Question about Nebo Redline Tactical Flashlight Strobe S.O.S 220 Lumen 5581
Need a replacement bulb for a Redline Nebo flashlight
Forgetting that I had the light in my top shirt pocket I bent to air the tires & the light fell to the ground & hasn't worked since, just figured that the bulb had popped
    New Friend:
Hi, replacement bulbs can be found at amazon, click here and take a look: Amazon com flashlight replacement bulb. Cheers
Posted on Dec 25, 2014
    New Friend:
I believe the lights are LED so it shouldn't have "popped". They're pretty well constructed for the most part. We go through lots of these lights where I work and usually the problems end up being the battery holder or the underside of the LED piece that makes contact with the batteries.
According to their website you can contact the following for replacement parts:
warranty@nebotools.net
Posted on May 06, 2013
How to replace Battery in a #5520 Nebo flashlight
If you will take it to a Batteries Plus they will show you how and even do it for you.
Sep 17, 2017 | Nebo Camping, Backpacking & Hiking
Can I buy a battery holder or frame for my NEBO Select flashlight?? My grandson dropped mine in the lake while changing batteries.
Given the cost and availability of those lights vs the expense for the battery carrier, you should just get a new light.
Feb 20, 2016 | Nebo Redline Select 310 Lumen Flashlight...
How do I replace the led in a 2w d cell maglite
Unscrew the top half of the flash light and pull the bulb straight up, and it's out,
Not to mention there's usually a spare bulb in the base of the flashlight under the spring in a piece of foam. unless someone used it already,
Line up the two pins and slide it back into the to pin holes on top and with the bottom of the flashlight back on with battery's try the on off switch and make sure it lights up and not have dead battery's, if it lights up throw away the old led and screw on the top of flashlight,
If it still don't light check for new battery's.
Oct 03, 2014 | MagLite Mag Instrument Mag Lite 2 "D"...
I have an Xacta Mirage light, I believe it is LED. The bulb seems to be brned out and I cannot find any information regarding replacement bulbs. Can you help?
I cannot find any info either, so lets "figure" it out. Does the "bulb" look like an interchangable (replace-able) bulb - LED's "almost" never need replacing (for the most part) and manufacturers always solder them in. I'll assume that you cannot twist (or un-screw) the bulb.
Now what to do...if you really like this flashlight - you could open it up, un-solder (or cut leads) the LED and put a new one in. The LED to use is:
- one that can handle the voltage - measure voltage (with volt meter) at the burned LED with flashlight on (keep track of polarity, which wire is negative/positive for the new LED),
- you will check for a flat (fish eye magnifier) top surface or round top,
- check for size (diameter) of the LED.
Now match that up to an LED at www.digikey.com They will have higher prices but, you are only buying 1 LED and they have the biggest selection to better match you old LED.
There are lots of new flashlights out there and getting a new one may be a good option.
Jul 12, 2011 | Camping, Backpacking & Hiking
Rapid overheating
Hi
The fan should come on when the light comes on, if not check that the switch wires are good & that there is continuity between it the light & the fan
There could be a pocket of air in the cooling system, squeeze the tubes from the radiator to dislodge it
There is a product called a water wetter (probably some sort of detergent) that helps to alleviate hot spots in the engine - Apparently it works well !!
Here's a to some on Ebay ;-)
Triumph-Redline-Water-Wetter-Super-Coolant
Ride Safe
Bike-Doc
May 14, 2010 | 1994 Triumph Daytona 1200
I don't know what a particular warning light is. It came on today; it looks like a circle with little lines coming out of it. Sort of like a "light bulb" idea symbol.
a circle with an exclamation mark is usually the low tire indicator (that symbol is a tire and a tire gauge). sometimes when the temperature drops down, one of the tires will show up as low & later in the trip when the tire warms up, it will read correctly. Or, you can just have oone that is too low & need air. good luck
Jan 31, 2010 | 2003 Volvo S40
Pockets
Dear sewer:
The only way I have found is to take the pocket off the shirt and re-sew it after you have finished embroidering it. Notrub
Mar 05, 2008 | Baby Lock Esante
Nebo Redline Tactical Flashlight Strobe S.O.S 220 Lumen 5581 Logo
3,573 people viewed this question
Top Nebo Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Nebo Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
