Question about D-Link AirPlus DI-524 Wireless Router
Di 524 through speedstream 5200: wireless connects but no browse
got 2 towers on a di524 router. the router plugs into a s.s5200 for its isp (dsl)
the cabled 1 works fine, connects browses no problems
the usb wireless adapter not so lucky! can't even connect the thing (64bit wep) unless i manually enter ip('s - tried a few), gateway & dns
then it will connect (strong) but i cannot surf.
even played with lan settings in IE to add a direct proxy... no go.
how do i make it work again? because i had wireless before, diff house, diff isp (cable)!
help
  • adam95glx Jan 04, 2009
    same guy ....
    so in Network Connections /Properties/ TCP/IP property (settings)
    at the bottom of this screen is 'advanced' whether your auto assigned ip or entered ur own.
    in that advanced tab you have things like dhcp.. tcp over net bios..
    i had to enable or change tcp over netbios.. for the wifi to get assinged from the dhcp server..
    i found this in run: cmd : ipconfig/help
  • 49 Answers
Try re-installing the driver for your USB adapter or create a new wireless network name.
You could also try to download the latest driver for your USB adapter. uninstall the old driver before installing the latest driver for your USB adapter.
Posted on Jan 05, 2009
Need to connect DI524 for wireless connection to internet
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
May 16, 2011 | D-Link AirPlus DI-524 Wireless Router
Forgot my DI 524 setup password, pushed RESET button, what next?
You will need to login as admin and set it up again. Connect per ethernet cable, open a browser and enter 192.168.0.1 You should see a router welcome screen or logon dialog login as admin the default password maybe one of several things depending on the particular revision/edition blank/null 'admin' 'password'
Support for this model is available at http://www.dlink.com/products/?pid=DI-524&tab=3 manual at ftp://ftp.dlink.com/Gateway/di524/Manual/DI-524_manual_06292005.zip
Once you're in you will have to set up an ISP connection which may require your ISP username / password and selecting a protocol particular to your ISP and setting up the wireless WEP key
Jan 08, 2011 | D-Link AirPlus DI-524 Wireless Router
I have a DI524 that was connected to my dsl modem before. Now I moved to a cable modem and connected the DI524 to the cable modem, but the wireless router doesnt work. help?
you have to confgure all the the setting in wireless configuration according to the cable connection then it will work.
Have a nice day and do not forget to rate please...!
Feb 02, 2010 | D-Link DI-524 4 Port Wireless-G Router -...
I have hooked my di 524 from my DSL cable modem then hooked the two in line to my computer when I hooked up to the computer I have no connectivity why?
OK, if I understand:
telephone----DSL Modem--di 524--computer.
That is what you are supposed to do.
Has any configuration of these devices ever had any connectivity?
1. Is the DSL modem in "Bridge Mode"? That is the first thing I'd check.
2. Are you using the right wires and ports? There may be a DCE-DTE problem. Be sure you have used the wire that came with the DSL modem to hook it to the internet port on the DI-524.
3. What is the state of all the various lights? Do they show that you have valid connections?
4. Most of these devices can be configured with a browser. When you browse them, what do you see?
5. What is windows telling you?
Jan 09, 2010 | D-Link DI-524/DWL-G630 (di524dwlg630kit)...
Dlink DI524 wireless problem: cannot access the router
If the Router is new proceed to Step 1. If the Router is used power on and press and hold the Reset button for about 10 seconds. It is located next to where the power cord is plugged in. Use either a pen or paper clip to push reset button.
Step 1. Connect one end of an Ethernet cable to the Ethernet port located on the Cable / DSL modem and the other end to the WAN port on your D-Link DI524 wireless Router. The WAN LED light will illuminate to indicate proper connection.
Step 2. Connect one end of an Ethernet cable to LAN Port 1 on the back panel of the DI-524 and the other end to the network adapter in the computer you are using to
configure the DI-524. The LED light for LAN Port 1 illuminates to indicate proper
connection.
Step 3. Once all pieces ar connected. Open your Web browser and type http://192.168.0.1 into the URL address box then press ENTER. Once the log-on pop-up screen appears type admin for the user-name and leave the password blank then click ok.
Step 4. Once you have logged in, the Home screen will appear and you should see a box called RUN WIZARD in the middle of the screen. Click that box and follow the steps.
Setup Step 1 - Click Next
Setup Step 2 - Create Password and click Next
Setup Step 3 - Choose Time Zone and click Next
Setup Step 4 - Setup wizard will try to auto-detect your Internet connection type.
Setup Step 5 - Select your Internet Connection. You will be prompted to select the type of Internet connection for your router. More than likely it will be Dynamic IP Address. Click Next.
Setup Step 6 - Click the “Clone MAC Address” button to automatically copy the MAC address of the network adapter in your computer. You can also manually type in the MAC address. Click Next.
Setup Step 7 - The default wireless settings for your 802.11g wireless network are: SSID = default Channel = 6. You can change the SSID name to whatever you like. This will be the name of your wireless network. Click Next.
Step 8 - If you wish to use encryption for your 802.11g network, the DI-524 is capable of two levels of wireless encryption - 64-bit and 128-bit. By default the encryption is disabled. You can change the encryption settings for more secure wireless communication. If you choose to use encryption, you will need to write down the encryption key so that you can connect your laptop or pc via wireless connection. Click Next
Setup Step 9 - Your is complete. Click Restart to save and reboot your router.
Setup Step 10 - Click Close to complete your setup.
Setup Step 11 - You will be returned to the Home tab. Close this window and wait for the Router to finish rebooting. Then relaunch your Web browser (i.e., Internet Explorer or Netscape Navigator), to link to your favorite Web site to test your Internet connection.
Here is the link to download all the necessary info to configure your router - http://www.dlink.com/products/?pid=DI-524&tab=1
Jun 21, 2009 | D-Link AirPlus DI-524 Wireless Router
I just purchased a D-Link 2.4GHz Wireless Broadband Router
U need to confirm that your router is connected to cable/DSL modem that has access to internet from ISP.
This is due to DI524 just a wireless router, u need to add in a modem for internet access.
Mar 29, 2009 | D-Link AirPlus DI-524 Wireless Router
DI 524 and airport express
Yes, that is possible for as long the DI524 is already properly setup and can provide already internet connection everything should be working fine there....
Nov 10, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524
make sure you have the wireless lan activated(software/hardware) and also configure your router's wireless setting(connecting thelaptop to the router by ethernet cable).write the wireless configuration down and configure your laptop with the same SSID and WEP key.it shud connect and you shud able to be good to goo..don'tforget to configure your DSL to therouter.post your router/modem/ISP details for further help
Feb 02, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
347 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
