Question about Xerox Office Equipment & Supplies
Xerox 8830 black line
A black line appears from top of the sheet to bottom. This problem only happens when I'm ripping a job to machine. Not off the glass. Please advise.
  • 12 Answers
SOURCE: xerox workcenter XD120f
The small scanner glass (not the full size glass) has some dirt on it. Use a lint-free cloth (not paper) with alcohol or Windex and clean the glass. This should help.
Posted on Jan 27, 2007
Cogz
  • 1326 Answers
SOURCE: Black Lines
Do the black lines only show up when useing the adf???? Or do they show up on both the adf and the copyboard glass??? If it is only when using the adf...... The fix is easy.... you have to clean the smaller piece of glass that is to the left of the copyboard glass with windex or rubbing alchola. If it is with both you may need a new drum and blade or a new ufr... Good Luck
Posted on May 21, 2008
  • 8 Answers
SOURCE: Photocopies with black lines from top to bottom.
Your leading edge erase margin is adjusted out too far. It can be adjusted with a manual.
Posted on Mar 01, 2009
  • 67 Answers
SOURCE: I have a Xerox 8830, that is getting a LL90 error
LL-90 and LL-91 refer to low toner and too much toner. If low, the cartridge is nearly empty, if too much, tape off half the holes on the cartridge.
Posted on Jun 17, 2009
  • 67 Answers
Cutter drawer is not closed
Posted on Oct 03, 2009
8830 Idle Message
Try to reinstall the driver. You can get the latest from the link below:
http://www.nodevice.com/driver/xerox-8830-printer/get126620.html
Sep 23, 2013 | Xerox Office Equipment & Supplies
Why is my kenmore washer shredding sheets?
Check the drum for any Sharpe edges or splits also check the activator for the same . Something in side may have a rough edge to cause this .
Apr 25, 2017 | GE Energy Star WCVH6260F Front Load Washer
Line appears on copies from top to bottom of the sheet, Approx 7 7/8 in. It happen both off the glass and when ripping a job to machine
With lines showing up with both coping & printing, you are most likely need a general cleaning and if that will not work, odds are you are going to need a new OPC drum & drum cleaning blade and a new developer change..... Good Luck
Nov 09, 2012 | Xerox 8830 AccXES N5T Wide Format Digital...
I HAVE A XEROX XC-830 COPIER AND THE FIRST INDICATOR LIGHT ON MY LEFT IS ON. THE COPIES ARE COMING OUT WITH BLACK LINE IN THE MIDDLE.
Sounds like copy cartridge is bad or old. Probably drum. If there's round symbol that's on, that's it....Drum.
Apr 03, 2010 | Xerox 8830 Copier
What could cause wide black streaks when I try to make a copy? I cleaned the tranfer corotron, but still have the streaks. No warning lights come on for toner or drum cartridge replacement.
you may see the drum surface if there are black line left. if there is then you're having a problem with your drum unit; most probably the cleaning blade of the drum. :)
what is the model number of your machine anyway?
Mar 23, 2010 | Xerox 8830 Copier
XEROX 260 problem
Is the DCHP shut off on the machine? If it is on auto, it most likely changed the IP address.
Print out a configuration page, get the IP address and enter that into you web browser address box.
It sounds like the machine IP address has changed .
Mar 17, 2010 | Xerox Office Equipment & Supplies
I have a Xerox 8830, that is getting a LL90 error after printing a couple jobs. I can restart and the error will clear but than comes back after a couple jobs. Is this a sensor or is it some other problem?
Jun 15, 2009 | Xerox 8830 Copier
E4-14
pls check stripper finger assembly
Mar 16, 2009 | Xerox 8830 Copier
My Xerox Documate 510 adds a line from top to bottom down each scanned document. The line only appears when something is fed into the paper feeder and does not happen when scanned single sheet at a time on...
you probably have something on the scanning bulb when it goes through the feeder. The scanning bulb is directly to the left of where you use the flatbed. Clean that glass with a dry, clean cloth and you should be back in business.
Jan 11, 2009 | Xerox DOCUMATE 510 Flatbed Scanner
Xerox 8830 - 2 Drawers / Trays non-operational
I would suggest to have the proper service rep work on it. albeit pricey if you want it to work correctly have it professionally serviced.
Or say, Dearly beloved, we gather here today LOL.
Dec 18, 2007 | Xerox 8830 Copier
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
