Question about Water Heaters
I dont know what the problem is so I need a bit of advice. I live in a 3 block council flat and have been here for 2 years. I have NEVER once been able to take a shower as everytime I lift the shower head above a certain height (above hips!) It stops! I have to bathe traditonal way and use a bucket or just have a bath. At time the hot water stops working and when someone from the council comes the check the boiler... for god knows what... sort out pressure or some sort. they mentioned I wont be able to shower because the pressure isnt high enough and it will stay like that. Is this true... how is that possible! I pay full rent, I'm entitled to a shower right lol. Can anyone tell me what I have to do to fix this and be able to have a shower whenever I want, pleaseee?
  • saima_wyma Jan 05, 2009
    Thanks I am going to give them a call at 09:30 when they should open. I will mention the pump - actually I will read this to them lol :) & I wish I was in Rhode Island then, but all the way in London, UK so have to rely on the crappy council of my borough, but thanks alot for your advice :)
  • 56 Answers
Wow , i've been a plumber for fifteen years never heard on like that before, but it should be pretty simple tell them to add a pump to the hot water systeme a taco 007 to be exact if you where in rhode island i could fix that for you. when you add a pump you must turn the mixing valve up hotter a little to build enuff pressure. hope it works out.
Posted on Jan 05, 2009
Can the 3 way gas tap be replaced with two independent cut off valves by a GAS Safe installer?
sorry that is something you need to check with the gas company about .
Dec 01, 2016 | Water Heaters
I have a Reliance 501 electric water heater ... Everything works great but below the water out. Be rusty? How can I fix it?
The tank is rusting. Replace anode rod or replace water heater.
Once the anode rod depletes, then the tank starts to rust.
IF you can replace the anode rod, it will stop rusting, and then flush the rust out of water heater.
This might buy more life with same tank, but old anode rods are pretty solid and even impact wrench might not loosen it up.
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flush
Loosen anode rod on new tank before installing, and then inspect every 1-3 years, and 1-2 years if water is softened.
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 08, 2011 | RELIANCE ELECTRIC WATER HEATER
I have a Bosch 10P water heater. Pilot light has blown out and while trying to relight the pilot the stop button has been pushed down and won't pop back out. What am i doing wrong? Cheers
What leads you to suspect that pilot blew out instead of another problem?
Fact that pilot will not relight, indicates other factors at play.
Open following link for Bosch troubleshooting resources including manual, and Bosch contact info:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Best place to start is your manual.
http://waterheatertimer.org/pdf/Bosch_10P-installation.pdf
1) Manual recommends 'cleaning by authorized person, never less than once a year.'
Tankless water heaters, and most newer tank-type gas water heaters, are highly technical and finicky devices that require continual maintenance, with tankless requiring 'yearly' maintenance while tank-type require 'periodic' maintenance.
2) Troubleshoot in manual says 'no gas supply' or 'blocked pilot' replace pilot injector
Upvote the help.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
May 21, 2011 | Bosch & Tankless LP Hot Water Heater
I have a PowerStar model #44-557701 tankless hot water heater. When you turn on the hot water it starts to heat and then it just shuts off. My dad thinks it might have something to do with the flow sensor....
Open following link for Bosch tankless troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
Feb 13, 2011 | Bosch & Tankless LP Hot Water Heater
Our Bosch 2400E NG tankless water heater is displaying the EC code. I've checked the ionization electrode (rubbed it with a pencil eraser as instructed once before when we had this problem) and I also made...
Had same problem on my five year old water heater (ec error). Didn't figure it was a gas supply problem after five years but double checked to see if the gas bill was paid. It was.
Cleaned the contacts on the two sensors that are clamped to copper pipes inside. Still had error after powering up. Held the error button in for about five seconds, and the blinking EC code went away.
May 21, 2010 | Bosch AquaStar 2400ES-NG
No hot water
pilot may be blocked therm/coupling may need replaced
Oct 09, 2009 | Bosch Water Heaters
Hot Water Heater in 1991 Pace Arrow RV is not working
If you look on the outside of the RV, you will find the vent for the water heater behind and access door. There usually is a drain plug and valve located as well. Generally they will be tucked away under the kitchen sink area with internal access as well. You will need to find where the valve that shuts the water off to the unit is and turn it on. Most times the water heater is either electric or propane. But sometimes they are only propane. Once your find the access door, you will know where the water heater is. You can also contact Fleetwood who makes the Pace Arrow to see if they have any information on your unit. Usually your unit info or trim number will be located on a little plaque right by the entrance to the RV. You will need this when you contact them. Hope this helps.
Mar 31, 2009 | Water Heaters
Hot water
there are two main faults with combi boilers not giving hot water. one is a faulty flow sensor, the other is the most common which is a blocked heat exchanger caused by debris and scale in the system. this needs to be flushed out or may require a new heat exchanger depending on the age and condition of the boiler some plumbers may suggest a new boiler.
Mar 02, 2009 | Water Heaters
Ground floor flat with vented cylinder.
clean the screen off on the hot side of the heater or the cold side depending on the unit on the shut offs there are cap screws and if you shut the water off and remove the cap screw there are filters inside take them out and clean them
Jan 07, 2009 | Water Heaters
Water Heaters Logo
93 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
