Question about Gaggia Syncrony Logic 74884 Espresso Machine & Coffee Maker
Cannot put the dispensing unit back in
Durring a mid cycle operation the coffee maker ran out of water. I then pulled out the dispensing unit but cannot put it back in
mirran
  • 515 Answers
SOURCE: No water coming through on rinse cycle
try to make a cup of water (tea), if you not get any water that way i think you have to replace the flow meter in the machine.
Best regards
/Mirran
Posted on Oct 26, 2008
  • 3 Answers
SOURCE: Hot water
Have you kept up with descaling?
Probably the water heater has failed. If you're technical then most parts should be replaceable but you may have to order them from Gaggia in Italy.
Posted on Nov 13, 2008
EsWorld
  • 1618 Answers
SOURCE: My gaggia coffee machine hasn't been used for a
First remove the screw and screen then press brew button to run water, if that works clean screen and reassemble, if not you will have to remove the allen wrench screws and clean the diffuser and vlave spring.
Posted on Aug 14, 2009
  • 109 Answers
SOURCE: Our Gaggia Tianium is stuck on rinse cycle, water pouring out
Just let it run the cycle,don't press any buttons.
When it runs out of water refill it and let it continue.
I get this problem a lot,
Posted on Feb 22, 2010
SOURCE: I have a gaggia cubika
I had the same problem but it was not a new machine (about 1 year old). I found the solution by replacing the valve inside the group head. It cost a matter of a few pounds and very easy to fit. In the middle of the spreader shower plate there is a screw. Undo this and take off the shower plate and you will find a threaded bolt that has the thread that holds the screw you just took out. Carefully undo the bolt and the valve drops out. This is the part that I replaced. Replace with the new valve and re-fit the shower plate. Be careful not to overtighten the valve as it can snap. It worked for mine and has worked well ever since. It might be worth taking the current valve out and wash it then put it back before ordering a new one. It could just be blocked.
Posted on Jan 05, 2011
Why is the coffee not going into the cup? instead it's going straight into the driptray
There are several reasons but the most common is a clogged brew unit - Have you ran the cleaning cycle successfully? Try running the rinse cycle and see if water is dispensed through the coffee spouts - the cleaning tablets are used to help rid the build up of oils in the brew unit and should be used regularly.
Jun 15, 2014 | Miele CVA4070 Coffee Maker
I need to clean my capresso c1000. i can't find the instructions. i put a cleaning tablet into the ground coffee area, and ran the ground coffee button a few times. is that it?
No, first push the self clean button (hold until lights come on). Then pull the grounds unit and empty it, that will turn off one red light. Fill the water tank. Then drop the tablet. Then hit the ground coffee button. Cycle through and dump the grounds each time the grounds light illuminates.
Jul 09, 2011 | Jura Capresso C1000 Espresso & Coffee...
I have a keurig mini and the water is barley dispensing. I dont know if its clogged or what. What can i do?
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Jan 04, 2011 | Keurig B100 Coffee Maker
Saeco Vienna coffee when the machine starts the coffee dispensing
Is it leaking only when brewing coffee ?
If not I would check the seal under the water tank (Part #NM05.006)
If so, I would check the following:
1- The water input port on the back of the brew unit (looks like a smoke pipe) might be clogged
2- The o-ring of the water tubes coming in and out of the boiler.
Jul 30, 2010 | Saeco Vienna SuperAutomatica Coffee...
Coffee maker does not dispense product, instead, it simply returns hot water back into water resevoir
It sounds like there is a restriction in the line between the pump and spray nozzle and it is being pushed back out the vent line. I would try running the cleaning cycle per the instructions in the manual. I would use a slightly higher concentration of vinegar to try and clear any hard water deposits causing a blockage. Also try soaking the spray head with vinegar using a small shot glass an see if that helps. If it is within the warranty period I would send the unit back to Keurig if the cleaning cycle does not fix it.
Feb 19, 2010 | Keurig B50 Coffee Maker
It is stuck on large and does not brew
My keurig did the exact same thing. Stuck on large and wasn't pulling water into coffee maker so it would only dispense a small amt of coffee. I turned it off for about 10 mins. Emptied the reservoir and filled it half way with white vinegar. Ran several cups through and after 2nd brew it ran faster and after the 3rd run with vinegar all the size cup lights came back on. It is working great now. Just empty reservoir with remaining vinegar and rinse. Run a couple cycles of plain water through the coffee maker to rinse out vinegar. I hope this works for you.
Dec 27, 2009 | Keurig B60 Coffee Maker
Water will only dispense out of the frother.
It could be several soutions to this problem. First of all, try to clean the sieve in the brew unit, it may be clogged. Take out the tray, in between the 2 brown "lips" inside you can put your finger up and clean out all the old coffeegrounds stuck up there. Then put everything back in place and run a Rinse machine operation.
If this is not helping, listen out when you start up the machine; You should hear that the valve is turning 3 times, if it doesn`t it can be a problem with this valve not opening in right position. Then all the water would go out in the tray, and not into the brew unit. That maybe can be solved by changing this Multi ceramic valve or the Main Electronic board. Then it`s a job for a sertified Jura technician.
Jul 04, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Stopped up
I took a small tooth brush and brushed the screen from the inside of the pot. That cleaned it right up and I now have a full stream, dispensing.
May 12, 2009 | Hamilton Beach BrewStation 47224 Coffee...
Cuisinart Coffee Maker Model # DCC-1150
Unplug for longer than 15 minutes to completely reset it
Oct 09, 2008 | Cuisinart DCC-1200 Coffee Maker
Descaling
There is a software Problem on the electronic in the back of the coffee maschine.
Changing that electronic to the new version will sort that Problem.
Mr. Cool
Sep 07, 2008 | Miele CVA4070 Coffee Maker
Gaggia Syncrony Logic 74884 Espresso Machine & Coffee Maker Logo
Top Gaggia Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Oloyede Monsuru
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
