Want to know wheather i should the Four Big screws at the back
  • 978 Answers
You remove them there only for transport
Posted on Nov 02, 2012
2 Suggested Answers
  • 254 Answers
SOURCE: wfw8300sw on the back of the washer it says to
NO, thosee are ur shipping bolts, only reinstall if u are moving.it holds the tub in place, u will mess up that unit if u operate it with those in..
Posted on Feb 03, 2010
Please, how can open A4TECH model X6-80D Thanks
There are four screws beneath the plastic pads or 'feet' of your mouse. They are just glued lightly. Also, the glue is rather decent and might serve to stick the pads back again, if handled carefully
Mar 21, 2011 | A4tech Mouse
The printer is giving me a message to check printer (press resume key) I have already checked for any obstructions or paper jams and need to know how to replace the waste ink tank to see if this is...
try these steps to fix the problem:
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu Copy Copy Copy Scan
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [Set] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Aug 25, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
I have a Fossil Automatic Watch, model ME1032. The case back is held intact by four small screws. I lost one of the screws after I cleaned the movement. Where may I purchase another screw without going...
mcdevito75 here, Almost any jeweler should have another screw for the case back. You may even save a few bucks going to a small jeweler shop over one of the big concerns.
Jun 15, 2010 | Fossil AU4003 Wristwatch
How to change dash board lights
remove the two screws on top of the bezel pull the bezel out then remove the four screws holding the cluster then remove the wire harness that is plugged into the cluster and the lights are the big green tabs on the back of the cluster panel
Feb 25, 2010 | 2002 Toyota Corolla
My computer tower wont stop beeping
Re-seat the memory.. more than likely they have unseated themselves during the dust cleaning. Beeping is usually caused by memory.. Beeps are usually a series like Morris code long..short beeps.. if re-seating the memory doesn't work, try swapping and removing different sticks and differnet locations on the motherboard, most motherboards have 2-4 memory banks or known as dimm slots.
Jan 16, 2010 | Ultra Products Ultra M923 Full Tower ATX...
Where is the air filter located on a 2002 Yukon XL?
under hood on the passenger side in a box follow black tube from engine to the passenger side big black box cover is held on with four philips screws or four torx screws, remove the screws and lift the cover air filter inside.
Aug 30, 2009 | 2002 GMC Yukon XL
Changing motor hayward 1.5 HP
Super pumps are very easy. If it is a northstar it is more difficult. Super pump. You will need 1 motor, 1 pump seal, 1 diffuser gasket, 1 housing gasket. turn off breaker, disconnect wires -noting whether it is 110 or 220 volts- , unscrew four bolts on back of pump housing (shaft side of motor), pull out motor with rear housing and diffuser (sometimes diffuser sticks inside), on wire side of motor hold shaft with wrench (flathead in some cases, but it is harder), unscrew impeller counter clockwise (like normal screw - you will nee a big pair of channel locks or a strap wrench), there are two pieces of the back housing and once the impailer is off you can remove the half that is closest to the end of the shaft to reveal four more screws, unscrew those four screws. screw back part of rear housing onto new motor. Install new pump seal to front part of rear housing and impeller, slide on front part of rear housing and then screw on impeller while holding shaft on wire side with wrench (only hand tight), replace housing gasket, replace diffuser gasket, slide into front housing and screw in four bolts. If electrical was 110 you will need to move the jumper on the wire end..if it was 220 then just hook kup wires...doesnt matter which is which as long as green or bare goes to the ground screw.
Mar 14, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
Not sure how to take the swivel base off for wall mounting on a 42lb1dra
If you look at the back of your TV, locate four big screw/bolts. Its the biggest screws/bolts you'll ever find at the back. 2 each side that holds the unit to its swivel base. roughly 12" from the left edge and 12" also from the right edge. remove all this four (4) screws/bolts then ask someone to help you lift from the base.
Dec 07, 2008 | Computers & Internet
Remove Swivel Base on 42LB1DRA
Good Luck.
Dec 30, 2007 | LG 42LC2D 42 in. LCD HDTV
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
