Question about Pentax Optio E10 Digital Camera
I got a pentax E10 i put a 1gig s card in an i can only take 258 pics and it is a 6mp camera and if i put the same sd card in an other camera it takes 550 pics what could that be
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Pentax Master
  • 102,366 Answers
The other camera could be recording pictures with a smaller size and/or higher data compression.
You're getting 250 pictures on a 1GB card. That's about 4MB per picture, which is a bit on the large side but not completely out of line.
Posted on Aug 23, 2012
  • 4 Answers
SOURCE: Pentax A10
Try another card in your camera but check the inside the card holder that you have not got a damaged connector in there. and format the card with the camera and not on pc. Hope that help you.
jam
Posted on Jul 03, 2008
SOURCE: Largest capacity SD card for Pentax Optio S5N
The maximum supported size is most likely 2GB SD Card. Cards with 4GB and more are following a new (incompatible) standard called SDHC (SD High Capacity), SDHC cards work only in devices specifically supporting SDHC. The Optio S5N uses the old SD standard where 2GB are the maximum size.
Posted on Aug 13, 2008
robmcd27
  • 423 Answers
SOURCE: SD memory prohibits functioning of Pentax E30
I know that usually, you should format the card for the camera that your going to use. Try formating it in the camera and see if that works. Let me know if I can do anything else for you,
Rob
Posted on Feb 22, 2009
  • 65 Answers
SOURCE: Camera won't read new SD card
The sd card is to big go for a 2gb ted10
Posted on Apr 20, 2009
  • 16 Answers
SOURCE: Pentax e10 shuts off The pentax optio e10
You probably set the auto power-off for energy saving
Posted on Jul 23, 2009
Need disc for pentax optio 6mp camera
You don't need any software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Dec 19, 2012 | Pentax Optio T10 6MP Digital Camera with...
I put newly charged panasonic evolta batteries into my Pentax E10. Took a couple of photos. Then plugged the connector into the computer and managed to transfer one photo into my photos library, but not...
When you reboot the computer, that message should go away. Use an external SD card reader and transfer your photos that way. They are inexpensive and relieves the need to connect the camera to the PC. It will transfer your photos much quicker too
May 15, 2017 | Pentax Optio E10 Digital Camera
What is max size of sd card?
SD cards top out at 2GB. Your 4GB card is actually an SDHC card. While SDHC cards will fit into the slot, they are electronically incompatible and will not work.
Dec 23, 2011 | Pentax Optio E10 Digital Camera
When I put fully charged batteries in my camera and turn it on the screen works fine. However, when I install any picture card and turn the camera on it gets stuck at the Pentax Optio screen. I will stay...
I have to say that you are probably using the wrong SD card. Or the memory card is to big and the camera cant handle all that memory space. I recomend that you try a 512mb San Disk SD Card. Dont mistake this for any card. Dont use a San Disk SDHC card. Do this and make sure your batteries are charged and you should of solved your problem. Good-Luck.
Jun 13, 2011 | Pentax Optio E10 Digital Camera
After i turn on my Optio E10, it shuts off right away even after i put in new batteries.
Sounds like a memory card problem. Try using A 512mb San Disk SD Card. Not a San Disk SDHC card. see if that doesn;t help you out. Good-Luck
Mar 21, 2011 | Pentax Optio E10 Digital Camera
What dous format on pentax optio e10 mean
Format completely erases the card and optimizes the card for your camera.
May 22, 2010 | Pentax Optio E10 Digital Camera
I have a pentax Optio E10 camera and put a 4gb sdhc memory card in but it doesnt respond when I switch it on - does this mean it is not compatible or is there a way of sorting the problem
The manual specifies SD cards up to 1GB. Cards bigger than 2GB are actually SDHC (SD High Capacity) cards and will not work in SD devices. 2GB cards may work; try at your risk.
Mar 11, 2010 | Pentax Optio E10 Digital Camera
Optio E10: memory card error
if the cards work ok on something else then there's a issue within camera it could be the actual sd connector within the camera ? doess the camera support that size ? Optio E10 supports upto 1GB SD Card http://www.pentaxcanada.ca/pdf/o_manuals/om_OPTIOE10_e.pdf it might not work with the high speed sd cards ? Regards
Jun 15, 2009 | Pentax Optio E10 Digital Camera
Sdhc memorty card in a pentax optio e10 camera
The E10 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
Dec 10, 2008 | Pentax Optio E10 Digital Camera
Pentax Optio E10 Digital Camera Logo
26 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
