I have a WD1457RD LG front loader and i am trying to clear an AE code.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
It indicates a leak has activated the flood protection device in the base. Lean the machine forward (or backward) & see if water runs out of the base. If it does you may be able to restart...but the source of the leak will need to be identified & fixed. I think it would be wise to remove the lid & check if the inlet valve has popped first.
Posted on Nov 02, 2012
    New Friend:
Our LG washing machine had an AE error because we put in too much washing powder and water overflowed. We unscrewed the back panel and soaked up the water on the bottom of the machine with a dry cloth. Cloth has to be wrung and soaked a few times to get rid of all the water in the machine. Really easy considering we arent the most handy people. Lesson to learn is to use front loader washing detergent and not to overdo the amount of detergent. Hope this helps.
Posted on Jul 18, 2013
  • HandyMan Jul 18, 2013
4 Suggested Answers
melnavz
  • 1226 Answers
SOURCE: I have a LG front
Hello!
Please try unplug it in the wall outlet and wait for a while and then plugin ans switch on the washer. if not work then try to refer to the manual how to reset the setting of the washer.
melnavz
Posted on Mar 05, 2008
DirtyOldGit
  • 5 Answers
SOURCE: what is the AE error code on LG steam direct drive washing machin
the AE code means that there is water in the base I found that the steam heater element in mine was leaking so after a quick repair using silicon and a good clean after drying the water out of the base it now works again
PS I used to be a washing machine repair engineer! I wouldn't suggest that you start opening up your washing machine!!!!
Posted on Mar 31, 2010
  • 343 Answers
SOURCE: i have an LG front loader washing machine...it kee...
OE is drain error..Most likely problem is partially blocked pump filter...This is accessed via the small door at floor level...Unscrew the pump cover and clear the filter..Any water in the machine will flow from the pump cover...Empty the machine first...Leaning it back can help....Good luck....Nomess
Posted on May 20, 2010
My dishwasher error code is AE what does it mean? I have tried to reset it but it still says that
If this is a LG dishwasher ... then the AE code means there is a leak somewhere underneath. On some models there is a small catch pan underneath that over time may accumulate some water which trips a sensor in the catch pan ... resulting in the AE code.
If that is your problem ... then resetting will not solve the problem since the water has not gone away. You need to take the front toe plate off and remove the water from the catch pan ... usually a paper towel can which it up as shown in the attached link.
AE Error LG Dishwasher LDF5545
You should also check all connections for leaks since over time the catch pan may fill again. Use a dry paper towel and touch all the connections ... if it becomes damp then you have a leak. (It is hard to just visually inspect for leaks)
Helpful?
Good luck on your troubleshooting!
Mar 03, 2018 | Dishwashers
Model Wt-h550. What does fault code AE indicate?
This error AE normally indcates a water leak,try tilting machine backwards or forwards 2 see if any water comes out from base of machine
Dec 22, 2015 | LG Washing Machines
LG washer WD1457RD looses time or jumps down a minut or so during cycle then stops before finish. What could be wrong ?
This is related to fault on the board, it can be the processor or the memory , check for moisture or faulty connectors from the board.
You can reset all connections and try to dry the board before the board can be suspected.
Feb 07, 2013 | LG Washing Machines
How do you clear the le error code on a front loader so it will run?
Hi Wendy just read your posting.Unfortunately LE means the Hall sensor on your motor or motor is faulty. To clear the error code you need to either change the Hall sensor or motor.Most of the time the fault is the Hall sensor.Please reply for further help.Looking forward to your reply.
May 24, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washer dryer 8 - 4kg code WD-1457-RD It has come up with AE half way through a wash -- how do i fix it?? Thanks Kate
Did u figure out an answer to this Kate? this as just happened to ours and can't work out what it means! Aaron
Dec 22, 2010 | LG WD-12124RD Front Load Washer
I have an lg front loader washing machine...it keeps stopping mid cycle and gives a troubleshoot code of oe...i cant find my owners manual and the lg site is awful....can you help me?
May 14, 2010 | Washing Machines
New LG Washer Dryer
Are you sure it's says AE for the error code.  LG doesn't list that particular error code.  Please check again.
Apr 19, 2008 | LG WM-2277HW Front Load Washer
LG Front Loader WD-8074FHB
sometimes you just have to force the door but first try hitting the machine near the door lock sometimes this helps the door interlock may be stuck in the closed position
Mar 02, 2008 | LG WM1812C Front Load Washer
Washing Machines Logo
866 people viewed this question
Top Washing Machines Experts
