Question about Refrigerators
Water condenses on outside bottom of freezer and drips on floor
The outside bottom of my Sub Zero 542 is cold and condenses water which drips onto the floor. After defosting the freezer and leaving it off for four days water is still leaking out of the bottom. I suspect the insulation has some how gotten wet. Can I remove the bottom of the freezer and replace the insulation? Alternatively can I try to spray expanding foam insulation on the outside bottom to keep room air from contacting the cold bottom. I cleaned the drip tube and it was not clogged.
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
I would not remove the bottom and replace the insulation. Where is the unit located in your home?
Posted on Nov 02, 2012
SOURCE: Sub-Zero 550 water dripping on right side of freezer forming ice on draw
I had a similar issue that started about a year ago with my Sub-Zero 550. My freezer gasket actually tore after several times of freezing closed. I thought that a new gasket would solve it, but a second but related problem developed where I was getting alot of condensation under the left side of the unit, with the water dripping onto the floor...eventually staining the hardwood floor in front of the unit.
I traced the problem to a clogged condensation drain pipe in the refrigerator. It is a corrugated pipe that drains a trough behind the crisper drawers. My pipe was clogged with black sludge and frozen down below. The condensation in the fridge would overflow out of the trough and leak below the crisper drawers, down out through the gasket.
To resolve, I used a piece of solid thin wire folded in half and twisted with a small loop at the end to fish out as much sludge as I could. Then squirted hot water into the pipe until it totally unclogged. I believe this will solve the problem without any need for a heater underneath the unit. The 550 worked fine for 4-5 years before this happened.
Posted on Nov 29, 2008
  • 56 Answers
The drain line has been clogged. There is actually a defrost heater kit for that problem if you can get the obstruction out. Did you call factory at 800-222-7820 or a local factory authorized servicer? The drain is accessed by removing the fan shroud and evaporator cover. There are a number of of phillips head screws that hold this in place. Once you have removed the two cover you will see the drain tube on the left side of the unit. I use a hair dryer to start defrosting the tube. If you have another freezer in the house it is easier just to turn the freeezer section off for a day or so. I use nitrogen to blow the line out from the bottom once everything has defrosted. Test for water flow, then put unit back together. Call the factory at the number above for the heater kit part number and they will also give you the local authorized parts supplier. The locator web address is http://subzero.com/locator/locator.aspx?type=0&zip=Zip%20Code
Posted on Feb 22, 2009
  • 400 Answers
SOURCE: There is a water leak inside the freezer
You need to remove the bottom two baskets, or more to make space. Using a hairdryer, defrost the back area. You should be able to locate a drain hole in the center below the freezer coils. This drain hole is connected on the outside to a drainpipe which has a p trap and often gets blocked up. You need to force water down the drain hole. You can use a turkey baster or similar type of plunger filled with water. Once you have cleared the blockage pour hot water till it runs freely. Hope this sorts your problem, don't forget to rate me.
Posted on Mar 11, 2009
Bat1956
  • 585 Answers
SOURCE: drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
The accumulated ice you saw is of course the source of the water. The refrigerator will eventually rid itself of the excess ice and the problem will therefore disappear on it's own after a while. The drip pan is normally filled with only a small amount of water, and that is dried up by the condenser cooling fan under the fridge. The pan is removable from most units, but not without making a mess. I suppose you can make and clean up the mess one time and be done with it.
Posted on May 20, 2009
  • 9 Answers
SOURCE: Refrigerator leaking water
This sounds like the water line from the icemaker and the cool water reservior inside the refridgerator side. The line is a rigid plastic hose and could be a leak at one point that is small enough to allow water to run along the line. Also sounds like you have a humidity problem. Check the door seals and wipe them off and apply a thin coat of die-electric grease to the seal. this will help keep it pliable and soft.
The water in the bottom leaks into a trough that is made into the fridge. This usaully evaporates, This is for the auto-defrost. It keeps the water from getting on the floor.
Check to see if the outer door gets hot at the edges. If not, It may not be auto-defrosting.
I would first check the water line first as this seems to be a more serious issue right now. The line is probably loose at one of the connections between the ice maker and water reservior.
Posted on Jun 14, 2009
Water on floor
The hose that goes into the drip pan to defrost the refer is plugged with stuff.
take the back off and see the hose connection.A coat hanger works well.Usually a 1/4" hose.
Also see where the bottom of the freezer drains into the drip pan.That may be plugged,also.
The temp may be set too low and the condenser is frozen up,leaking water into the floor.Just ice stuck to the condenser.
Possible that the condenser FAN stopped turning. That will ice up and melt at random:
see/hear that the fan is working.
If stuff gets into the fan,it will ice up,melt and make a mess on the floor.
Nov 26, 2012 | Sub-Zero 700 Refrigerator Freezer...
Water leaking
the bottom tray/salad compartment will always get a fair amount of condensation because they are glossy plastic(bathroom paint is matt)the only "cure" is kitchen towel under the tray and remove once a week.as for the drain it is normally at the back and does collect a fair amount of "moss"in the tube,pour some clorine bleach down to clear any out.the design of the shelves directs the side/back condensation down the drain.
Apr 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
Sub Zero 611F "vacuum condenser" warning persists, unit not 100%
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 29, 2009 | Sub-Zero 611 / O Bottom Freezer...
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Subzero model #561, freezer is warm, water leak
Check to see if the freezer fan is running. Push in the two switches at the top. The light should go out and if the freezer is powered on the fan should come on. The icemaker runs on temperature so no cold means no ice. Check for ice build up around the evaporator. Could be a defrost issue or a sealed system problem. As for the water, is it the floor of the unit or the floor of the house? Is the drippan in place or sitting on the floor? Also check the condenser fan motor. If this is all greek to you, you should probably call a factory authorized servicer.
Feb 03, 2009 | Sub-Zero 561 / F
Jan 26, 2009 | Sub-Zero 650 / O Bottom Freezer...
Bottom freezer door dripping water on kitchen floor
you can take a ook into the freezer sect its possible that the line has frozen, nad no longer is defrost water going into the drain but rather falling on to the floor of freezer and evnetually out the door
Jan 11, 2009 | Freezers
550 Sub zero
your drain is clogged or frozen over,the drain is most all the time in the middle back bottom of freezer,you might have to remove the freezer back wall to get at the drain,use a hair dryer to melt the ice and a metal hanger to clear the drain,let me know how you make out-mike
Nov 02, 2008 | Sub-Zero Refrigerators
Jan 14, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
163 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
