Question about Sewing Machines
Left needle thread on empisal sd4 not stitching
Have re-threaded overlocker several times, perhaps i'm missing something but the left needle thread is not stitching - what could be the problem?
  • johduffin
    johduffin Nov 04, 2012
    I actually took the overlocker to get serviced last week & was told the timing was out. All fixed now, YAY!
bargainbox
  • 1388 Answers
SOURCE: mock safety stitch
Sounds like the timing is a little out.
If you remove the needle plate and turn the handwheel manually watch for the lower looper as it swings behind the Left needle....the needles ought to rise by only about 2mm before the looper passes......the looper must pass the needle above the eye to catch the thread, and be so close as to be barely touching the rear of the needles......if the left needle thread is not picked up, it may be the timing, or the distance between needle and looper.
For the uninitiated, there are a myriad of variables in correctly timing an overlocker (serger), and without the manual to refer to the correct parameters, you will rapidly descend down a road of despair....if you move a looper to advance or ****** the timing, you risk looper collision and a broken looper is almost as much as a service, so my advice is do the test to see if the timing is the likely culprit, and if so, take the opportunity to give the old girl a treat.
If you need to save for a while to do it, just use the 3 thread option for the time being.
www.bargainbox.com.au
Posted on May 10, 2008
SOURCE: thread continually breaking in lower looper needle
I was having this very same problem with my lower looper . I had been using the one needle stitching all afternoon and I was doing quite nice stitching. then I decided to put the right needle back in and do some overlock stitching and guess what I spent the next two hours fighting the looper problem. I had completely re-thread this machine at least 20 times now. I decided to take the needle out and re-insert it and re-thread it one more time (right lower looper- then upper looper- right needle- then left needle) was careful to pull all threads to the back and under the presser foot for about 6 inches.
Held on to the thread, lowered presser foot and did the chaining stitch. BINGO it didn't break, tried it with a piece of cloth and Perfect stitches. I have a Babylock BL402 and used tension settings left to right
4-3-3-3 and default settings for the rest.
Hope this helps someone someday.
Jo Griffith
Posted on Mar 29, 2009
SOURCE: On my overlocker, the bottom two threads keep breaking.
globe overlocker stitching reverse
Posted on Jun 18, 2009
RickE1
  • 202 Answers
SOURCE: Threading an Empisal Overlocker - Model S4D
All sergers thread the same way and sergers have to be threaded in a certain order. I made a jingle out of it...
upper looper
lower looper
right needle
left
It would be best to have a tweezers handy to help with the thread and threading.
always be sure the lower looper thread goes over the top of the upper looper then out the back. I would be surprised if your thread guides are not color coded.
If you look at the top thread guides or the spools. First from left to right thread the 3rd spool, then the fourth spool. Then you thread the right needle (the second spool) then the left needle (1st spool.
The lower looper can be tricky because you have to thread it from the back of the looper to the front.
Pull the threads out the back from under the foot. Then go ahead and run it slow watching to see if it starts making a chain. It should. If not do it over again.
Good luck
Rick Engel
Posted on Aug 03, 2009
  • 40 Answers
SOURCE: I need a manual for an Empisal overlocker Model
www.janomestuff.com answer it all
Posted on Sep 15, 2009
Husky 910 overlocker..left needle will not sew stitches...does not unthread just won't form stitches
Be sure to install a brand new needle. Verify it is the correct needle for your machine and it is installed facing the correct direction.
Remove all the thread from your machine. (Clip the threads below the thread spools, RAISE the presser foot, and gently pull all the threads DOWN through the needle--NEVER up!)
ALWAYS RAISE the presser foot and rethread from the beginning. Verify that you are threading each thread in the order specified in the manual--failure to do so will cause your machine to malfunction.
When threading, give each thread an extra little tug when going through the tension disk.
Set all the tensions to the midway point for a 3 or 4 thread overlock.
Test your machine.
If the left needle still fails to stitch, then your machine may need a timing adjustment.
Apr 24, 2017 | Sewing Machines
How to thread a Empisal overlocker.. model 760C
Perhaps the manual would help:
Empisal Overlocker 760C Empisal Sewing Machines
On most machines, it is important to ALWAYS raise the presser foot when threading the machine (although the instruction manual says to raise the presser foot only to pull the thread tail under it). Be sure to give the thread an extra little tug when going through the tension disk to seat it properly. Be sure to thread in the order as specified (Upper looper, Lower looper, Right needle, Left Needle). If the machine messes up, it is usually a best policy to remove all the thread and rethread from the beginning. Threading out of order will almost guarantee failure!!!
Jul 20, 2016 | Sewing Machines
I have an empisal overlocker and the needles keep breaking. What am I doing wrong?
Perhaps this will give you some ideas:
Serger needles Threads Magazine Gatherings Forum Sewing Questions Answers
Make sure the threads are not hanging up somewhere on the way to the needles. As suggested, if checking the needles, thread path, and tension does not achieve success, you may need to take it for service. Could be a timing issue.
Jun 10, 2016 | Sewing Machines
I need help in good tension for rolled hem in empisal 606D overlocker
Your owner's manual should have instructions for rolled hem settings. My Bernina manual has a the following settings:
Medium weight fabric
80/12 Universal needle
3 cones serger thread
Upper looper 3-5
Lower looper 7-9
Left needle (no thread)
Right needle 3-5
Stitch length 1-1.5
Cutting width 2-3
Differential feed N
Can use woolly thread in the upper looper, but the tension may need to be loosened since the woolly nylon thread will stretch.
Make It Handmade Threading Your Serger or Overlocker
Dec 19, 2015 | Sewing Machines
Can a Empisal Electronic Overlocker 760DE do topstitching?
Thats a 4 thread serger, you cant do a top stitch unless its a 5 thread
Sep 19, 2014 | Sewing Machines
Left needle thread not connecting
Timing an overlocker is NOT for home service, it takes training, tools, gauges and experience take it in to get it fixed
Jan 06, 2014 | White Sewing Superlock 1934D Mechanical...
I purchased a used SingerSH654 and am at the "dreaded" threading stage. I have threaded using the book and sitting with the serger using the DVD. My left needle (B) thread will not pick up the lower...
I have had a similar problem with my overlocker and had to adjust the height of the needle by moving it lower.
because one needle was so fussy i use my overlocker with only one needle, which give a good enough stitch for what i'm doing
Sep 08, 2010 | Singer 14SH654
upper looper
lower looper
right needle
left
Good luck
Rick Engel
Jul 18, 2009 | Sewing Machines
Singer overlocker
Most likely is the left looper thread is trapping the needle threads.
Remove the threads and start over in this sequence....
Left looper - right looper - left needle - right needle.
If you thread the needles before the lower looper, the needle thread wrapped over the looper will be under the looper thread and will never be free to form a stitch, so the threading sequence is critical.
Jun 08, 2008 | Sewing Machines
Bernina 1300 dc overlocker skipping stitches
Make sure the chain stitch thread is threaded exactly as it should be, make doubly sure the thread comes off the bobbin vertically and runs through all eyes smoothly. Any faults in the threading causes extra tension at the needle despite what the tension is set on.
If this is not the cause then the needle depth and the looper timing needs checking.
Rob
Mar 14, 2008 | Sewing Machines
Sewing Machines Logo
51 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
