WD 1457RD How do you clear the AE code - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
It indicates a leak has activated the flood protection device in the base. Lean the machine forward (or backward) & see if water runs out of the base. If it does you may be able to restart...but the source of the leak will need to be identified & fixed. I think it would be wise to remove the lid & check if the inlet valve has popped first.
Keep me posted.
Posted on Nov 02, 2012
Testimonial: "I replaced the cold water inlet"
What dose it mean AE6 error code in Samsung wash machine
SAMSUNG WASHER FAULT CODES: AE or AE6
SAMSUNG WASHER ERROR DEFINITION = communication errors sub and main PBAs - main and inverter PBAs
AE and AE6 represent communication errors between the sub and main PBAs or the main and inverter PBAs.
HOW TO REPAIR/CLEAR ERROR?: If either of these errors is displayed, troubleshooting is needed or service is required.
http://removeandreplace.com/2016/06/15/samsung-washer-quick-troubleshooting-guide-error-code-definitions/
Feb 17, 2017 | Samsung Washing Machines
I have an LG WD-1457RD washer and dryer and it shrinks all of my clothes, Possibly Temperature problem?
Very few driers have temperature controls. The best way to stop this happening is to run it for less time. Take the clothes out when they are still very slightly damp. If you hang them up straight away, you will find that most wont need ironing. Some dryers allow you to set the amount of moisture in the clothes when they shutoff, but they generally are the most expensive ones.
May 16, 2016 | LG Washing Machines
How do i clear code AE after leak is fixed?
Kindly remove all water from the bottom plate..you can do it while machine is lying down or angle..all the water will go out..
Oct 17, 2014 | LG Washing Machines
LG WD 1457RD washer dryer will no spin stops on 14 with OE alarm have cleaned filter etc still not working
pull out plug
check the pipe from the drum to the pump it may be blocked??
or your pump needs to be looked at
Dec 14, 2013 | Washing Machines
Recalling memory page just continues to feed; tried the code F thing, did not work
Go to NADIST.COM click on current models a manual is there It will tell how to clear the memory.
DickyO
Oct 17, 2011 | Nakajima AE-830 Typewriter
Washer dryer 8 - 4kg code WD-1457-RD It has come up with AE half way through a wash -- how do i fix it?? Thanks Kate
Did u figure out an answer to this Kate? this as just happened to ours and can't work out what it means! Aaron
Dec 22, 2010 | LG WD-12124RD Front Load Washer
Clear All Memory Files
exit "store" mode (if it is in it)
clear display
hold down the Code key and hit the C key
message should come up "CLEAR ALL FILES Y/N?"
hit Y, message should say "ARE YOU SURE Y/N?"
press y again to clear all files
to cancel the memory all clear function, press the N key at the first or secound prompt
Nov 13, 2008 | Nakajima AE-740 Typewriter
Nakajima AE 740
Tab to the one you want to clear then press the tab clear button
Oct 05, 2007 | Nakajima AE-830 Typewriter
Margin clearing and resetting
You cannot "clear" the margins. You have a left margin and right margin. They MUST be set somewhere even if they are set at the extreme left and right of the carriage. This part is IMPORTANT!!! Some functions (like right margin or margin release) may be written in a different color or shade. If they are, you must hold down the CODE or FUNCTION key while touching that function. In any case, the CODE key or similar will be the same color as the function you are trying to access. Get the printer where you want the margin to be. If you want the left margin set to the left of the current margin you will have use the MARGIN RELEASE key first. This may be labeled MREL or MAR REL or something similar. Backspace to where you want the margin to be then press the LMAR or LEFT MARGIN key. That will set the left margin at that point. Repeat the process for the right margin. Hope that helps Ed
May 26, 2007 | Nakajima AE-830 Typewriter
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
