Question about Bionaire BWM2600-UC Humidifier
What works best in removing Calcium deposits (I believe)? I've got the BWM2600 filterless and this deposit has hardened on the inside and seems to be slowing down or preventing the vapor from coming through altogether. thx.
  • 114 Answers
One thign that you can do is get a solution for any hardware store or any store that sells humidifiers. then you would take 1 cap full of the solutions per gallon of water. and let it run through your unit.. or if you don't want to do that. what you can do is rinse the tank portion out with bleach and rinse really well. get a soft toothbrush and lightly brush off the build up off the coils. if that doesn't work please let me know and i'll see what else i can do.
Posted on Aug 29, 2009
Everything is alright except that no ultrasonic wave coming out
Is the little ultrasonic disk clean, or is there hard scale on it? If there are hardened deposits on the disk they will stop it from vibrating. Be careful not to damage it by scraping or digging with a tool. I have found that the best way to clean it is with a Waterpik, turned all the way up. It often takes ten minutes of work to clear it off. This is MESSY, do it in the shower, or outside.
Mar 03, 2017 | Humidifiers
I have an Ultrasonic Visible Mist Humidifier, Model SUL 495. The fan runs, but no mist. I have cleaned it with bleach, as directed in manual. Any help for it? Thanks.
Feb 25, 2017 | Humidifiers
It runs but does not put out any mist.
You didn't specify the brand or model, but for generic advice, try using a strong solution of white vinegar and water and soak overnight or for several days (if very scaled up).
If you were using hard water in the humidifier, try using a commercial humidifier cleaner such as BestAir products (or similar - there are many to choose from): Amazon com BestAir 3US 6 UltraTreat Ultrasonic Vaporizer Water Scale...
(Make certain it's certified for steam and/or ultrasonic use, if your using that type of humidifier).
Follow directions on box. You will have to let soak for a period of time (hours/days) to allow chemicals to do their thing.
If you are using "soft" conditioned water, just refill with soft water and allow to sit for several hours, then discard and refill. The hardened minerals will re-disolve and will be removed when you flush the unit. For hardened minerals clinging to the sides, etc, just use your fingers to break up, possibly a brush or Dolby pad and break them loose.
(Soft water has just as much minerals as hard water, but in hard water there are mostly calcium based and turn rock hard and in soft water they are sodium based (sodium bicarbonate actually) and have a weak structure).
It's important to keep a humidifier clean of deposits, not just to keep the unit running, but to avoid air quality problems (bacteria will cling to scale buildup, which make excellent breeding grounds for them).
If you use "hard" tap water, clean (at a minimum) once a week. Use white vinegar and water - 50/50 mix. If your using "soft" conditioned water, clean once a month. Same with distilled water.
You could also consider using a small amount of bactericide in the water to prevent bacteria from growing. (Okay for filter type humidifiers, but DO NOT use in ultrasonic or vaporizer type humidifiers). 1/4 cap full should suffice. BestAir 3BT 6 Original BT Humidifier Bacteriostatic Water Treatment 32 oz
Jan 03, 2016 | Humidifiers
How do you remove calcium deposits?
A weak vinegar/water solution should remove calcium deposits. I either used purified water or I add a tiny bit of vinegar to the water when I use the humidifier to help prevent calcium deposits from forming.
The mix of vinegar to water is up to you, but as a guideline, if you're smelling a strong odor of vinegar, then it is likely that your solution is too strong - try adding some water to it. Rinse with clear water afterwards.
Apr 14, 2015 | Humidifiers
When we run the humidifier the waterlevel does not change.
The humidifier and it's tubing may be clogged with calcium deposits and scale. Especially so, if you're using well water or your city's water has high calcium deposits.
Empty whatever water is in the unit and refill it with a 50/50 solution of White Vinegar and Bottled Distilled Water. Allow it to sit for 30 minutes and then turn the unit ON. Once you feel moisture coming out, allow it to run anoter 10 minutes or so. Then turn the unit OFF and empty the remaining solution (if any is left). Now, flush the system by filling it with Bottled Distilled Water and running it.
For future use, I'd recommend that you use nothing but, Bottled Distilled Water.
Apr 07, 2011 | Vicks V3100 1.2 Gallon Humidifier
Looks like calcium deposits, need operational manual
Sorry to read about your problem, I hope this helps you out.
try running 50/50 water and white vinegar... then put back fresh water
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Honeywell HVM2030 Humidifier
I only used my machine for just about two weeks (only in the evenings)with a brand new filter and already the top of the filter has turned yellow/brown and brittle. Is it normal to go through a filter so...
how long the filter will last depends on your water .. if your water has a high mineral content then that is left behind as the water evaporates from the filter/wick ... the yellow brown sounds like calcium deposits .. calcium is often added to water to give it a good taste .. that may be beneficial for you but will build up on the filter .. it doesn't hurt much until it starts to clog the voids in the filter material .. as long as air gets thru then the deposits will be ok .. normally the filter should last about 3 months .. if you use distilled water (with no calcium added) then much longer .. if you have hard water then less .. there is a tablet that you can add to the water to reduce the calcium buildup .. the manufacturer of your humidifier will likely recommend that .. thats often available from hardware stores also ..
so your choices are:
1. don't worry about it until the filter becomes clogged
2. use the anti calcium tablet or something like ProTec PC-1 Humidifier Tank Cleaning Cartridge
3. use distilled water for really long filter life
4. plan on replacing the filter every 3 months
other types of humidifiers have other problems .. the hot water type gets calcium deposits on the heating element requiring cleaning a couple times a year, usually with vinegar or a calcium solvent .. that takes awhile..
the Ultrasonic type doesn't generally have problems with internal deposits because it blows moist air out including the calcium .. that produces a fine dust on surfaces in your house ..
of those types the filter system like yours is easier to maintain than the hot water type and doesn't leave dust behind like the ultrasonic all work better and longer if the water is pure .. distilled water doesn't cost much but you have to be careful .. read the small print .. some of it will say "calcium added" .. you don't want that .. if you use only distilled water then the filter should last the whole year ..
Sep 26, 2010 | Vicks Cool Mist V3500 Humidifier
Stop putting out the vipors
run some CLR trhough it its just plugged up with calcium deposits from the water put about a quart of CLR in it let set for about a hour then run it through
Jan 21, 2010 | Humidifiers
How to clean calcium deposits from the filter
keep it in a dry for some time and then use some old tooth brush or small paint brush to clean it then rinse it with water and dry it .........
Jan 03, 2010 | Aprilaire 600 Humidifier
Hm495tg
possibly calcium or other deposits from the type of water you are using in the unit..........
Feb 03, 2008 | Holmes Products Holmes 3 Gallon Cool Mist...
Bionaire BWM2600-UC Humidifier Logo
258 people viewed this question
Top Bionaire Humidifiers Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a Bionaire Humidifier Expert? Answer questions, earn points and help others
