Question about Technics Audio Players & Recorders
Technics sl hd 81 cd multichanger shows NO DISC
The multichanger, when a disc is put into any of the five slots, doesn't sound like the disc spins - almost as soon as the draw is closed, NO DISC appears on the display screen.
  • Gary Stewart Nov 02, 2012
    Thanks for the advice - I've done that and the disc goes from the front to the back of the CD player, but then doesn't do anything else - the disc doesn't spin round like I'd expect it to. Usually, the discs spins so that the player can identify how many tracks on it. What do you think the problem is ?
    Master:
  • 444 Answers
Take the cover off to see what it is doing,
Posted on Nov 02, 2012
  • Rocky Degelman Nov 02, 2012
    Lazer is reading the disc,s any more, Or the mother is going on it, My advice (Garry) Is to just to look for a good use one that is working.It will cost you less then having it (Repaired)
    Sorry for the spelling erors garry, Lack of sleep.
HOEEEE
  • 7 Answers
SOURCE: Technics SL-HD350 Cd Player - Sound problems
This maybe due to overheating of some Sort.
Try taking it out of where it is where theres a good flow of air.
Then try running a cd.
Try Putting in a Cleaning cd, this maybe a fault with the laser.
Regards
Posted on Jan 05, 2008
  • 9 Answers
SOURCE: Technics SL-MC7 / Can't play cd's any more!
Friend. Did you try a CD that you purchased from the store? if so and this problem persist, then you need to get you a new player. If the CDs are scratched, some players will not play them, If they are burnt in mp3 format, (or data format) your player may not recognised this also. Please try playig a regular CD that you bought from the store, if this work, then you will need to reburn your music as a regular CD, hoping that the SL-MC700. reads copied. It should. But please checks these steps.
Please let me know what works.
Thank you
Posted on Dec 11, 2007
techman
  • 3130 Answers
SOURCE: Disc gets jammed mid-way between CD magazine slot and inside player
Thats alot of disc this ubit holds. 110+1!! The CD changer arm mechanism sounds like is out of timming or the gears have slipped there teeth, and or the cam is broken, or theres a couple of small microswitches that can get broken as well.. The only way to work on this unit and see what the problem is, is to get a service manual and go through the mechanical alighnment and see where the problem is. Unless you can do a physical examination and know where every lob and gear is suppose to be, I do not see any other ways.
Posted on Oct 06, 2006
SOURCE: Technics SL-MC6 CD player
a) the current CD in use is in slot 23
b) behind slot 23 is a CD left inside
Posted on Jul 31, 2008
  • 417 Answers
SOURCE: my technics sl-p770 doesn?t recognize the loaded
Try cleaning the lens with a cd/dvd lens cleaner disc. Another thing of note....some cd players simply will not recognize homemade cds, or dics that are not audio discs, or if they were made on a computer.
Posted on Apr 15, 2010
TECHNICS SL HD81 5 CD MULTICHANGER. The multichanger, when a disc is put into any of the five slots, doesn't sound like the disc spins - almost as soon as the draw is closed, NO DISC appears on th
The motor is shot,Or the gears are jamming up in it, Just look for a different one, It will cost you more to have it repaired, I have got good used disc (Players) For $10 to $40 at the most for friends of mine,
Nov 04, 2012 | Technics Audio Players & Recorders
Where can i get the drive belt for a technics sl mc400
Thank you malicious me I went to ace hardware and got an "O" ring the exact size you called for, put it on and bingo everything works like new. Thank you five years after your post. I had to pay a whopping 41 cents for mine!
Oct 22, 2012 | Technics SL-MC400 110-Disc CD Changer
Technics SL-MC60 error message: "Take out"
Hello
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
Feb 03, 2012 | Audio Players & Recorders
I own a technics CD changer Model SL-PD 787. The system powers up showing the disc & track no. but the timer does not count down . and therefore does not play. How can I fix the problem.
Actually it's the other way around. Playback makes the counter move. Did you hit PLAY or try to seek to a track or anything to verify it 'likes' the disc?
Sep 22, 2011 | Technics Audio Players & Recorders
SL PD887 5 disc CD changer was working one day but not the next day - does not read the CD - goes from one CD to the next but unable to read each CD in the changer. Have changed the CD's and cleaned the...
I have a model sl-pd847 and experience similar problems to many other submitters. I checked the main pcb and found discolouration around what appear to be 2 (power?) transistors and probably a voltage regulator. After about 4-5 minutes after switch on these get really hot. I suspect that may be the reason why it doesn't work anymore. Worth fixing? I don't think so. This one didn't even play CD-R let alone CD-RW! Get something a bit more up to date I say.
Jan 16, 2011 | Technics SL-PD887 5-Disc CD Changer
Door will not open,get checking disc message
I solvwed the problem by removing the cover and found 2 discs jammed into the same slot. removed them and put them in the proiper slos, put back cover, gently tightening the screws incase it happens again.
technics 110 cd changer. model sl-mc310.
Dec 20, 2009 | Technics Audio Players & Recorders
You have to removo all disc
Then turn on the unit and let do the initialization process
May 26, 2007 | Technics SL-MC6 CD Player
Oct 06, 2006 | Technics SL-MC6 CD Player
142 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
