Question about Cameras
My brand new Nikon CoolPix L180 lens area is stuck in the extended position and it keeps shutting off indicating a need for the cap to be removed when it is not on
My camer keeps saying lens error
Copied from Nikon's Service & Support Page:
Having a "Lens error" message display on the camera's LCD display indicates a problem with the camera lens mechanism. This situation generally requires that the camera be sent to a Nikon Service Department for repair. Before doing this however, be sure to check these situations below:
  1. One possible reason for this error is if the camera is switched on and the lens unit is prevented from extending. The camera will struggle for a second to extend the lens, then report the problem. Inspect the lens for any obvious obstruction, then turn the camera off, then on again. Usually, simply switching the camera Off then On again is enough to correct this problem.
  2. Remove and recharge the battery. Retest.
If this does not help, then we regret the camera must be sent to our Nikon Service department as there are no user serviceable parts on Nikon Coolpix cameras.
To find your local Nikon authorized service agent Click Here.
We apologize for the inconvenience and will do everything we can to repair your Nikon camera as quickly as possible.
Aug 30, 2014 | Nikon Coolpix S2700 16 Megapixel Compact...
When i t turn on my Nikon coolpix L810 i keep getting a message to"turn off the camera, remove the lens cap and then turn back on." it seems like the lens starts to expand and then retracts as if it's...
I'm afraid that you are right about the lens being stuck.
The camera has several checks to make sure the lens can zoom freely in and out. If the camera detects there is a blockage of some kind, the lens will retract and switches of the camera to prevent more damage.
I'm afraid there is nothing you could do to fix it, other than bringing it to a repair shop and have them take a look at it.
Jan 02, 2014 | Nikon COOLPIX L810
Nikon l20 the screen froze
Take the batteries out of it let it sit for about 5 minutes and then put them back in
Oct 25, 2017 | Nikon COOLPIX L20 Digital Camera
Lens Error, Camera shuts off
This indicate that there will be some problem with your camera Lens. Try to follow these steps to resolve the issue:-
1) Switch the camera OFF and then ON again.(May be your camera lens is struggling to extend)
2) Remove and recharge / replace the battery, If the error does not clear, Keep battery battery out of the camera overnight, and try again the next day.
Else your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 01, 2010 | Nikon Coolpix L11 Digital Camera
My Nikon Coolpix L100 flashes a lens cap error
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Jan 02, 2010 | Nikon Coolpix 5700 Digital Camera
Nikon coolpix L11 Lens stuck
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Sep 28, 2009 | Nikon Coolpix L11 Digital Camera
Coolpix 4300 "system error"
Hello
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Jun 07, 2009 | Nikon Coolpix 4300 Digital Camera
Battery problem
It probably lacked the power to retract the lens. I'd start with recharging the battery and see if that corrects the problem.
Sep 19, 2005 | Nikon Coolpix 5400 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
