Question about Car Audio & Video
Clarion ce008 comes up with no mag
Has no power and comes up with no mag
  • Tom Chichester Nov 16, 2012
    What is it installed in? Is the magazine installed when the no mag message appears?
Sometimes my clarion stereo won't turn on and it needs a couple of tries to hit the power button on
you need to contact clarion and tell them the problem sounds like you have a defective stereo and they should replace it under warranty
Mar 24, 2014 | Clarion NX602 In-Dash Car GPS Navigation
Clarion nx501 with hino and password
i hAVE the same exact issue and the 4 digit password to unlock it is the last 4 numbers the HINO trucks V.I.N... they say u only get 3 tries and it locks it and the only way to unlock it is to contact clarion... lick my balls clarion the default password is 0000 and u get 3 tries but just disconnect the power and reconnect the power and BAM... you will be asked to enter a security code all over again...0000 that is your unlock code.
as for the start- up HINO screen... good luck. its called a splash screen and you would have to hack clarions firmware in order to do so and i suppose if you were able to locate the internal hard drive but even then. clarion invested billions to protect their operation systems in their devices. i think the image is burned into the chip where the head unit was sent from a hino dealer brand new in a box directly to clarion's I.T. to have changed cause it comes factory as a clarion boot screen.
you will also notice that the hint clarion nx501 wiring harness is altered so to make work in that truck that only comes with two front speakers.... the rear speaker leads are nowhere to be found; GONE like a new brides panties!.. you also won't have any rya leads ect.. gay gay situation and if u figure out the splash screen change let me know.
peace.
S.D
Jan 16, 2013 | Clarion NX501
Apx4360 clarion amp has no power to it no lights come on the head unit comes on just the amp has no power fuse are good
Do you have the Continuous power wire hooked up to the amp from the stereo? that will generally make the amp not turn on.
Jun 06, 2011 | Clarion APX4360 Car Amp
I have a MAG INNOVISION LT765s LCD monitor. When the computer boots up, the power button on the monitor won't stay on so the display won't come on. It sometimes takes an hour of fooling around with the...
I have had similar problems with my Mag LCD monitor. I recently dicovered that the problem was with the adapter and not the monitor. Try replacing the power adapter.
Sep 21, 2009 | Mag Innovision InnoVision LT765 17" Flat...
Clarion apa4320 amp power light pulses
There is not enough power coming from you radio to power the amp. You might want to look in to a capacitor. What this will do is it will pull in the power and maintain a steady output for your amp to operate
Mar 18, 2009 | Clarion APA4320 Car Audio Amplifier
No ejection
hi does it make any noise or clicking?
you may have a cd dislodged or mag dammaged.
Mark
Sep 05, 2008 | Clarion DC625 6-Disc CD Changer
Clarion dc 625 cartridge
yas long as all the trays are still loaded in the cart/mag then you should be able to release it with a long flat peice of stiff card. push it under the cart/mag and kinda wiggle it this should trip the catch and pop out your mag
Mark
Blue ICE
Dec 11, 2007 | Clarion DC625 6-Disc CD Changer
Clarion dxz545mp doesn't power, does not work.
Check the fuses in the fuse block under the hood. Your clock fuse and radio constant power fuse are combined in this vehicle.
Jun 11, 2007 | Clarion DXZ545MP CD Player
Car Audio & Video Logo
53 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
