Question about Cell Phones
Forgets network settings - Cell Phones
  • 580 Answers
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Posted on Nov 02, 2012
How do I change the password on the kindle for the wireless network?
To add a new Wi-Fi Network:
If you don't see the network you want to connect to in the list of detected networks, you can add it by choosing "Enter other Wi-Fi network" at the bottom of the list of detected networks.
  1. Make sure you are within range of the network you want to add, and that you know the network name and password (if required).
  2. Press the Home button, then press the Menu button.
  3. Navigate to "Settings" by moving the 5-way controller down, then press the 5-way controller to select.
  4. Select "view" next to "Wi-Fi Settings" to display a list of detected Wi-Fi networks.
  5. Use the 5-way controller to navigate down to "Enter other Wi-Fi network" and press to select.
  6. Enter the name of the Wi-Fi network that you want to add.
  7. Enter the password (if required). Press the Symbol key to enter numbers or characters not present on the Kindle keyboard. You can continue to use the keyboard while the Symbol menu is displayed.
  8. Choose "submit." Kindle connects to the new Wi-Fi network.
If your Kindle fails to connect to the new Wi-Fi network, it will display an "unable to connect" message. You can try manually entering all the network information for the Wi-Fi network by choosing "set up network" when you see the "unable to connect" message. If you don't know the network information, try connecting to a different network, or contact the network's administrator.
To forget a Wi-Fi network:
You can tell Kindle to forget the Wi-Fi network you're connected to so that your Kindle doesn't connect to it automatically in the future.
  1. While connected to the network that you want to forget, press the Home button, then press the Menu button.
  2. Navigate to "Settings" by moving the 5-way controller down, then press the 5-way controller to select.
  3. Select "view" next to "Wi-Fi Settings" to display a list of detected Wi-Fi networks. You may have to wait a moment as your Kindle detects networks in range. The Wi-Fi network you are currently connected to displays the word "forget" next to it in the list of available networks.
  4. Choose "forget" to disconnect from the network.
To connect to a Wi-Fi network:
  1. Press the Home button, then press the Menu button.
  3. Select "view" next to "Wi-Fi Settings" to display a list of detected Wi-Fi networks. You may have to wait a moment as your Kindle detects networks in range. Kindle automatically scans for available Wi-Fi networks at periodic intervals. To rescan for available networks at any time, select "rescan."
  4. Select "connect" to connect to a network. If you see a lock symbol next to "connect," the network requires a password to connect.
  5. If necessary, enter the Wi-Fi network password, and choose "submit." Press the Symbol key to enter numbers or characters not present on the Kindle keyboard.
Once you are connected to a Wi-Fi network, Kindle automatically connects to it again whenever that network is in range. If more than one previously used network is in range, your Kindle automatically connects to the network that was most recently used.
Tip: Once your Kindle connects to a Wi-Fi network, that network displays "forget" next to it in the list of available networks. Selecting "forget" disconnects your Kindle from that Wi-Fi network and also prevents Kindle from automatically connecting to it in the future.
Mar 07, 2016 | Tablets & eReaders
My iphone istelling me to forget this network. It has been using it since Christmas. What's wrong
Are you having trouble with the WiFi? I've never had a smart phone, or anything else for that matter, suggest forgeting a network. The list of remembered networks just gets longer and longer over time. However, if you go into WiFi settings there are things you can do to clean up the list of networks like set a priority order/move up and down or forget/remove old networks. In summary, unless you are having trouble with the wifi, this may be a normal thing you just recently noticed.
Jun 17, 2015 | NetGear N600 Wireless Dual Band Router
A WiFi connection potensWL has popped up on my wifi settings. I do not know what this is but want to delete it. How do i do it? I have a Samsung Galaxy tab 2.
Hi
To connect to a WiFi system, you may need 3 pieces of information:
A username
A password
An encryption key
Once you have successfully linked to a WiFi access point then your tablet will remember the settings until told to forget them. To do this, tap on the connection in >Settings >Wireless and networks and ou will be given 3 options, Connect, Forget, Cancel. You need "Forget".
A lot of the time you may only need the encryption key, and if the tablet detects a WiFi access point then if you tap on that in wireless settings then it will either connect automatically or ask you for some sort of code - the encryption key. If this is not entered correctly then it will return an authentication problem/error. In order to connect you have to have this code.
It is worth remembering that your tablet will always notify you (via Wireless and Network settings) of all wireless networks that are within ita range.
Cheers
Feb 28, 2015 | Samsung Galaxy Tab on 3 Mobile Tablet PC
My android sumsung s4 can not select network settings. wen I select manualy it keeps on saying error while searching for network and wen I select auto it does not show selected network. wen I make a p
Hi
Samsung phones and probably most other phones store all networks detected throughout their lives unless you select them and tell them to "Forget" particular connections. This applies even when the network settings don't match the settings of the network you are trying to connect to.
I would suggest that you "Forget" the connection you are trying to connect to. After a while the phone will detect the network and if you tap this network it will ask you for a password. Enter this and it should connect it the network without trouble.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Jan 04, 2015 | Samsung Galaxy S 4 GT-i9500 Smartphone...
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Oct 09, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
How do I correct a wi-fi error code?
If there are any networks detected, forget that network. Then set it back up again with same network. If that doesn't work call your wifi provider
Sep 19, 2014 | Nextbook Premium 8 Se Android
Will not stay connected to home wifi
Open your wifi on the phone and press and hold the wifi network that you want to connect to then click (modify) re-enter the security code for the wifi network again and then connect. If that does not work then the wifi signal is weak and you'll need to get closer to your router.
Another thing is to choose United States for your Wifi Region in the wifi advanced settings menu.
-- uncheck (avoid poor connections)
-- check scanning always available
-- Wifi Region Code (select United States)
I hope that helps will-not-stay-connected-home-wifi-5x01jctu1hti52f1zciidmg3-3-0.png
Mar 19, 2014 | Samsung GALAXY S4
Authentication problem when trying to connect to the internet
If it use to work on your network and you haven't changed any router settings. You can try and "forget" your connection. Go into settings > wireless and your network should be listed. Touch and hold on your network and you should get a button "Forget Network", tap that and try to reconnect to your network.
Dec 29, 2013 | Polaroid S7 7-in. Internet Tablet
I touch the forget network buttom on my ipod touch and wiped out my linksys network
Try clicking the Renew Lease button, on the same page where you found the "Forget this Network" button.
     Or, on the home page, go to Settings->General->Reset->Reset Network Settings. Reset Network Settings, again, in the red box. Once the iPod is back on, try connecting to Safari. If this doesn't work, try turning off your Linksys router for at least 30 sec to 1 min. Turn it back on and try connecting to Safari. This should work, hopefully.
Jan 07, 2010 | Apple iPod touch
Mac Book Pro forgetting Wi Fi settings
yep! Go to the Systems Preferences window and select NETWORK.. then select Airport and the advanced button... you can drag your networks to the order you prefer and then check the appropriate box at the bottom of the list to keep your log in ... that should do it!
May 03, 2009 | Apple MacBook Pro Notebook
Cell Phones Logo
18 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
