Question about Nokia N95 Cellular Phone
Failed update with nokia updater
I have just updated my nokia n95 and it failed now all i get is a black screen with nokia on it
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 78 Answers
Your update must have failed , now you have to do a hard reset of your phone , you cannot do the normal #*7670# , so use the following
Press and hold Green ( call send button )
Also press the * ( the Star Key )
and number 3 and keep them held and power on your phone and keep the button pressed until Nokia screen comes on .
If this solution help please do vote for me
Posted on Jan 04, 2009
Nokia 95 8gb i bought an iphone 5 months ago and so i stoped using my nokia n95 8gb now my ipnohe is broke and i cant remmebr the unlock code for the nokia n95 8gb please can you give me the master code...
hi
just try this
1) Downlaod the nokia Sowtware Updater and PC Suite
2) connect your phone useing cable
3) Update your software using nokia Software updater
it will reset all settings and passwords to defaults
MAke sure abour your date
Link For Nokia Software Updater
http://www.nokia.co.in/support/product_support/phone-software-update
May 27, 2011 | Nokia N95 Cellular Phone
Won't boot. Get following message:"Phone start-up failed. Contact retailer."
Your phones software or may be firm ware is deleted you should reinstall it.Do following:
  1. Connect your cell to your PC with DATA cable.
  2. If you do not have NOKIA PC suite then you must download it first. CLICK TO DOWNLOAD PC SUITE FOR NOKIA N95.
  3. Update your phones software.
  4. Backing up device data
    Before updating, remember to backup your device's memory on a memory card or Nokia PC Suite.
    To backup data to a memory card:
    • Select Tools > Memory from the main menu
    • Select Options > Backup phone mem.
    To restore the data after updating:
    • Select Options > Restore from card
Click here to DOWNLOAD N95 SOFTWARE!!!
Thank You!And good luck!!!
Dec 06, 2009 | Nokia N95 Cellular Phone
My N95 kept rebooting itself so i looked around on the net and found that i need to install new firmware. I downloaded nokia software updater and it starting downloading the upgrade. However about 14mins...
You should try to install NOKIA SOFTWARE UPDATE to ur phone to install the new firmware .It is just software problem not any big to worry.You can go to any nokia center to reinstall the firmware and got ur phone A1.
Dec 05, 2009 | Nokia N95 Cellular Phone
N95 turns on but screen stays black and unable to use
  • First you should update your phone using NOKIA SOFTWARE UPDATER
  • if Lcd is still blank,repace your LCD by a new one
Nov 23, 2009 | Nokia N95 Cellular Phone
My screen is upside down N95
Try a firmware (software) update, you can download the NOKIA Software Updater from the NOKIA web site.Do the update even if it is the same SW version that is already on your fone
MAKE SURE YOU BACK UP YOUR DATA 1ST, EITHER WITH THE NOKIA PC SUITE OR ONTO YOUR MEMORY CARD
Dec 27, 2008 | Nokia N95 Cellular Phone
N95 Cant update my phone software
Please let me know what do you mean by update fails.. Does it show any error messages? Please let me know so that I can see you through this.
Thanks,
Sai.
Nov 03, 2008 | Nokia N95 Cellular Phone
N95 can not power on
Interrupting a firmware update is a major problem depending on how much information was transferred. If the phone is no longer recognized by your PC and you cannot try another update the only recourse may be to send it to Nokia for service.
Oct 12, 2008 | Nokia N95 Cellular Phone
N95 startup problem
do not consult a technicition i have had this problem and solved it for my friend, you were trying to update your n95 firmware using nokia software updater then it said please unplug and remove battery you should never touch a mobile during an update... anyway to fix it your n95 thinks its still in a middle of the update so charge your phone for 10 minutes (DONT TURN ON) then connect up to the computer via usb to your n95 then open up software updater and press start update it it says could not find deivce keep retrying it took me 20 minutes but could last up to 1 hour then it willl recognise the phone and continue update and turn itself back on only problem is that your phone will be reset but you still keep your memory card data
post back asap dale goodwin
Jul 22, 2008 | Nokia N95 Cellular Phone
Nokia 95
Hi
Sounds like maybe the update wasn't as successful as it says it was.
Try the update again, and see if it completes.
I have an N95 and had a few problems with mine, I ended up sending mine back to Nokia for repair.
If your update wont complete, or start, get on the phone to the shop you bought it from because they'll liaise with Nokia. If you bought it elsewhere, get straight onto Nokia yourself here
Mar 30, 2008 | Nokia N95 Cellular Phone
Updating N95 Software
Make sure to update your Nokia Suite application before updating.
I recall there being an issue when updated the phone software with the steps being Backup to your PC, Update software and Restore from your PC but since the update changes some of the phones software the older Nokia Suite was no longer compatible and came back with an error.
If you can, I also suggest running a backup to your memory card, you can never have enough backups when upgrading these phones.
Jan 25, 2008 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
