Question about General Electric WHRE5550H Top Load Washer
General Electric Washer Model# whre5550h1ww makes a clacking sound in wash cycle about i se
Makes loud clacking soun in wash cycle only. 1 per every agitation.
    Top Expert:
  • General Master
  • 9,472 Answers
There is a known problem with this GE model. Remove the front panel, look at the base plate below the motor. Can you see that it has been rubbing there? On that model the "front apron bracket" fails allowing the motor to rub againist the base. You will need to replace the apron with the new design they have out.Here is the part to order.
You may also check this by removing the front and run a load of wash and watch the motor.
Please post back your finding to me.
Posted on Nov 02, 2012
  • Rob Watkins
    Rob Watkins Nov 05, 2013
    How do you remove the front panel
  • Richard Roth
    Richard Roth Nov 06, 2013
    Take a look at this video. At the 1:50 mark it shows you how to remove the front panel. http://www.youtube.com/watch?v=BJBdwhGqL...
2 Suggested Answers
  • 10 Answers
SOURCE: General Electric WBVH5200J Front Load Washer
Your washer may be doing this because you use far too much detergent or non HE detergent. To solve, use 1 eyedropperfull of liquid HE detergent, or one half teaspoon of powdered HE detergent dissolved in extremely hot water. Try running a Basketclean cycle with vinegar to remove the extra suds which can STILL be lurking in your drums and lengthening your rinsing time.
Posted on Apr 22, 2010
Why does a front loading lg washer smoking in spin cycle
Lg washer smoking - YouTube
? 1:06
https://www.youtube.com/watch?v=vKeIDM78CFI
Mar 29, 2013 - Uploaded by mrsbarney04
Lg washer smoking ... LG Front-Load Washer Disassembly -Washing Machine Repair Help ... Lg Washer model #WM2016CW PARTING OUT! ... Roblox: Chaos Washers -SPINNING IN A GIANT WASHER WITH FANS!
GE Washer Diagnostic - Loud Noise and Smoking ...
? 2:33
https://www.youtube.com/watch?v=a-ONJ2_RQvk
Jul 7, 2013 - Uploaded by ApplianceVideo.com
Service your trusty GE Washer that has these following dilemmas: Loud Noise ... L-G. Samsung Kenmore ,LG, Whirlpool, Electrolux Speed Queen, Amana ... Front Load Washer Repair - Bearing and Seal Failure Mode - Duration: 14:44. ... WasherDiagnostic - Very noisy during spin -GE, General Electric, ...
LG WM1815CS Front Load Washer Smoke burning smell ...
Jan 25, 2016 | LG Washing Machines
Spin cycle in the washer just started making a loud clacking sound. It also seems to stop much more abruptly than it did before. Seems like something may be rubbing, but spin speed still seems good
i think it is like u havent got the lip down propley i used to have washing maschine like and it made that exact noise what i did was remome less clothes and just give it a kick with ur foot
Jan 13, 2013 | Washing Machines
General electric washer makes clacking soun in wash cycle every time it cycles.
There is a known problem with this GE model. Remove the front panel, look at the base plate below the motor. Can you see that it has been rubbing there? On that model the "front apron bracket" fails allowing the motor to rub againist the base. You will need to replace the apron with the new design they have out. Here is the part to order.
Please post back your findings.
Nov 02, 2012 | General Electric WHRE5550H Top Load Washer
General electric top load washer model #wpre6100g1wt loud noise
Your problem could be one of 2 things either the base is pushed up in the center or the front apron is bent. The apron is the piece of metal that runs across under the top cover. To remove the front cover to see either use a putty knife to release the catch between the top and the front cover and pull front outward one side at a time.
Feb 25, 2010 | Washing Machines
Early in the wash cycle, my Bosch diswasher makes a chirping soun
yes the problem from the heater.
if the sound coming from boiler heater means
1)scaling on the boiler tank(tank to be cleaned).
2)check any loose connection on the heater wire.
Jan 09, 2010 | Bosch Dishwashers
Washing machine rumbles when spinning
it needs to be leveled. most units are self leveling meaning they sit evenly. if yours in on uneven ground make sure you get it onto a flatter spot. should help.
Aug 23, 2009 | General Electric WSXH208H Front Load...
Clacking sound on agitate cycle only, no noise on spin
The agitate cycle uses the motor and a spring to function. The spring is made in pieces and asit gets older some of the sections of the spring break. To verify that it is not a loose drum. Ope the washer during the wash cycle andhold the drun by hand. If the noise stops lool for the loose bolts or replace the springs, they may be weak after that many years.
Aug 18, 2009 | Washing Machines
Something stuck in drum, spinning cycle loud hammering/clacking sound
hi there,
sounds like you may have something caught between the tumbler and the cabinet. since the drum has holes in it, can you have a look if you can see anything that's come of clothing, like a bra wire. it's usually something bigger.
Sep 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Slow cycle making a loud CLACKING noise???
Open washer's cover and look for a released or a malfunction shock absorber. Good luck!
Apr 08, 2007 | Kenmore 45981 Washer
General Electric WHRE5550H Top Load Washer Logo
182 people viewed this question
Top General Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Chris Goulet
Are you a General Washing Machine Expert? Answer questions, earn points and help others
