Bryant plus 80 t blower motor running slow - Heating & Cooling
mcgyver468
  • 710 Answers
SOURCE: 36e93 bryant furnace inop
CHECK THE PRIMARY CONTROL TO SEE IF IT IS LOCKED OUT. IF THE RED BUTTON HAS POPPED UP THEN PRESS IT ONCE TO START, IF IT DOESN'T RUN THEN CALL A TECHNICIAN. ALSO CHECK THE SIDE OF THE MOTOR TO SEE IF IT HAS GONE ON THERMAL OVERLOAD(LITTLE RED BUTTON). RESET IT AND THEN PRESS PRIMARY CONTROL BUTTON. IF MOTOR BUTTON HAS POPPED OUT THEN REPLACE MOTOR. COULD ALSO BE A BREAKER. GOOD LUCK THANKS FOR AN HONEST RATING AND FOR USING FIX-YA.
Posted on May 10, 2009
  • 252 Answers
SOURCE: blower motor humms but wont start runs slow when spun by hand
nope, need a new motor
Posted on Jun 06, 2009
  • 116 Answers
SOURCE: blower wont run
make sure getting 220 v ac on imputs the relay my be bad hook up fan man to power check to see if getting a call from stat to make fan run green to common 24v ac hope this helps
Posted on Jun 17, 2009
  • 1033 Answers
SOURCE: Bryant furance cat.# 333BAV048080, with
Hello, sincebthe motor will not run in heating and cooling the first thing to do is check the capacitor, set your meter to ohms and disscharge the capacitor with a screwdriver, if the capacitor is good the meters numbers should ramp up and down, if not the capacitor is bad. To check the motor turn off power to the unit and take you meter and measure from the common wire to each other wire coming from the motor, you should have resistance,if not the motor is bad and must be repalaced. To check the board place one meter lead on the cool/high speed motor tap and the other lead to ground, if therebis no power on a call for cooling the board is bad.
Posted on Jul 11, 2011
  • 1033 Answers
SOURCE: a/c blower turns slow and makes puffing sound. bryant 80% avac system.little cold air from vents
Hello, replace the capacitor as when there are storms sometimes they can cause a voltage spike and damage the capacitor. The capcitor will be a round or oval metal looking can next to the motor. When the blower motor runs slow the coil can start to freeze due to lack of airflow and this is why little air is coming out of the vents. If the capacitor does solve the problem then the motor will have to be replaced.
Posted on Jul 02, 2012
Bryant gas furnace does the blower motor have to work for the heat exchanger to light up both are not working
It depends....on if you are talking about a small blower in the front of the furnace or the indoor fan motor. If your furnace is an 80% effficiency rating or above it will have a 'combustion air' fan....that will be a small on in front of the furnace in the vestibule under the front cover. If you have that motor and that is the one you are asking about...then YES it has to be running prior to the furnace igniting the gas.
If you are talking about the indoor fan motor for circulating air into your ducts, then NO it does not have to be running in order for the furnace to ignite. But it WILL have to run to remove the heat from the heat exchanger after it ignites or it willl overheat and shut off on high limit.
Jan 02, 2015 | Heating & Cooling
Furnace motor fan runs to slow, whats the problem?
need to replace the motor bearings are going out of motor.
Sep 15, 2014 | GE Carrier Bryant Furnace 1/2 Hp Ecm...
Bryant plus 90
Could be a cracked heat exchanger
Feb 28, 2018 | Heating & Cooling
Bryant Plus 90 furnace
possible your supply duct leak or break
Feb 11, 2014 | Heating & Cooling
Blower motor not working
2006 and later units have an X 13 GE non capacitor blower motor. Many many thousands have failed. There is a 5 year parts only warranty,if it has expired a new motor will cost $550.00 plus installation cost.
Jan 14, 2014 | Bryant Heating & Cooling
A/c blower turns slow and makes puffing sound. bryant 80% avac system.little cold air from vents
Jul 01, 2012 | Bryant Heating & Cooling
Nov 09, 2008 | Bryant 462AJC021BA Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
