Washing machine error code h6
When i put a laod into the washing machine it will begin to wash then it will stop and bleep showing a h6 code i have no idea what this means,please could someone help me solve this problem as im losing the will to live!!!! PLEASE HELP ARRRGGGHHHHH!!
  • onthethejob1
    onthethejob1 May 11, 2010
    we need a model number,,,what kind of washer is it...
Iv looked at the back of my masher and there seems to be no connectors dislodged and that needs reattached. What is a spade connector exactly? Thanks
Posted on Nov 09, 2012
  • 679 Answers
seems a spade connector had dislodged itself from the back of the machine reattached and all works seems it was a heat problem.
Hope this helps
please give me a FixYa rating if the solution works.
Thanks
Posted on Jan 04, 2009
Fault code h6
Hi my washing machine ( a swan sw3010b ) keep draining the water and after a while it shows a foult IE. Can someone helps please
Nov 14, 2011 | Washing Machines
Error code h6
hi friend
hi think ur proggremed chip has been damged so u have to chage it or a timer ckt has a probelm so chenge it
Apr 05, 2008 | Daewoo DW500M Top Load Washer
My machine keeps bleeping to tell me the cycle is finished but will not begin another programme ?
1. Set the cycle knob to any "X" (reset) position
2. Press and hold the Pre-wash and the Start buttons at the same time. While still holding these buttons, turn the unit on by pressing the On/Off button
3. Keep holding the Pre-wash and the Start buttons until the digital display comes on (about 5 seconds)
The digital display will show 00 for no faults or will show a fault code.
To end the test program turn the washer off at any time
Let me know what error codes come up, if any.
Nov 25, 2010 | Bosch Washing Machines
My Zanussi zwf1650w comes up with a message draining 0 0 after about 30 seconds of starting a wash cycle. The machine the stops and bleeps saying cycle ended, is there a solution to fix this?
zanussi zwf1650w washing machine. when starting any program after a few seconds machines stops and shows draining 0.0. have done diagnosis test and shows fault E91 & E48 fault codes also shows E34 code. any help much appreciated.
Nov 05, 2010 | Zanussi ZWF1650W Front Load Washer
Washing machine - efo error display. machine stops. bleeping sound
The code EFO shown to the user can either be related to a blockage in the filter or pump.Also check the outlet drain hose for kinks or blockages.Another one to check out is that there is not too much detergent in the drum as this causes overfoaming.
Hope this was helpful.
Aug 04, 2010 | AEG Washing Machines
My kenmore elite washer just stop working. My mom
When activated all the buttons will be disabled and a child will not be able to alter any wash programme or option settings. Once selected this feature remains activated, even when the machine is ‘off’.
To use this feature press the ‘Child Lock’ button and hold down for 2 seconds. The child safe icon will begin to flash. When the icon stops flashing the feature is activated. If any of the control buttons are pressed, the child safe icon will flash and the machine will bleep 3 times: no alterations to the control settings will be allowed. If power is interrupted, at any time, pressing any button will reactivate the child lock feature.
To deactivate this feature hold the ‘Child Lock’ button down for 4 seconds. You will then hear a bleep and the child safe icon will go out.
If this is not the problem than turn off the AC power for 30 mintes and then power the machine back on an everything should be OK to use as long as no Error Codes are displayed.
Nov 13, 2009 | Kenmore Elite 45986 Front Load Washer
DWD1210S/1210W
H6 is an error code with the heater - you will need to get a professional to look at it.
We have one of the machines and it has been trouble since day one. We will not be getting another.
Aug 17, 2008 | Washing Machines
Error code e30
This error relates to the motor drive. Plug off the wall, open up behind, look for broken belt. If the belt is good its the motor brushes. Secure connections to the motor, look for loose wires.....
& pl rate if helped...............
Dec 04, 2007 | Zanussi FJS1225W Front Load Washer
Washing machine fault
im having the problem now with my daewoo that every time i put a wash on its giving me a H6 message error
Nov 09, 2007 | Washing Machines
Washing Machines Logo
388 people viewed this question
Top Washing Machines Experts
