Question about Sharp Televison & Video
I need to clean the bulbs on my tv. It is several years old. Is this done from the front or the rear behind the speaker covers?
    Top Expert:
  • Sharp Master
  • 14,553 Answers
If the set has three picture tubes it is usually done from the rear (safe and easy) by simply cleaning the lens above each tube. Got a model number?
Posted on Nov 02, 2012
  • 1153 Answers
SOURCE: projection tv
Yes you can safely clean tv, just remove front speaker panel and you should see screws holding up front prot. screen. Becareful not to snap screws. You can take screen out and there is a mirror that you can clean and 3 lenses.
Posted on Aug 12, 2007
SOURCE: cleaning JVC rear projection screen (behind cover)
You will have to do some dissassembling of the cabinet to remove the screen and bezel assembly. If you are will to do this I can give you the directions.
Posted on May 11, 2008
ctf1800
  • 4402 Answers
SOURCE: cleaning tv screen of hitachi rear projection tv
http://serviceman.site88.net/index.htm
Posted on Jul 07, 2008
  • 85 Answers
SOURCE: GREEN GHOST
If you want to adjust focus and screen there is a focus block some sets they can be found on the front behind the gril then behind a cut out held in place by screws if not check from the rear. But a ghost like you say sounds like a convergence problem
Posted on Sep 26, 2008
electronick
  • 505 Answers
SOURCE: I have a RCA 60 inch TV and its about 12 or 13
you probably have a little of both. the shutting off is definately heat related but could be too much dust on heatsinks, etc causing it to shutdown. cleaning may eliminate problem but could be a sign of an underlying issue..
the dust can really cause the picture to dim. most of these tvs you can pull the "lightbox" or guts out of the cabinet to clean all 3 lenses, and clean the mirror if needed. don't mess with the screens except cleaning the front from outside. usually a 1/4" driver will be all you need, and a soft cloth for the lenses. use compressed air or a vacuum to clean out dust which will help with cooling, but the picture is only effected by dust on lenses, mirror, and screens.
Posted on Feb 18, 2009
My mitsubichi projection tv model vs-50605 is getting dark, Do i need to change the bulb
This model does not use a "bulb", it has three picture tubes.
What does happen is the lens for each can get dusty; picture will gradually get dimmer and dull looking.
With set unplugged, remove rear cover (it can be done from front but back is safer for a do it yourself person..
With the rear cover removed look for the 3 large black lens pointing up in the middle of the set--simply clean them with a lens cloth or a paper towel with glass cleaner sprayed on it---this should usually be done once a year.
If they have not been cleaned recently or you are in a dusty environment, cleaning them should improve the picture a lot.
Let me know if you have questions.
SD TECH
Jun 01, 2011 | Mitsubishi VS-50605 50" Rear Projection...
Can the front cover be removed for cleaning?
yes normally its just small clips that are resealable used to hold it on as for maintenance it requires exposing the light bulbs
hope this helps
Robb
Apr 23, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Replace bulb sony KF-60XBR800
When you are in front of tv grasp the right side of the front grill and pull it off, the lamp door is right behind it. Unscrew the cover and remove it, you will need the allen wrench provided with the new lamp to remove the old lamp just unscrew it and pull it out.
Sep 15, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Need to replace lamp cant figure out how to take out
on the front of tv set there is a panel that you unscrew to get to the lamp then once you get that done you have to go through the back of tv to remove and yes you can buy the bulb by itself but you have to order it or any tv repair place might have one in stock
May 02, 2009 | Panasonic PT-50LC13 50" Rear Projection...
No video but there is audio after replacing bulb
NAKE SURE YOUR FRONT COVER THAT GOES OVER THE LIGHT IS'NT ON TO TIGHT ALSO CHECK THE 2 SCREWS THAT MOUNT THE LAMP COVER MAKE SURE THERE NOT TO TIGHT AND THAT THERE BOTH SCREWED IN THE SAME AMOUNT AND ALSO CHECK THE FAN ON THE BACK OF YOUR T.V. AND CLEAN IT IF NEEDED
Mar 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Cleanng the projection mirror
remove the speaker grill, you will see the screws holding the front screen, remove the screws and the connectors going to it and slide the screen up and off.
Sep 18, 2008 | Mitsubishi VS-45603 45" Rear Projection...
Tune up for Hitachi 60FX32B
Remove rear cardboard cover....can you see tops of red / green /
blue tubes ? Clean lens' with soft , dry cloth......Do you smoke ?
If not , replace back. Picture should now be clearer but not
necessarily brighter.......Next, remove front speaker grill and find
the RGB focus / screen adjust block....turn RGB screen controls
SLIGHTLY clockwise to achieve more brightness....not too much
or you will have retrace lines in background of picture.......Let me know after these steps are done........T.
Mar 02, 2008 | Hitachi 60FX32B 60" Rear Projection...
Green flashing light - no picture
If the green power light is blinking and you have no picture, then your light bulb has burned out and needs to be replaced. It is not a cheap bulb to replace. If the TV is less than 1 year old it should be covered by the warranty
Nov 03, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Projection tv
Apr 01, 2007 | Hitachi 50UX57B 50" Rear Projection...
Televison & Video Logo
22 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
