SOURCE: i AM GETTING AN A2 ERROR CODE
hi ill try to help the fault is in the overheat cutoff fuse its the white overheat wire fuse that wraps around the heat exchanger disconnect the plug connector between the fuse wire and the control unit ! using a multimeter check the resistance through the fuse to see if its bad !if its bad check to find the cause ie .a leakage of flue gasses on the heatexchanger also check the black rubber seals located at the top and bottom of the heat exchanger also inspect the seal around the viewing window on the heat exchanger then call tec support and report leakage areas also for fuse replacement the only number for tec support i can find is 08006423111 i do hope this helps
Posted on Dec 06, 2009
SOURCE: i have a 250SX aquastar bosch tankless hot water
The 250 MUST have the condensate line connected. EC comes from gas supply problems and CO2 levels not being adjusted. LP units require 3/4" smooth gas pipe or 1" corrugated pipe minimum size. The LP regulator needs to be turned up to about 13 inches of water column and with all the gas appliances on, measure no less than 11 inches of water column. The CO2 levels must be measured by a qualified gas technician with a calibrated (with in 6 months) CO2 analyzer.
Posted on Apr 11, 2010
SOURCE: i have a bosch aqvastar 250 sx ng error code EC
Q.
EC - Ionization failure during operation
A.
Posted on Mar 06, 2011
Jan 08, 2014 | Water Heaters
Apr 22, 2011 | Bosch Water Heaters
Mar 06, 2011 | Bosch & Tankless LP Hot Water Heater
Dec 15, 2010 | Bosch & Tankless LP Hot Water Heater
May 21, 2010 | Bosch AquaStar 2400ES-NG
Mar 20, 2010 | Bosch & Tankless LP Hot Water Heater
Jan 06, 2010 | Bosch AquaStar 2400ES-NG
Dec 05, 2009 | Bosch AquaStar 250SXO-LP-RE...
Mar 02, 2009 | Bosch AquaStar 2400ES-NG
138 people viewed this question
