Question about Cell Phones
Factory reset u8150 without using recovery mode
Boot into recovery stopped working
  • 580 Answers
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Posted on Nov 02, 2012
My lg viper 4g lte wont boot completely
if you wont mind losing your data that are not backup... you can simply perform a hard reset to factory settings. 1. remove the battery 2. re-instert the battery 3. hold VolumeDown button then press the power button Do not release the volumedown key til u get to recovery mode Now that you are in recovery mode, first try WIPING CACHE and then reboot your phone. if the problem persist, then repeat step1-3 again this time, select WIPE DATA FACTORY RESET if wiping cache solves it, then your data are intact WIPING DATA FACTORY RESET wil return ur phone to new without losing any unlocking feautures. i'm McKennie
www.iswaltech.com
www.iswalhost.com
Jun 19, 2014 | Sprint LG Viper 4G LTE GSM Smartphone -...
How to unlock samsung gt 87610
try this one ^_6
If You Can't Boot
If safe mode doesn't help fix your device, you can perform a hard reset by booting into a special recovery mode. First, ensure your device is fully shut down.
Press and hold the correct keys to boot the device into recovery mode. This will vary from device to device. Here are some examples:
  • Nexus 7: Volume Up + Volume Down + Power
  • Samsung Galaxy S3: Volume Up + Home + Power
  • Motorola Droid X: Home + Power
  • Devices With Camera Buttons: Volume Up + Camera
Similar devices will likely use similar key combinations. For example, the Nexus 4 also uses Volume Up + Volume Down + Power.
If your device isn't on this list and none of the above methods work, do a Google search for the name of your device and "recovery mode" - or look in the device's manual or support pages.
Release the buttons when the device powered on. You'll see an image of an Android lying on its back with its chest open and its internals revealed.
Press the Volume Up and Volume Down keys to scroll through the options until you seeRecovery mode on the screen.
Press the Power button to restart into recovery mode. You'll soon see an Android with a red triangle.
Hold down the Power button and tap Volume Up. You'll see the Android system recovery menu appear at the top of your screen.
Select wipe data / factory reset with the volume keys and tap the Power button to activate it.
Select Yes - erase all user data with the volume buttons and tap Power. Your device will be reset to its factory state and all your data will be erased.
If your device freezes at any point, hold down the Power button until it restarts.
If You Can Boot
You can reset your Android phone or tablet normally from its Settings screen. Tap the Backup & reset option on the latest versions of Android or tap Privacy if you're using Android 2.3.
Tap the Factory data reset option and to through the reset of the steps to confirm the factory reset.
If the factory reset process doesn't fix your problems - or doesn't work at all - it's likely that there's a problem with your device's hardware. If it's still under warranty, you should have it fixed or replaced.
(There's one exception to this: If you've been flashing custom ROMs and messing with your device's low-level software, it's possible that you could have overwritten the stock recovery software. In this case, it's possible that you have a software problem and not a hardware problem.)
goodluck
May 10, 2014 | Samsung Cell Phones
How can I fix my galaxy centura?
try this
If You Can't Boot
If You Can Boot
goodluck sir
Apr 25, 2014 | Samsung Cell Phones
My Kocaso Android Tablet 4GB it loads to the android logo n stays there is there a way to reset the tablet
Hi.
If you recently had a modification on your ROM, you may be experiencing a BOOT LOOP which is common to Android Tablets. A factory reset would be the best solution to that. Here's how to do it;
Turn-off your Tablet by long-pressing your power button. To be sure it's totally shutdown, wait for at least 30 seconds before proceeding to factory reset. If your tablet's battery can be removed, it would help if you detach the battery and put it back again before proceeding.
Resetting your Tablet to factory setting erases all the data in your tablet's memory, so you have to be ready to encode all contacts again and stuff like that.
Factory Reset Proper;
1. Press VOLUME UP and POWER button at the same time without releasing until the device boots to "Recovery Mode".
2. In Recovery Mode, scroll down by pressing VOLUME DOWN until you reach the option "Swipe Data/Factory Reset" or any equivalent to Factory Reset therein.
3. Follow through the succeeding menus until the device initiates the reset.
Note: If your Device has a HOME button (usually located at the Center-bottom of the LCD), the buttons to be pressed to enter into Recovery Mode are HOME and POWER at the same time. Release only after the device shows it boots in Recovery Mode.
I hope this helps you.
Apr 23, 2014 | Tablets & eReaders
Unlock pattern
tested 100% working How to Factory Reset Your Android Phone or Tablet When It Won't Boot android-recovery-mode.jpg
Safe mode can help you troubleshoot your Android, but sometimes you'll need to wipe everything and restore your device to its factory state. You can even perform a factory reset when your Android phone or tablet won't boot normally.
Ensure you have any important data backed up before doing a reset. This includes your Google Authenticator credentials, which will be lost during the reset. Disable two-factor authentication on your accounts first or you'll experience some trouble afterwards.
If You Can't Boot
If You Can Boot
goodluck
Apr 20, 2014 | Samsung Cell Phones
Galaxy tab 2 10.1 does'nt show thw level ef charge
Try Resetting the Device Cache Partition by booting in to Recovery Mode.
o turn ON in Recovery Mode:
Step 1: Power off device completely (You Might need to Keep it on charge)
Step 2: Press and Hold "power" + "Vol up" for 5 sec
Step 3: Notice it flash boot screen twice
Step 4: Enter recovery menu use vol up and down to navigate
Step 5: Press power button for confirmation
Step 6: Wipe cache partition.
if clearing the cache partition doesn't help, you can also try resetting your device by formatting it to factory settings (ALL DATA WILL BE DELETED). for this Repeat the Steps upto 5, then use Step 6: Wipe data and clear cache.
Post Thanks if it helps
Mar 26, 2014 | Samsung Tablets & eReaders
Reset rca tablet
You can perform a hard reset on your tablet 2 ways. The first is by going into Settings>backup and reset and choosing the Factory Data Reset option.
If you are stuck at the startup screen or a password/pattern screen and cannot boot into the system, you will need to use method 2, which is booting into recovery mode. Have the tablet powered off first and make sure you have more than 50% charge on the battery. Boot into recovery mode by pressing and holding the volume up and power buttons. At the RCA logo screen, let go of the volume up button and you should next see an android image. Press and hold the power button and tap the volume up button once more and you will be brought to the recovery mode menu. From here, you will need to use your volume up and down buttons to scroll and navigate to the wipe data/factory reset option and use the power button to confirm. When the process is done, go ahead and reboot and your tablet will be set to factory original settings.
Jan 12, 2014 | Tablets & eReaders
Hard reset u8150
It may happen that despite you have restored your mobile to factory setting, the error still exist. In this case, it is recommended that you opt for Hard reset
•Enter the code: *#7370# and press Yes to confirm initialization.
•Important Notice: It is recommended that you save all important information on your phone (e.g: memo, contacts etc)
•To make a Hard Reset on a Nokia phone that is not willing to turn on, just press simultaneously these 3 buttons:
•on/off + * + 3
•Before making a Hard reset better backup all your important information: contacts , memo...etc
Nov 02, 2012 | Cell Phones
Tablets wont boot up just shows arnova on screen and shuts down
I had same problem looping startup just showing Aenova screen, i tried the pin thing ended up doing a factory reset IT WORKED WAHEY!!
How can I do a Factory Reset on my tablet? If your tablet freezes often or if you get error messages during the start up of your tablet, you can use the recovery mode to reset your tablet to its factory settings, removing all installed applications as well as any data or content.
Your tablet must be up to date with the latest firmware - downloadable from the downloads area of this website.
To access Recovery mode on the ARNOVA 10bG3
To access to the recovery mode:
1. Hold down the volume button + and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button +.
The ANDROID green robot is displayed.
3. Once the ANDROID green robot is displayed, press simultaneously the volume button + and the ON/OFF button.
The Android system recovery screen is displayed.
a. Use the volume buttons to navigate
b. Use the ON/OFF button to select an option
To restore the default parameters of your tablet:
1. In the Android system recovery, select Wipe data/factory reset;
2. Select Yes -delete all user data.
3. Select Reboot system now.
Your tablet reboots. Redefine your parameters through the wizard.
Your tablet is restored to its default settings.
To access Recovery mode on the ARNOVA 9G3
1. Hold down the Home button and press the ON/OFF button.
2. Once the ARNOVA boot logo is displayed, release the Home button.
To access Recovery mode on the ARNOVA 8cG3/8bG3
1. Hold down the volume button - and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button -.
Sep 16, 2012 | Tablets & eReaders
Been reset to factory settings and need the password
You don't say what password you want. If it's windows password, in some versions of windows you can start the computer in safe mode by holding down the F8 key when starting the pc until it beeps. You can then log in as administrator without using any password and go to control panel to change the password. Failing this go to http://www.windows-password-recovery.net/password-recovery.php and download the windows password recovery program. Stellar Phoenix Password Recovery. It costs 49 dollars or 36 euros. It allows you to create a boot disc which you use to start the computer and displays all user passwords without entering windows and allows you to delete which ones you want so you can then shut down and restart without the boot disc and not need a password.
Jul 19, 2010 | Computers & Internet
Cell Phones Logo
16 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
