Question about Samsung Galaxy S I9000 (8 GB) Cell Phone
Samsung galaxy s not charging - Samsung Galaxy S I9000 (8 GB) Cell Phone
  • 580 Answers
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Posted on Nov 04, 2012
How can I repair charging point on Samsung ce0168?
Samsung CE 0168 cell phone: repair charging port:
The simplest way to repair it is to take it to a local cell phone repair shop and let them do it for about $35 to $50. I would determine first if that is worth the phone to do so.. If not, it may be more economical for you to just buy another phone.
Parts for this particular device are not easily found. And, you can't just call up Samsung Customer Support and say you need this part. Parts are usually sold through 3rd party cell phone repair centers only.
The schematics for this device are not readily available and there are no known repair videos online for you to follow.
Jan 11, 2016 | Samsung Cell Phones
How to screenshot
How do I take screenshots on my Samsung Galaxy Avant ™ ?
www.samsung.com > ... > Cell Phones > T-Mobile
Samsung Electronics... of the screen. The screenshot will be copied to the clipboard and saved to the Screenshots folder in the Gallery. ... Print: Print the screenshot to an available printer via a wireless network, Wi-Fi Direct, or USB cable. Settings: ... Cell Phones.
How to take a screenshot on Samsung Galaxy - PC Advisor
www.pcadvisor.co.uk > ... > How to take a screenshot on Samsung Galaxy
May 15, 2015 - Taking a screenshot on a Samsung Galaxy smartphone is a simple task, but it's a ... Whether you've got a Samsung Galaxy S3, Samsung Galaxy S4 orSamsung ... How to take a screenshot on Samsung Galaxy. PC Advisor · Phones ....Once my Galaxy S3 get fully charged on wireless charging pad , I will ...
How to take a screenshot on Android phones, tablets - PC ...
www.pcadvisor.co.uk/.../how-take-screenshot-on-android-phones-tablets...
Aug 20, 2015 - In the early days of Android taking a screenshot on a phone or tablet ... on an Android smartphone or tablet, including the Samsung Galaxy S6, ...
Dec 21, 2015 | Samsung Cell Phones
My Samsung s5 is not charging their is nothing wrong with my charger
check this
1. First of all make sure that you are using an approved wall charger of Samsung Company. Because charging accessories of other brands may have different voltage parameters and may cause Samsung Galaxy S5 not charging issue.
2. Plugged in your Samsung Galaxy S5 with an original Samsung Mobile charger, but do not turn on your phone. Sometimes it may take little longer to charge the phone. After you phone starts charging, a charging icon should appear on screen. But if you see nothing is appearing on screen, then Samsung Galaxy S5 not charging issue is occurring either for damaged charging cable or there is some problem on your phone such as the charging port is damaged or bent, or the charging contacts on your phone is not cleaned.
3. To check the charger, charge another Samsung phone using the same charger and see if it is charging. If the other phone is charging well, then the charger is fine. Now you should check your phone.
3. Check the charging port on your Galaxy S5. To check the charging port, take a light, magnifying glass and a pointed wooden toothpick. Then see if the charging port is in the center and not bent. If you find the port is bent, then straight it using the wooden toothpick carefully.
3. Also verify the charging contacts are clean. Sometimes dirt gets stored into the charging port and occurs Samsung Galaxy S5 not charging issue. So Insert a small needle in the charging port and clean carefully so that the port does not get bent or damaged.
4 Download Galaxy Charging Current, to see if your phone is charging at it's maximum potential
How to fix Samsung Galaxy S5 not charging issue
Summary
  • Try a different charger with Samsung mobile origin.
  • Try a different USB Cable and charge by Kies.
  • Try charging it off via PC/Laptop.
  • Try removing the battery for 3 minutes, let it cool down and then charging again.
  • Blow inside the USB port and fix the contacts if it's bent.
  • Reboot your phone several times.
  • Download the battery charging electrical current app to monitor charging
(Note:Samsung Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
goodluck
Jul 04, 2014 | Cell Phones
Why will my samsung galaxy s4 not connect to the charger - the socket seems to have dropped
REASONS OF SAMSUNG GALAXY S4 NOT CHARGING- GREY BATTERY PROBLEM
The main reason of Samsung Galaxy S4 not charging- grey battery problem is a shorted charging port. There may be several reasons for it such as sometimes dust entered into the charging port and causes this problem. Sometimes the bar across the center of the charging port gets bent.
SOLUTIONS TO FIX SAMSUNG GALAXY S4 NOT CHARGING- GREY BATTERY PROBLEM
Method 1
If your Galaxy S4 falls and you start to face Samsung Galaxy S4 not charging- grey battery problem, then take a pointed wooden toothpick, a magnifying glass and a strong light and see carefully if any bar across the center of the charging port is in the center and not bent to touch one of the sides of the shell. If you find that it is bent then straight it using the toothpick point carefully.
Method 2
Look for the dirt into the charging port that it may pick up from anywhere. Take a thin needle and gently insert it in the charging port to take out the large piece of dirt from it. But you have to be very careful so that you do not make any damages of the charging port. You can do this by using a can of compressed air or dust/hair blower that will blow out the small dust particles from your phone's charging port.
Method 3
Some users reported that they have found solution of the Samsung Galaxy S4 not charging- grey battery problem by taking out the battery from the phone , insert it into another Samsung Galaxy S4 ,and then again put it in back.
So follow these steps to get rid of Samsung Galaxy S4 not charging- grey battery issue.
Apr 25, 2014 | Samsung Cell Phones
Samsung galaxy tab 2 10.1 brought today and charging through computer keeps flashing a battery but then disappearing and making a disconnected sound from computer what do i do?
Samsung galaxy is a powerful device which require at least a 2A charger to charge it well. computer can only deliver 0.5A and thus is not enough power to charge your tablet. Connect it to the wall AC charger that come with the tablet and you'll be able to charge it just fine
Sep 16, 2013 | Samsung Galaxy Tab 2
Samsung galaxy Y pink wont charge
i tHink iNnn yOur cEll pHone cHarging piNn iZzz dEstroyed !!....!! rEpair yOur cEll pHone tHen iTz wOrking !!....!!
Apr 07, 2013 | Samsung Galaxy Y Gt-s5360 Pink Factory...
Samsung Galaxy S I9000 (8 GB) Cell Phone Logo
420 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
