Question about Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer
Lrd display showing E 42 and will not start a cycle
Pipes were frozen when washing machine went on,the threeway connector on the pipe flew off with the force of the water trying to get through the frozen pipe when replced display still reading E 42
    President:
  • 373 Answers
E42- Fault in tachimetric generator circuit
-Main PCB (tachimetric generator sensing circuit)
you might have to replace the main PCB also need to work on the pipes.it also means that the door remains locked. try perssing the start and pause button simultaneously for 5 secs and see if the error goes off.
Posted on Jan 05, 2009
  • Hotpoint Master
  • 19,396 Answers
Unplug machine from power, or cut power by tripping the circuit breaker. Wait 10 minutes then connect it back, this to reset the panel.
Ensure that the door lock is closing, not stuck.
Unsure water mis now coming through the water supply.
E 42 I think to remember is door lock, but from description it lets think to a fault related to water supply (inlet valve etc.).
  • Ginko
    Ginko Jan 05, 2009
    E42 is not listed as a valid hotpoint error code(E42 was door lock on Zanussi, therefore this can indicate a defective control assembly.
    The digital control board must be tested by a technician , and eventually replaced.
    Here is hotpoint code list, do first what suggested on my previous comment. If that does not work, call Hotpoint using the number listed on use and care manual, or click contact us for an explanation,
    and ask to confirm that E42 can be digital board error.
    If the error is not E42, but a different code , like F12, then give me the right code.
    Read also my previous message.
Inlet water valve error when the door is opened and closed during a washing cycle
If water is siphoning out, either drain hose is too far down pipe or there is an airtight seal where drain hose goes into pipe.
Aug 31, 2017 | Washing Machines
My washing machine keeps flashing e10 what is the problem
E10 - not filling make sure the water is turned fully on and pipes are not frozen if in garage. when you have checked everything then turn off machine at control panel and then unplug it for 5 mins then plug back in turn on and start cycle it should start to fill. hope this helped.
Dec 28, 2010 | Zanussi FJS1225W Front Load Washer
Mymachine was out in garage and pipes froze is it safe to now turn it on
if all the pipes are not frozen any more it should be ok to start make sure there is no ice in the pipes then check the drain hose if it is frozen if not should be ok to start try putting on rinse cycle to see if it fills ok and then switch it to spin to see if it drains ok if it does ok to use. hope this helps.
Dec 28, 2010 | Miele Novotronic Premier 500 Front Load...
I HAVE BOUGHT SAMSUNGWA80V3 TOP LOADING WASHING MACHINE. I AM GETTING ERROR 5E and WATER IS NOT DRAINED OUT.PLS ADVICE.
this error comes if waste water pipe jammed or blocked
2. WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
check the drain pipe that comes out the back of your machine
please message me back if this does not solve your appliance situation and please remember to rank how this opinion has helped Thanks again
Rick
Nov 09, 2010 | Samsung Washing Machines
Zanussi Jet Stream 1600 is displaying E10 as it has started its cycle to wash. Can you tell me what this means please?
I found that the water pipes were frozen! so I have 'gently' defrosted them and we are now working...
Thanks
Jan 10, 2010 | Zanussi IZ161S Front Load Washer
Hotpoint qualtis washing machine spin display showing H20 and won't start. model AQXXF 149PM
H20 means a problem with the water inlet supply.
Check the inlet hose/s for a kink or restriction, make sure it is turned on fully at the supply..
If it is cold fill only, could be a frozen pipe.
Hope this helps.
Jan 07, 2010 | Washing Machines
Have a Bosch Exxcel - error code F04 comes up half way through cycle - cleaned filter...still not resolved. Any ideas?
washing machin pipes were frozen in garage, defrosted now. done one wash half way through, error f04 came up. water still in machine and it makes a noise when trying to spin. The fillter knob has broken and i can't undo it to clean it out.
Oct 15, 2009 | Bosch Exxcel WFO 2264 Front Load Washer
Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer Logo
37 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
