It's possible that the issue is with the control board and not just the control panel. Before replacing the control board, here are a few things you can check:
Make sure the control panel is properly connected to the control board. Check the connections and make sure they are secure.
Check for any damaged wires or connectors. Look for any signs of damage, such as frayed wires or loose connectors.
Check the voltage to the control board. Use a multimeter to check the voltage at the control board. If there is no voltage, there may be an issue with the wiring or power supply.
Check the fuses on the control board. If the fuses are blown, the control board will not function properly.
If none of these steps resolve the issue, it's possible that the control board is faulty and needs to be replaced. However, it's important to note that diagnosing and repairing electrical issues can be dangerous and should only be attempted by qualified professionals. If you're not comfortable working with electrical components, it's best to seek the help of a certified technician.
F1 - Control Board Failure - Replace control board (ERC). F2 - Oven Temperature Too Hot - Replace oven temperature sensor. F3 / F4 - Shorted or Open OvenTemperature Sensor - Replace oven temperature sensor. F5 / F6 / F8 - Control Board Failure - Replace control board.
Communication problem. Check the wiring between the Main Control Board and the Speed Control Board. Wiring bad, correct wiring problem. Wiring good, replace the Main Control Board. If the problem is not corrected, replace the Speed Control Board.
E11 Fill time too long. Refer to test (1).
E13 Water leak in tub or air leak in air bell. Refer to test (2).
E21 Water not pumping out fast enough. Refer to test (3).
E23 Drain pump relay on control board failed, wire off pump or pump Replace console control board, wire or
defective. pump.
E24 Drain pump relay on control board failed. Replace console control board.
E31 Pressure sensor not communicating with control board. Refer to test (4).
E35 Pressure sensor indicates water overfill. Refer to test (5).
E36 Console control board problem. Replace console control board.
E38 Air chamber clogged or pressure sensor defective. Check air chamber, rpl press. sensor.
E41 Control board thinks the door switch is open. Refer to test (6).
E43 Console control board thinks the door locking device has failed. Refer to test (7).
E44 Console control board problem. Replace console control board.
E45 Console control board problem. Replace console control board.
E46 Console control board problem. Replace console control board.
E47 Console control board thinks the door PTC circuit is open in spin. Refer to test (7).
E48 Console control board thinks the door PTC circuit is closed. Refer to test (7).
E52 Bad signal from tacho generator. Refer to test (8).
E56 High motor current. Refer to test (9).
E57 High current on inverter. Refer to test (9).
E58 High current on motor phase. Refer to test (9).
E59 No tacho signal for 3 seconds. Refer to test (10).
E5A High temperature on heat sink caused by overloading. Test first-if bad-rpl speed control brd.
E5B High temperature on heat sink. Replace speed control board.
E5C High temperature on heat sink. Replace speed control board.
E5D Communication problem. Refer to test (11).
E5E Communication problem. Refer to test (11).
E5F Communication problem. Refer to test (11).
E66 Heating element relay failure. Refer to test (14).
E67 Input voltage on microprocessor incorrect. Refer to test (15).
E68 Current leakage to ground on heater or fuse opened. Refer to test (14 & 15).
E71 Wash NTC failure. Refer to test (15).
E74 Wash temperature does not increase. Wire off NTC - rpl water valve.
E75 Water temperature sensor circuit. Refer to test (12).
E82 Console control board problem. Replace console control board.
E83 Console control board problem. Replace console control board.
E91 Comunnication error between UI board and console control board. Refer to test (16).
E93 Console control board problem. Replace console control board.
E94 Console control board problem. Replace console control board.
E95 Communication error. Replace console control board.
E97 Console control board problem. Replace console control board.
E98 Console control board problem. Replace console control board.
EB1 Incoming power frequency out of limits. Refer to test (13).
EB2 Incoming line voltage above 130 VAC. Check voltage at outlet. If < 130VAC,
replace the console control board.
EB3 Incoming line voltage below 90 VAC. Check voltage at outlet. If > 90VAC,
EBE Console control board problem. Replace console control board.
EBF Console control board problem. Replace console control board.
EF1 Clogged drain pump. Unclog the drain pump.
EF2 Too much soap. Advise customer to reduce the amount
of soap they are using.
I assume that should be "SC400"... This is an error which can be reset by turning the MAIN power switch off for a few seconds and then on. The code will be cleared, provided the problem does not happen again.
SC400 - Image transfer belt bias error
Detected Conditions: - Timing - While the image transfer belt bias is ON - Condition - The feedback voltage is 4.8V or higher, or PWM value is 50% or higher for 500ms continuously.
Possible Causes: • Poor connections • Defective high voltage supply board (T1/PCC/BR) • Defective I/O control board • Defective main control board • Worn Transfer Belt
Troubleshooting Procedure: 1. Make sure the high voltage cable and trigger lines are properly connected to the high voltage supply board, I/O control board, and main control board. 2. Replace the high voltage supply board (T1/PCC/BR). 3. Replace the I/O control board. 4. Replace the main control board. [Signal Check] • Feedback signal: CN209-9, TP264, or CN211-A4 on I/O control board / CN302-A6 or TP106 on main control board. • PWM: CN209-10 or TP272 on the I/O control board.
Here are all the Fault Codes on the 6000/7000 but i dont see a E70 on here are you sure?
Failure code Fault condition Check
E11 Fill time to long. Refer to test (1).
E23 Drain pump relay on control board failed. Replace control board orwire.
E24 Drain pump relay on control board failed. Replace control board orwire.
E36 Control board problem. Replace the control board.
E41 Control board thinks the door switch is open. Refer to test (7).
E43 Board communications problem. Replace the control board.
E44 Board communications problem. Replace the control board.
E45 Board communications problem. Replace the control board.
E46 Board communications problem. Replace the control board.
E47 Board thinks the door PTC circuit is open in spin. Refer to test (7)
E48 Board thinks the door PTC circuit is closed. Refer to test (7)
E56 Highmotor current. Refer to test (9)
E5A High temperature on heat sink. Test first if bad replace
E5B High temperature on heat sink. Replace the speed control
board.
E5C High temperature on heat sink. Replace the speed control
board.
E68 Current leakage to ground on heater or fuse opened. Refer to test (14).
E74 Wash temperature does not increase. PlaceNTC in correct position.
E76 NTC temperature for the cold water valve over the limits. Hot and cold water hoses
switched.
E82 Console control problem Replace the control board.
E83 Console control problem Replace the control board.
E91 Selector LEDs do not light up Refer to test (16)
E93 Console control problem Replace the control board.
E94 Console control problem Replace the control board.
E95 Communication error. Replace the control board.
E97 Console control problem Replace the control board.
E98 Console control problem Replace the control board.
EB1 Incoming power frequency out of limits. Refer to test (15)
EB2 Incoming line voltage above 130 VAC. Check voltage at the outlet.
If below 130 VAC replace the
control board.
EB3 Incoming line voltage below 90 VAC. Check voltage at the outlet.
If above 90 VAC replace the
control board.
EF2 Tomuch soap. Advise customer to reduce
the amount of soap they are
using.
EBE Console control problem Replace the control board.
EBF Console control problem Replace the control board.
EF5 NTC temperature for the hot water valve over the limits. Hot and cold water hoses
switched.
No E20 on that model# Heremis a list of the codes
board.
board.
switched.
I think I figured this one out. I think it means that the washer is not able to drain, therefore it won't spin either. Underneath the washer is a series of outlet hoses and within one of them is a filter. When I finally found the filter it was clogged up with lint, fibers from a pillow and coins. You have to dig the filter out and then clean the filter and rehook up the hoses, this was relatively simple even for me. The washer works perfectly now.
I WOULD SAY REPLACE THE PRESSURE SENSOR IF BOTH CONTROL BOARDS HAVE BEEN REPLACED
THE MOST ECONOMICAL PART ASSOCIATED WITH THE CONTROL BOARDS ESPECIALLY AFTER HAVING ELECTRICAL PROBLEMS IS MORE THAN LIKELY THE PRESSURE SENSOR it may have BLOWN ALSO
