Question about Maxtor Hard Drive
Sata HDD set in primary master in Bios
My HDD,s cable is sata cable . Dos Bootable disk do not detect it. Because it is not primary master in Bios set up. I want set my HDD in primary master or slave in Bios.But How ? Plz answer me.
  • 1 more comment
  • Kamruzzaman chowdhury
    Kamruzzaman chowdhury Jan 04, 2009
    Sata cable HDD set in primary master or slave in Bios. How? Plz answer me.
  • Roberta Smith
    Roberta Smith May 11, 2010
    you have two drives the same ?....
  • Thomas F. Schneider May 11, 2010
    Fo intp setup and find the Boot order. Place the one you want to be primary,which must also have the operating system on it. as number one. .
    Problem Solver:
  • 8 Answers
Try considering these:
1. DOS disk doesn't recognize SATA, that's the truth
2. You're going to have a problem if you install OS in your computer (solution: do not select SATA in HDD type but rather IDE)
3. For your SATA HDD to become primary (boot first) try to select your SATA HDD as devic first to boot..
Posted on Feb 12, 2009
Today I installed SATA HDD at red SATA port 1 . But in BIOS, it shows Primary IDE master not detected....Primary IDE slave not detected....Third IDE master detected..I wanna know why my HDD is not detected...
there is no diffrence between primary & third ide hdd ,if you install nay booteble hdd in master so system try to from that frist . boot sequence of motherboard is try to boot from primary master first then Primary slave then secondary master and then master secondary ..................,
Jun 12, 2011 | ASUS P5GC-MX/1333 Motherboard
I have a 250gb seagate sata but when i put my 80gb IDE hdd it only detects in booting and in bios but after that if i open my computer i cant see my 80gb IDE Hdd and even in device manager my hard disk was...
there was wrong in the set up of jumper in your 80gb hdd. Look closely to the 80gb harddrive, in between the ide cable terminal and the power supply connector you will see 8pin terminals paired together and a jumper use to short the paired terminals. It is most likely that the jumper was configure to detect your hdd as master. If the ide cable you use for the 80gb hdd was also use for the dvd/cdrom drive then it will conflict with it if both jumper setting was set to master. See the description of jumper settings in the sticker of the hdd. Position the jumper to slave.
Reboot your system again and see if the 80gb finally appear in your system. When system boot upon detection of hdd, the primary master should be 250gb while your primary/secondary slave will be read your 80gb hard disk.
Jan 24, 2011 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
XP not detecting MY HDD but 7 trail and linux freeware
Method 1 : Go to BIOS and set anything with SATA disable (usually find uns=der advance setting in IDE configuration setting).Save the setting.
Windows Xp will detect your hard drive now.
Method 2 : This days BIOS comes with only few thing to configure.if that's is the case.
Download SATA driver,here is the link
http://download.cnet.com/SATA-Driver-Intel-Ver-7-0-0-1020-zip/3000-2122_4-162224.html
you need one more software called "nlite" in order to integrate the SATA driver in Windows XP CD so that it recognize SATA drives.
Here is the link for nlite download
http://home.midmaine.com/~nlite/nlite/nLite-1.4.9.1.installer.exe
On how to intergrate SATA driver with windows XP
Go to this page :
http://www.nliteos.com/guide/part1.html
Jan 12, 2010 | Toshiba Satellite A100-S8111TD Notebook
My Zenith PC displays Verifying DMI pool data . Update Success
Sometimes this can be even simpler. Put in your Windows CD and boot to safe mode command prompt and type fixmbr. This will repair your master boot record for your primary boot harddisk. Eject the windows CD and reboot and see if it fixes your problem.
Sep 02, 2009 | Computers & Internet
New SATA Hdd detection problem
Have you checked in the bios setup of the motherboard if your SATA ports are enabled?
Let me know if you need further assistance.
Regards,
Graemevm
Apr 19, 2009 | MSI Mother Board (MSM865PEN2V) Motherboard
Wont boot
go to BIOS and enable the secondary drive auto detect.
if you manaully set the drive to primary, secondar. the system should be able to detect it as you have set it. if you select cable select or auto. the sytem will put the drive connected to the end of the IDE cable as primary.
Apr 02, 2009 | Intel Motherboard
Harddisk
Check the jumper settings on the back of the drive, if this is the primary HD, set it to master, if secondary, set it to slave, if secondary still does not recognize, switch the ide cable so that the two drives are not on the same one.
Nov 19, 2007 | Computers & Internet
SATA II HDD instaling on ASUS P5LD2
No but you need to ensure that the drivers for your SATA controller are installed correctly (as they probably are not installed) http://uk.asus.com/products1.aspx?l1=3
Oct 25, 2007 | ASUS P5LD2-VM Motherboard
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Maxtor Hard Drive Logo
471 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
