I want to know if i should remove the Four Big strews at the back before i start using the machine?
Yes you should remove them.these are to hold the drum while in transit If you leave them in and start the machine it will shake the machine apart.
Posted on Nov 02, 2012
How you change horn pad at the strewing wheel
You remove the airbag first ,two screws/allen headed /torx headed screwqs on the back of the steering wheel ,this is a specialised job and dangerous so disconnect the battery first to stop the air bag from going off ,or better still take it to a mechanic
Aug 11, 2014 | 2006 Toyota Tacoma PreRunner
I have a clicking noise coming from the back of my vz strewing wheel after I installed my new clock spring
remove the wheel and recheck everything is in place and no trim,wires etc catching when steering turned
Jul 20, 2014 | Cars & Trucks
For the pgo big max 50 cc they have the gear oil on thr left back side how are you supose to fill it ? Right when it goes to thr thread on the strew. I could find this answer in manuel
the bottom big bolt is the drain bolt.
the fill hole is a bolt which you take out to fill the fluid it is labeled with oil symbol or words. this is where you fill it.
there is another bolt you need to take out approx 1 1/2 inch above the botton, it should be labeled
fill or level but sometimes no marks, note: what your looking for is a bolt that dosen't attach anything, that bolt is specifically a level gauge bolt.
okay once drained, put the bottom drain bolt back in. and start filling in the top hole
until you see oil start coming out the fill/gauge hole, once you see oil start flowing out, put the bolt in and tighten, then put the top bolt in and your done.
dispose the old gear oil at your local auto parts store.
Best Regards
Big Al
May 22, 2011 | 2011 PGO Big Max 50
There is a grinding noise during the wash and spin cycles.
hello,
the problem is from the jet strew it indicate that the jet strew need to be reset it at the back of the washer it is connected to the main drum it is commonly call propeller or roller it is the cost of the noise
because it has loss it position connected to the drum
unscrew the washer and see the propeller connected to the drum .
thank you and thanks for using fixya.
Jun 11, 2010 | Maytag MAH2400A Front Load Washer
I tried to tighten the belt with the two strews at the end of the walking belt. In the process, the metal bracket in which strew and belt was set broke. What is this part called that broke and how can I...
The part is called Rear Roller Bracket Part# 245895 you can order this form Icon Fitness @ 1-800-999-3756 It'll run about $12.00. You will have loosen the running belt, then pull off the end caps next unscrew from the top the foot rails, then unscrew and remove running deck then you will be able to replace bracket, reverse to assembly procedure. Also take off the motor shroud and check drive belt tension that maybe the cause of the belt slipping, so you do not over tighten the running belt.
Mar 18, 2010 | Icon Image 17.5 S Treadmill
I wouold like to know where the filter is on the Hotpoint Aquariaus WF100
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Mar 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Belt replacement on GE top loader WJSE4150B2WW
Your post shows a model WJSR2070B and a model WJSE4150B2WW but in this case the procedure is the same. Use a putty knife to push in the clips at the top seam of the front panel, where the front meets the top, about two inches in from each side. Tilt front panel forward and lift off bottom pegs. Loosen the four nuts holding the motor with a 3/8 inch wrench so you can push the motor back a bit. Take old belt off. Install new belt (WH1X2026), putting belt around motor pulley, part way on big pulley, then turning big pulley by hand to ride it onto the big pulley. Use one hand to pull motor toward you to put a little tension on the belt as you tighten the four nuts under the motor.
Nov 30, 2008 | GE WJSR2070B Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
