How to replace the v-belt of Samsung washing machine wa90g9?
2 Suggested Answers
IFIXALL
  • 868 Answers
SOURCE: How to replace the belt on a Samsung J845 front loader washing machine
Its on the back of machine and after you remove the back cover plate youll see that its very easy to install the new one.You shouldnt have to use any tools to put on the new belt.Just loop it around the motor pulley and around the large tub pulley that you see right in front of you.It may even appear to be too tight while your winding it on the pulleys but its not .
Posted on May 20, 2008
My washing machine model WA90G9 leaks water as soon as the water pass the lowest water mark
Get the machine out but leave it attached to the water and power. Switch off at the wall, remove the rear access panel and then operate the machine while looking in the back with a torch /flashlight. DO NOT put your hands or anything else into the machine. Operate the fill cycle and I'm pretty sure you will see the source of the leak. If its a hose / pump / etc, get the machine details off the sticker on the back and call a domestic appliance shop or go online. Most good online shops have exploded views of the parts and a good DIY fixer should be able to identify the part. If it leaks when it reaches the half way level up the drum it could be the drum bearing / seal assembly, in which case its much more complicated and you will need knowledgeable help. There may be no rear panel in which case the top lid will need to be removed. Usually by a couple of screws on the rear edge. If you don't know what to do get help. Water and electricity don't mix.
Sep 27, 2016 | Washing Machines
How do I fix/diagnose my washing machine, The belt keeps slipping off?
if the drive belt is v section the reason for coming off will be pulley misalignment
easy to check with a straight edge
check that the belt fits in the pulley so that the top of the belt is level with the pulley edge
Jul 21, 2016 | Samsung Ecobubble WF80F7E6U6X Silver 600...
No spin motor moves top loaded samsung washing mechine
You may need something as simple as a belt if its a belt drive machine...Hope this helps Shannon
Mar 07, 2012 | Washing Machines
Replace belt j845 samsung front loader washing machine. how do i get replacement belt on as back and both sides of machine is one piece of metal
There is no belt on a front loader washing machine. The way the drum spins is by a stator in the back of the unit.
Dec 29, 2009 | Samsung WF337AA Front Load Washer
My washing machine wont spin or move. It goes thru the whole cycle with no error message. Samsung J845
All fixed - it was the belt that needed replacing
YAY no need to buy a new one
Aug 20, 2009 | Samsung Washing Machines
Spin cycle wont work and error code 8E comes on display on Samsung Q1235S
It doesn't pump or spinIf it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • Aug 05, 2008 | Samsung Washing Machines
    Washing machine wont spin
    Jul 13, 2008 | Samsung Washing Machines
    May 20, 2008 | Washing Machines
    How to replace the belt on a Samsung J845 frnt loader washing machine
    If you stand in FRONT of the washer, leaning over the top, the drive wheel is underneath the main drive motor, on the RIGHT hand side.  Loop the belt over the drive motor wheel, then over the main pully, and it should be good to go!
    May 20, 2008 | Samsung WF337AA Front Load Washer
    Washing Machines Logo
    24 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
