Question about Ovens
We have a Scholtes FX 36, built in/self cleaning oven. The oven continues to beep long after the oven has been shut off. The clock symbol appears next to the
  • Tammy Nov 04, 2012
    The oven turns on by itself, and continues to beep. Technicians have looked at the control panel and assured me that all connections are secure. Any advice?
SOURCE: dacor oven ECPS127S will not heat after self clean
the problem was fixed by opening the panel between the oven cavity and the touch panel just behinf the door. you can look through the grill but to trip the reset you must unscrew the panel. you will find the reset back behind the wires Looks a red button nestled on top not very open but it should be there> i do have to say i found a step by step description on this site. but right now i can't tell you who exactly he was.
Posted on Feb 24, 2008
SOURCE: "Door Locked" keeps flashing
Was able to get the lock to go in on the door and then turned off the power which reset the system.
Posted on Apr 01, 2008
SOURCE: Whirlpool self-cleaning electric built in oven
I have the same problem. Who has a solution?
Posted on Aug 24, 2008
ginko
  • 19396 Answers
SOURCE: GE Elec oven JT952-30" blinks the "lock" after self-clean
Try unplugging power cord or trip circuit breaker, to cut the power to the appliance, then wait one or towo hours for the oven to cool down completely.
If the door stays locked, then there is a fault, probably a faulty temp probe that had blown because of high temperatures generated on self cleaning, or a defective control assembly. In that case you will need to call a technician to take apart the oven and fix the fault.
Enter model number here to find assembly diagrams and parts.
Posted on Jan 02, 2009
SOURCE: Moffat Self-Cleaning Oven will not self-clean
did you try setting a start and stop time with the time knobs? i had the same problem til i set 3 hrs on the start and stop, then let it sit (after locking the door and turning the knob to clean). after it was warmed to cleaning temp, the light for cleaning came one...
Posted on Jun 11, 2009
Hit button for auto clean a Whirlpool self cleaning oven super capacity 465. After I hit the button 3:30 comes on screen then I hit start and it starts beeping with a message of F5E1. Help?
that's a problem with the latch assy. if the oven works don't worry about it,your better off not using the self clean,the oven gets up to 1000 degrees and can damage the electronics in the oven,seen it before and tell people not to use it,use easy off works just as good and you won't damage anything in the oven,people do this right before the holidays and then you go out and the clock assy. is bad or the latch gets damaged and the parts have to be ordered and they can't use the oven for the holidays,some of the clock assy. are big bucks,it's not just the clock it has a computer board that the clock is built into and they can cost from 160 to 500 dollars or more or if the oven is old you can't get the parts anymore,if your oven is working forget the self clean.
Sep 22, 2017 | Whirlpool Ovens
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 | Ovens
After cleaning both ovens have received F2 code Replaced sensor on one and now sensor is bad on the other one. theoven i replaced the sensor on continues to work but i am still getting the beep and F2...
most likely you have a bad computer board or clock assy. same thing,when you self clean the oven it gets up to 1000 degrees and can and will damage the electronics in the oven,after the things i've seen i will never use the self clean again,i clean my oven with an sos pad and hot water usually it's just the floor that gets drips on it,i take the racks and floor out and clean them by hand,if anything on the walls i scrub it out,don't use the self clean on any stove the extra heat kills them.
Nov 01, 2017 | Jenn-Air JJW8230D Electric Double Oven
How do i operate the self cleaning function
Hello - Before using the self-cleaning cycle of the appliance, remove the broiler pan and any utensils stored in the appliance. Also remove any excess spillovers in the oven cavity. Allow the oven to cool before cleaning. During the self-cleaning cycle, the outside of the wall oven can become very hot to the touch.
Typically to set the controls for a self-clean the first step is to confirm that the clock shows the correct time of the day. Press CLEAN. "---" appears in the display. Press the UP ARROW or DOWN ARROW once. "3:00" appears in the display for a 3 hour cycle. To change to a 2 hour cycle press DOWN ARROW"2:00" appears in the display. As soon as the controls are set, the motor drive lock will begin to close automatically and the "LOCK" indicator light will flash. DO NOT open the oven door while the light is flashing (it takes about 15 seconds for the over door to lock). "CLn" will appear in the display during the Self-Clean cycle and the "LOCK" light will glow until the Self-Cleaning cycle is complete or cancelled and the oven temperature has cooled.
When the Self-Clean cycle has completed, the time of the day or "End" will appear in the display window and the "Clean" and "LOCK" light will continue to glow. Once the over has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. If "End" is the display and the Clean indicator light remains ON, press CLEAR/OFF. The time of the day will appear in the display.
If it becomes necessary to stop or interrupt a Self-Cleaning cycle, press CLEAR/OFF. Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. Restart the Self-Clean cycle once all conditions have been corrected.
Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
My frigerdaire oven heats for a while about 15-30 minutes then shuts down with a beeping noise and a f3 code.
Good Afternoon Friend,
I see that your Frigidaire double oven heats up for about 15-30 minutes, then shuts down and begins beeping while showing an F3error code. The F3 states that the oven is sensing a potential runaway temperature. This is possibly a sensor issue or it could be a false error code.
I suggest giving your double oven a hard reset by cutting the power at the circuit breaker for at least 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Let the oven heat up, and if you are still receiving an F3 error code, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
WP
Jan 27, 2012 | Frigidaire 30 in. Electric Gallery Series...
OVEN WONT SHUT OFF F1 COMES UP AND IT BEEPS
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock)
Feb 13, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
We are using self clean feature. continuous beep about 20 minutes into cleaning screen shows F# locked door and beeps nonstop. what can we do to stop beeping but still proced with self cleaning?
F3 is a bad oven temp sensor. The sensor fail F3 code will appear if during self clean that it senses temps above 915F, or there is an open / short in the temp sensor. The only thing you can do is replace the sensor. Just getting the oven door open can be a real pain as you have unlatch the oven door lock to get to the screws that are in the top lip above the oven door so that you can change the sensor. Depending on model you may have to reach through a burner to manually unlatch the oven door lock or remove the side panel of the oven to manually unlatch the door lock. On most units It will not continue to self clean with an F3 code detected. Once an F3 code is detected the ERC shuts off power to the bake and broil elements so that it does not catch fire from a run away temperature condition.
Thanks for choosing FixYa,
Kelly
Nov 25, 2010 | Ovens
GE Profile Stove
I used what Charlie recommended ...” post-it” as insulation
And works PERFECTLY….
I have a Kenmore oven Clock…( built in the wall)
Thanks Charlie…you are a Genius!!!!
Jul 15, 2008 | GE JKP15 Electric Single Oven
Self-Clean gets too hot on JTP56 double-oven
Your husband is correct, kind of. You should not try self clean again until you get the oven repaired. You have a temp sensor going out. I doubt that the oven actually got too hot, most likely the resistor in the sensor is failing as it heats up and giving a false temp reading.Since the lower oven was operating at the time, it is probably the sensor in the lower oven. Don't use it for baking until you get it repaired. It will go out completely and shut down both ovens. You should be able to get a new sensor for around $30 and they are not hard to replace.
The oven won't set your house on fire during clean mode if the cabinets were built with the correct air space and dimensions, but they do get very hot, about 800 degrees F. Most ovens give no trouble during the clean cycle, but if there is any weak components in the electronics system it will show up then. It will give you less trouble over time if you don't use the self clean mode and just manually clean it.
Jan 18, 2008 | GE Profile JTP56 Electric Double Oven
Ovens Logo
6,744 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
