SOURCE: Tile Saw
i know blades on tile saws don't have to be super tight, i'm not familar with that kind of saw, i put a wrench on the nut and hold on to the blade with my hand and hit the wrench with a rubber mallet, and of course have the unit unplugged
SOURCE: pump doesn't work on tile saw I just bought. It's
What brand of saw? Ideally you should return it for a refund or replkacement. It sound like it might have been a demo saw and was sold cheap. But if it doesn't work and you have proff of purchase take it back. If it is a GE model I have a manual i can type up for you. I am in australia where is your location?
contact me on [email protected] if you need to
SOURCE: nada
According to my translation your question is:
"I would like to know the price of water for cutting ceramic tiles"
Your best bet is to figure out how much water you will require and then call the water company to inquire what the charges would be for that amount.
SOURCE: Wet tile saw just stopped cutting; I only cleaned
How thick is the diamond bearing segment running around the rim of the blade? There needs to be at least an eighth inch. The last part contains no diamonds. If their is sufficient diamond left the material you were cutting may not have been abrasive enough to expose new sharp diamods. You can cut a small piece of asphalt. This will wear the matrix down so new diamonds are exposed.
