Question about Coleman Powermate Powermate 5000W Generator
Model# 185432 0242E1 98111749
Rebuilding the pullcord assembly
Pullcord slipped back to motor how do i release it
you will have to take starter cap off to free the cord
Oct 01, 2014 | Garden
Replace pullcord on craftsman 316.350840
I know that the starter assembly for Craftsman 316.350840 [ The 316 means it was made by MTD] this saw became became no longer available. But you can use this model number 41AY80AG983 [Remington also made by MTD] and get the same part (exception being that it will be Orange, instead of Black). Part number 753-06974
http://www.searspartsdirect.com/partsdirect/part-model/Mtd-Parts/Chainsaw-Parts/Model-41AY80AG983/0736/1503220/1303082P/00002?blt=06&prst=0&shdMod=41AY80AG983
Jan 25, 2014 | Garden
Homelite ohv 140cc
Remove recoil assembly. Observe cord installation. Remove old cord. New cord is sold by the foot at mower repair shop. Replace cord, reassemble recoil assembly.
Jun 18, 2013 | Garden
How do ithread anew pullcord. i need diagrams of the correct place the string goes on the pullcord
take it to a local small power shop,its not an easy task,takes them 2 minutes
Jun 11, 2011 | Garden
Victor spitfire motor type lawnmowers pullstart. The pullstart is not working, its not the pullcord/spring return system that is the problem, it is not engaging anymore to the plywell well that it needs...
Either the pull string has un coupled or the little fingers that are part of the start assembly are not engaging the motor. If latter, you need new start assembly. Ouch.
Aug 29, 2017 | Garden
The pullcord works sometimes but usually just pulls out without any tension. Just went to try it today and this is the first time I've had this problem. The generator is about 12 years old.
the catch 'pawls' are worn and bad and need to be replaced,, or the catch 'pawls' spring is broken.
you can buy a rebuild kit for this at you local generator repair shop,, this will restore the pull function to normal.
c...
Feb 02, 2011 | Sport & Outdoor - Others
I have a ceiling fan with remote, remote will not turn fan on high, how can i fix this
The fan probably has manual pullcord switches - one for the light and the other for fan on/off/speed. The fan control pullcord needs to be at maximum setting.
Switch the fan on using the remote. Then set it to high using remote.
Now use the pullcord switch (probably cycles through off, low, medium, high, off with each pull). Set it at its fastest speed, and leave it there.
You should now be able to select highest speed from the remote.
Happy to try to help more if that does not work.
Feb 25, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Shrieking Lawnmower!! I hit small tree branch w/ walking non-drive 3.75 hp Briggs and Scrap-Iron "Sprint" off-brand gas mower. Started shrieking like banshee. Resulted in tangled pull-cord. So I removed...
sounds like you have dirt in the recoil clutch, (under the screen) or you bent something there. try removing the clutch and make sure shaft is very clean and lightly coated with oil. This would be for a briggs and stratton engine.
Jul 25, 2009 | Garden
Coleman Powermate Powermate 5000W Generator Logo
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
