Panasonic plasma TH-42PA60A screen is black and won't display the menu or picture. It still has sound though. The batteries in the remote have been checked.
The batteries in the remote are good. The plasma just went black and will not display any image, the menu won't come up on screen but the sound is of good quality.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
It will need to be checked and boards replaced to know which if any are causing this trouble--I presume it happens on all inputs including the rear ones.
Posted on Nov 02, 2012
5 Suggested Answers
  • 54 Answers
SOURCE: I am hooking up a
check your connections. it sounds ( looks ) like you may have connected the video cables incorrectly. the inputs and outputs are color coded, even if the cables you are using are not you can still use them.
Posted on Jan 24, 2009
  • 184 Answers
SOURCE: Panasonic viera Plasma TV model TH-P42X10A The tv
The power supply board of the television is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem....
Posted on Aug 01, 2011
caroldon
  • 17129 Answers
SOURCE: Plasma tv has sound but
This is a common fault solution which can be checked and corrected by you assuming that there is no component failure. There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance.
The best way to check for loose connections is to tap lightly when the set is powered on , If there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
Sometimes the fault occurs when the set warms up, if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault.
Based on the above method you must be able to locate the area of fault and solder the sections. Sometimes large IC's- ones with more pins- tend to have drying in some pins and so cause faults related to the IC's protocol. Have a rough idea of looking into the areas to reduce the time of probing.
Check for tips to look into the SMPS unit with some of my tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Thank you for using Fixya.
Posted on Aug 17, 2011
SOURCE: Panasonic plasma TH-42PA60A Having display problems. Pulling apart to clean out dust. Gone from bits of red through blacks to how it is in video now. Some times it comes good for a few seconds. Have
Try making adjustments to the VA on the power supply and adjusting voltage on the SC (Y-Sustain) board
Posted on Oct 28, 2012
Panasonic Plasma 50 TH-P50U30A blacked out with no sound
Appears to be a power supply issue with everything being so dead.
Jan 22, 2017 | Panasonic Televison & Video
The picture does not fit the screen
Resolution is set too high on the TV. On the TV remote open Menu
Go to set up
Change the screen resolution to the next one down.
Mar 27, 2014 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic Plasma - turns on, but stays blank.
Your TV probably has power supply trouble.
Jan 16, 2014 | Panasonic Televison & Video
My last question was in reguards to a panasonic th-50px 75u I have small black vertical lines all across the screen and a rainbow effect on the picture all channels and all inputs
Press the menu button on the TV remote and see if the lines are on top of the menu or covered up by the menu. If the lines are covered up by the menu, the issue is being caused by your source device.
Aug 26, 2013 | Panasonic TH-50PX75U Plasma HDTV
Pananasonic TH-42PA60A
This is a television, not a camera. If you repost this query in a forum dealing with home electronic entertainment equipment, you may stand a better chance of getting a helpful reply.
May 02, 2017 | Cameras
Panasonic Viera TH-50PZ80U no back light
There is no backlight CCFL lamps to Plasma displays, like LCD ones. If there is no screen with plasmas, the Z-Sustain board should be checked and replaced. This is actually a skilled work, and not a user repairable one, if the user is not experienced to work with plasma displays. Check this link and see whether you can do it by yourself. The link have enough details about the faults to Panasonic brand TVs.
Jan 17, 2013 | Panasonic Viera TH-50PZ80U Plasma TV
Just bought a 42" panasonic
On your remote, click menu, then setup, then external devices, then input labels. Here is a link for manual:
http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-HDTVs/model.TH-42PX80U
Dec 09, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Picture on screen is narrow and I cannot select normal view
use menue button on tv if this does not work change main board in tv
Jun 05, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Televison & Video Logo
99 people viewed this question
Top Televison & Video Experts
Electro Med Services...
