Question about Philips Televison & Video
I have a phillips magnavox 51mp6100 37 with awesome pic but while were watching the sound stopped and the screen went fuzzy for a sec as an error code was displayed ...how do i get sound back?
    Top Expert:
  • Philips Master
  • 14,553 Answers
Try unplugging the set for a while to see if it helps or not.
Posted on Nov 02, 2012
albertv29
  • 87 Answers
SOURCE: no pic. or sound but power light is on
Most likely the blue picture tube arched and shorted out the horzontal output transistor.Very common problem with this chassis.Now if you have an electronics background you can most likley fix it, if not you will be dealing with finding a high voltage leak consisting of 31,000 volts which can kill you.That pop you heard was the high voltage leaking to ground.
Posted on Jan 16, 2009
  • 2920 Answers
SOURCE: how to fix fuzzy pic & red,blue,green lines on your screen?
i would call a repairman and have him come out and fix it.if you like the tv then its worth fixing if you dont then dont invest any money in it. but if it were me id have a repaiman come and fix it
Posted on Jan 26, 2009
Ecollier2012
  • 3459 Answers
SOURCE: Phillips Magnavox Proj. TV only makes cyclic chirping sound
Most common reason is shorted convergence chips. Goto the site www.TvRepairKits.com and get their "chirping set" repair kit.
Posted on Feb 04, 2009
Ecollier2012
  • 3459 Answers
SOURCE: philips magnavox model# 9p5040c102
Goto www.TvRepairKits.com and get their shrinking/expanding video repair kit. It works on the Philips sets.
Posted on Apr 08, 2009
Ecollier2012
  • 3459 Answers
SOURCE: I have a Phillips 609202 It went black but still had sound.
Flyback is the most likely cause. Goto www.TvRepairKits.com and see if they have a solution.
Posted on Jun 20, 2009
I have a Phillips plasma tv model number 42PF5521D/10 serial number VN4B0708013071 i was watching it on 1 of the 2 hdmi channels when all of a sudden it just went off when I turned it back on all I had was...
Does it work on the cable/antenna input jack? Can you get the menu screen to show up? If none of the inputs work and you can't get a menu screen to show up, then it sounds like you may have a bad YSUS driver board.
Mar 21, 2014 | Televison & Video
Phillips 47" flatscreen sounds still
If the TV menu displays your problem is most likely not the Tv , but is caused by the signal source:
Cable box or connections. Reboot everything test using other sources like a DVD player to isolate the problem.
Aug 20, 2011 | Televison & Video
Phillips cineos 52 inch have sound but no picture
i have a 52 projection tv phillip and the pic is off you see three images on the bottom nice pic in the middle and on top a little off.so what is the problem
Jul 02, 2009 | Philips Magnavox 51MP392H Rear Projection...
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
How to fix fuzzy pic & red,blue,green lines on your screen?
Typically this is due to a convergence chip failure. This repair can be done pretty easy with the proper instruction. Have a look at this video to help determine if you truly have a convergence problem.
Jan 26, 2009 | Toshiba 57H82 57" Rear Projection...
Pic.not fitting on screen
the black bars on the sides are normal there are settings in the menu to change the screen sizes.
Dec 01, 2008 | Philips Magnavox 42MF521D/37 Television
Cannot get the television to get out of fuzzy screen
  • hit the channel return button on the remote
  • hit the tv/video button on the remote
  • perform a channel scan through the remote menu
  • unplug unit for over an hour and plug back in, complete initial setup by following instruction on the tv.
Jun 25, 2008 | Philips Magnavox 27MS343S 27" TV
Phillips Magnavox Rear Projection Tv screen too dark
The high voltage is failing. The LSB board is about $200 from partstore.com.
Dec 28, 2007 | Philips Magnavox 51MP392H Rear Projection...
Screen is black
on that tv you have to check just for circuit of high voltage - check
transistor near flyback transformer - delfo
Dec 11, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
22 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
