Question about Philips Sony Lime Enx-15 Tv Tuner Pci Card 1692-228-12 Tsch6-112a 191024a Made In Japan
How do i use this tv tuner card it came with a computer i got and i dont know how to use it
I have samsung SMB2030 LCD MONITER I wanted to know that it supports which tv tuner card
The output of the tuner card must match the input of your monitor. Assuming it's a fairly recent tuner card, it probably has HDMI output, so your TV must have an available HDMI input. Older tuner cards had VGA outputs which many monitors still utilize, although the display won't be nearly as distinct as with HDMI.
Nov 23, 2014 | Computers & Internet
Philips SAA7130 TV tuner not scanning channels
hi try this procedure
1.go to device manager
2.then double click sound,video and game controller
3.then right click on saa7130 tv card (which is the driver u should have installed earlier)
4.then right click on that and select update driver software
5.the option box appears select browse for driver software on my computer
6.next u get two option select second one i.e let me pick from a list of device drivers
7.then u fine two collumed table manufacturer and modle.(note:uncheck show compatible hardware)
8.then under manufacturer select philips semiconductors then from model select saa7162 ,hybrid capture device and install.
8 it may warn about windows signature..some thing like that but dont worry just continue
9.it installs the driver.
10.then restart your pc
11.on windows startup it may show error like no device some thing like that .u just run ur tv application
if it works the dont forget to tell thanks
if it dosnt the sorry for wasting ur time
Jun 13, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
I have no driver to get it ready for work
Look here for your drivers
http://us.kworld-global.com/main/support_down.aspx?mnuid=1312&modid=21
Apr 24, 2009 | KWorld PCI TV/FM Tuner, DVD Maker Card,...
What can a tv tuner do, dose it work on a blank
A tv tuner card is a device usually inserted into a computer screen or tower. this device has a "Coaxial Cable" jack in the back so that "Cable" can be hooked into the monitor. Along with this most come with an input selector. this enables you to switch between tv and computer with the push of a button.
My Sources ( I simply Google'd "What does a tv tuner card do") (lol just so i dont answer incorrectly and look like a fool lol.
OK GL!
and btw i have one and love it! it came in my monitor and i didnt think of it much till my TV went out on me. after hooking up the coaxial i havent gone without for a while :)
PS ive got built in speakers in my monitor. when i turn cable on it comes through them. the nice thing is my USB headset stays sending sound from my PC (so if im running a scan ill heard the BEEP at the end and know its done :)
GL
any further clarification required just comment and ill check back
***A TV Tuner Card NEEDS cable to be input into it. You cannot connect to the net or run it off your pc :S
Apr 09, 2009 | Dell Televison & Video
TV TUner external not starting up
Safe mode
Power saving off
restart normally
Jan 30, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
How do i get drivers for Philips SAA7130 TV Tuner/FM
tv tuner card internal philips chipset driver dowonload saa7130tv
Jun 11, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
MONITOR
You will need a TV Tuner expansion card for your computer. If you buy a TV Tuner expansion card and install it, and connect an antenna or cable TV cable, you will be able to watch TV shows on your computer monitor while using your computer. With some TV tuner cards, you can also record TV for watching it later, or even hook up your VCR and record VHS tapes and home videos to put on DVD. This is a more complicated topic and instructions should come with the TV Tuner expansion card you purchase.
TV tuner cards usually run in the range of $20-75 and will fit in most computers. You can buy them online and at computer or electronics stores. Installation is fairly simple and the instructions and software are included (unless you buy a used one)
Jun 10, 2008 | Sharp LL173C 17" Flat Panel LCD Monitor
Using tv tuner card for a s/w
HI,
PLEASE CHECK UR CARD OR TRY TO RENEW IT OR PLEASE CHECK UR SOFTWARE IN THE WHICH EFFECT THE EXTRA TERESSTIAL THING SOFTWARE LIKE - FIREWALL.
Jan 29, 2008 | Computers & Internet
HP ExpressCard Pavilion Notebook
its definitely something you did.
theres a way to wipe system back to original pn hp screen.. F10.. that might fix..
if it dont. then bios is the issue.
Dec 20, 2007 | HP Expresscard TV Tuner For Windows Vista...
SAA7130 TV tuner card
I need Philips SAA 7130 Tv Tuner driver for windows xp professional SP2.
Dec 15, 2007 | Philips SAA7130 TV Tuner/FM Radio/Video...
Philips Sony Lime Enx-15 Tv Tuner Pci Card 1692-228-12 Tsch6-112a 191024a Made In Japan Logo
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
