Wma32 i havforgot were the conections go on the program unit
Here is the manual for that unit.
SOURCE: Hotpoint WMA32 Front Load... Problem:
if its not your belt its the brushes in the motor that need replaced i would replace the brushes first the cost about £15-20
SOURCE: my hotpoint wma32 wont empty
Chances are you have a lid switch problem or the most likely cause could be a drain pump obstruction.You could use a wet dry vacuum and connect it to the drain hose in the back of the washer to empty the water.Once the water is empty remove the hoses that are connected to the drain pump and feel for the obstruction in the pump.If nothing in the pump,it would be the lid switch.
SOURCE: hotpoint washing machine WMA32....how can you spin
turn the machine off, turn the selector switch to spin, turn the machine on and press start
SOURCE: does my hotpoint wma32 washing
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
