Question about Sharp Microwave Ovens
R-888-F sharp Microwave oven is not heating. - Sharp Microwave Ovens
MicrowaveSvc
  • 9047 Answers
SOURCE: heat's water great , won't pop corn
It may be a food placement issue or possibly a bad humidity sensor.
I always recommend that folks put food off-center on the turntable (not in the center) to assure more even heating.
It's a stirring action, so imagine how inefficient it would be to stir just by twirling a spoon in the center of your coffee!
Also, when you put your food off-center, you're not putting it in the same spot every time. That will help prevent repeated heating of the the same spot on the glass, which can lead to weakness and cracking. Microwave popcorn gets hot enough to do that.
We have the entire service manual at our site if your or a friend want to look that over: http://www.microwavedisplay.com/r820bc_bk_bw_sm.pdf
If you need a new sensor, you can order Sharp parts from Tritronics at http://www.wehaveparts.com
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 04, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: User's Manual of Sharp Microwave Oven Model R-9H56
Found this posted under Whirlpool instead of Sharp, but I'll be happy to answer it here.
While that one may not be available, we have one that may be close enough to work:
http://www.microwavedisplay.com/r9h66_r9h76_r9h84b_r9h94b_om.pdf
Posted on Dec 17, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp Covection Oven/Microwave stops after 1min on any setting
This 59-second stop failure is due to a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller thinks that the door is not in the right position, it will shut down the cook cycle.
See the attached sample photo.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We even have a video on our site that shows you how to safely & easily remove the control panel assembly to send it for service.
Posted on May 09, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: R-4H84 Sharp Carousel II microwave oven stoped working
A microwave can be dead for many reasons.
The fuse is normally located on the floor of the chassis behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Jun 23, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp microwave oven model r-1440 runs, but doesn't heat food
Assuming your inside light and turntable come on when you try to microwave, with the symptoms you have, I would most strongly suspect a bad magnetron or a loose and possibly corroded connection on the magnetron's terminal.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it'sprobably okay)
http://www.gallawa.com/microtech/mag_test.html
The best place to order parts for this brand is Encompass (formerly Tritronics).
Or you can call them toll-free at 866-779-5835.
Posted on Feb 08, 2009
Sharp r-610dk microwave runs but don't heat up
The magnetron has failed, or the inverter board, "if 7 years old or less" there is also a possibility the keypad control board may be the problem.
Apr 21, 2012 | Sharp Microwave Oven Microwave Oven
My microwave oven sharp r-220, it doesnt give heat or produce heat? what should i do to fix it?.. the light bulb, motor fan and the timer are all ok..
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 14, 2010 | Sharp R-220BW Microwave Oven
My microwave Sharp R-259 does not heat up, the
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101][][]\
May 12, 2010 | DeLonghi MW 605 Convection/Microwave Oven
Sharp microwave oven R-580D will not heat or defrost
heatman101
hljk
Mar 12, 2010 | Sharp R-1480 Microwave Oven
Sharp R-1870 Convection works, microwave doesnt heat
heatman101
ytwyys
Oct 07, 2009 | Sharp R-1870 Convection/Microwave Oven
My microwave oven (Sharp R-9h58) is not heating offen
heatman101
jhfkj
Jun 17, 2009 | Sharp R-1480 Microwave Oven
Microwave will not heat
heatman101
tsjus
May 09, 2009 | Sharp R-316FS Microwave Oven
Turntable stop working along with microwave and convection oven
would be a door micro-swtch sharp part # Sharp Part Number: QSW-MA085WRE0
Jan 07, 2009 | Sharp R-1405 / R-140 Microwave Oven
Microwave Ovens Logo
44 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
