Question about Canon imageRUNNER 1023iF Black and White Copier
Canon NP 1215 copier:
The lamp is working, but it does not move across the bedplate.
Taking off the glass, the lamp fitting feels very heavy the drag across - oiling the runner has not helped.
Lubricate the drive gear related to moving the scanner unit
Posted on Mar 10, 2009
    Novelist:
  • 148 Answers
There is a drive gear, clutch or electromagnetic clutch that is either broken or dirty(slipping)
FIX
remove the back cover and manually move the image assembly back and forth on the rail
determine were the drive gear, cable or motor is connected to the scan/image assembley
See if you can observe the mechanism from the back or top of the machine by ressing th eprint button
(caution do not touch any electrical connections) you may have to trip any safety switches to get machine to come on with covers off
This drive assembly can be complicated if it is a series of cables if it is just an electromagnetic clutch with a gear it is relatively easy (may need ring clip remover or allen head (metric wrench) remove the assemby and clean it
If the assembly does not move after you have done the following the drive motor/clutch needs to be replaced( usually requires technician) YOu must be very mechanically inclined
Posted on Jan 04, 2009
"E212" Lens problem (sensor, motor)
You have a very old copier..... Try taking the copy board glass off and the lens cover (black box) off. Try to move the lens with your hand, will it move? Move it out of HP and turn the power ON. Will the lens move, if so look where it stops.... I believe there is a drive gear that may of cracked... You have to watch were it stop moving....Good Luck
Jan 15, 2013 | Canon NP 6050 Copier
Need service manual for canon copier np-1215
hello, you can find the canon np1215 series service manual in below link:
http://goo.gl/1sdGnj
thank you
Apr 27, 2012 | Canon Office Equipment & Supplies
What will I do if my copier's bulb (light) is not functioning?
You will have to replace it. You should make sure the copier is unplugged because there is line voltage on the lamp. Remove the glass and move the scanner to the right a bit. You remove the black lamp shield. One or two screws, I can't remember. At the rear of the lamp you should see a spring that needs to be removed. This keeps the lamp in place. Get the correct lamp, and reverse the procedure. Test to make sure the lamp comes on before replacing the shiled and the glass. Some times the from spring lead doesn't make good contact and you have to try again. Be sure to uplugg the copier if you have to work with the lamp. Sometime the foil that powers the lamp or the connections go bad. Good Luck
Nov 08, 2010 | Canon NP 6551 Black and White Copier
Requist for sugasion kyocera km-1500 toner
it is support cnon np 1215 toner
first time
you clean copier toner unite clean complite previous toner then put canon np 1215 toner print ok
May 28, 2009 | Kyocera KM-1505 Copier
Warm up problem NP 1215
all support and parts have ended for this very old copier.
Jan 12, 2009 | Canon imageRUNNER 1023iF Black and White...
Shaky image at particular are in canon 6650 photocopier
the scan lam assembly is dragging when you hit
print
If you can get access to the scan rails( remove the glass platen put small amount of silicone on the rails and if it moves manually(do not force )
If this does not work there may be a clutch or electrmagnetic drive that is slipping
either way it needs o be removed and cleaned
Dec 29, 2008 | Canon NP 6650II Copier
Canon NP-1215
1-toner may be bad (moisture)
2-primary wire not charging - no contact or broken (unit with a thin wire above drum)
3-seperation unit shorting out (wires under the drum)
Sep 01, 2008 | Canon imageRUNNER 1023iF Black and White...
Problem with my copier
Mesin Saya 6035 Error 224 gimana atasinya
Jun 27, 2007 | Canon NP 6035 Copier
Canon imageRUNNER 1023iF Black and White Copier Logo
111 people viewed this question
old marine
old marine
