Question about Toshiba satellite c660
Toshiba satellite c660 touchpad keyboard not working
Computer bots up and shows normal display but keyboard and touchpad do not work
IB4G2008
  • 3587 Answers
SOURCE: My Toshiba labtop's touchpad and keyboard won't work
oooh..frozen...eagle338 must have been in the cooler, eh?
only way to connect with him/her is to add them as a buddy, then do an 'ask buddy' request..
Posted on Mar 07, 2008
  • 3 Answers
SOURCE: Toshiba TouchPad Not Working
tap on the touchpad or click on the top rightand if that does not work it is defently the hardware or software
Posted on Nov 26, 2008
benwabnick
  • 2404 Answers
SOURCE: Toshiba Satellite Touchpad not working
Restore the defaults in the BIOS to begin with, this will make sure its not a setting in there that is disabling the mousepad.
Then in windows see if the touchpad is working. If not then take the keyboard out with the power turned off.
When you take the keyboard out you will see the ribbon cable that comes from underneath the touchpad. disconnect it from the motherboard and reseat it firmly back in. Then turn back on the motherboard and see if the mousepad works. If it still doesn't then try the shortcut key to enable it.
If it does't enable then that means its either going to be a mousepad problem where you would have to replace the top cover assembly or a motherboard problem cause it could be where the voltage required to run that mousepad is missing.
Posted on Jun 27, 2009
  • 17 Answers
SOURCE: Toshiba Satellite L305D Unresponsive Touchpad
It is possibly an error with the driver. To check, go to Control Panel and then the Device Manager. Look for the section labeled "Mice and other pointing devices" and look for "Synaptics PS/2 Port TouchPad" or anything which has TouchPad in the title. If it has a weird yellow triangle with an exclamation point, there may be a driver problem. Double click on the device, choose the Driver tab at the top and choose to Update Driver. Choose to automatically search and hopefully you should find, then install, the driver.
Have you recently run any Windows updates? If so, that may have messed up the driver. Instead of choosing to update the driver, choose to roll it back instead.
My solution is only for a bad driver. I hope this helps you and apologize if it does not.
Posted on Jul 15, 2010
  • 375 Answers
SOURCE: I have a Toshiba C660-116
try FN+F7, this switches the touchpad on and off
Posted on May 05, 2011
How to reset a toshiba c660 to its original settings
Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear
this is how i did my partners c660
may also if its in bootable condition work by pressing f8 at startup then repair my pc then factory recover option
  • Report abuse
Jul 28, 2013 | Toshiba satellite c660
Toshiba Satellite A65-S126 keyboard no longer works
If you have the disk or driver for keyboard then reload it.
If not then use the mouse and click on the Start button, use the mouse's right button on Computer (My Computer). Select Manage. When the Computer Management console appears, Select Device Manager. Expand the Keyboard Section. Right Click on your computer name and select Scan for hardware changes.
If this fails to reload the driver then right click on the keyboard item that says Unknown and select Update Driver Software.
Jan 29, 2013 | Toshiba Satellite A65-S126 Notebook
My function keys doesn't work in my laptop toshiba satellite c660-a047
The function key, labeled "Fn" and located in the lower-left corner of your keyboard, is a useful feature. By pressing "Fn" along with one of the numbered function keys at the top of the keyboard (F1 through F12), you can adjust your screen brightness, enable and disable your touchpad or wireless modem, lock your computer and complete a variety of other tasks. These keys will not work if the "Fn" key is not pressed along with them. While the "Fn" key itself does not turn on and off, there are settings that can make it behave differently, or seem to be disabled.
Click "Start," then "All programs" or "Programs," then "Toshiba." Select "Utilities," then "Accessibility." Place a checkmark in the box to make sure the "Fn" key will work whether you press it simultaneously with the F1 through F12 keys or immediately before pressing those keys. Customize the other options on the screen, then click "OK." Test your "Fn" key. One of the easiest ways to do this is by pressing "Fn" and "Esc" at the same time. This toggles the sound on your computer on and off, and will show a speaker icon on your screen if it works. Press "Fn" and "Num lock" at the same time if the "Fn" key still does not work. Use the "F11" key if your laptop has no "Num Lock" key. Test the "Fn" key again, using the same method as in Step 4. Locate a licensed repair technician if the key still is not working. A hardware issue may be at fault. Hope this helps.
Jan 09, 2013 | Toshiba satellite c660
My laptop toshiba satellite c660 does not show any wireless connections
Look for a key on the keyboard which has a wireless picture on it,then press that key and the Fn (function) key at the same time when you're on the desktop
Aug 26, 2012 | Toshiba satellite c660
Touchpad not in device manager
Hi There,
The touchpad will normally show up under input devices in device manager. If you don't see it listed, check to see if your touchpad has a manual on/off switch located on the laptop keyboard (sometimes under specialized function keys)
If a switch doesn't seem to be the issue, try reinstalling the drivers for the touchpad, which should be available on the toshiba website.
Aug 06, 2012 | Toshiba Satellite P105-S6197 Laptop
Laptop toshiba satellite m300 keyboard and touchpad not work
Run a full virus scan with your antivirus, also go to www.download.com Type: malwarebytes anti-malware and run a full scan, if all that fails sub out the ram and test.
May 21, 2012 | Toshiba Satellite A70 A75 P10 P15 Notebook
Locked keybroad toshiba satellite C660
Try booting in safe mode and see if the keyboard is locked. Maybe the keyboard is bad.
Turn off the computer, then hit the power button to turn itback on and immediately start hitting the F8 key repeatedly until you see SAFEMODE. Take the Safe Mode option and let it boot up. Safe Mode will lookdifferent to you, the screen will be darker and the icons bigger, this isnormal.
May 08, 2012 | Toshiba satellite c660
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Toshiba satellite c660 Logo
304 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
