Question about KitchenAid Architect Series KEBC107KSS Electric Single Oven
Kitchen aid, self cleaning
I turned it on the self cleaning mode, when it was done the bottom is white and the glass is permantley fogged in places
The only solution is to get a new oven, The paint in the oven burned off, and now the electic board is burning out. This oven when it hits about 400 degrees it makes this chemical plastic smell, and at selfcleaning it makes the same smell for 3 1/2 hours, and come to find out it burned the paint off
Posted on Jan 05, 2009
Replace outer glass on oven gr440lxmc
You have to take the inner glass off first to get to the fixings for the outer glass. its normally 4-6 screws holding the frame for inner glass in place good idea to keep the parts in order for refix.
Sep 18, 2014 | Whirlpool 30" Self-Cleaning Freestanding...
Why are there brown/white streaks inside oven door glass after using self cleaner 1 time?
Thank you for your post, friend!
From my understanding after you used the self-clean feature on your Frigidaire range you now have brown and white streaks on the indoor glass. Typically streaks can be removed by cleaning the interior glass. Normally it is recommended to have a professional clean the inside glass but a consumer can do it as well. Use caution when following the steps some pieces can have sharp edges. You will need to have a Phillips head screwdriver or small quad bit driver.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner.
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Hopefully this is helpful. -Matt
Aug 23, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Owner's manual re self clean feature Kithcen aid Superba27 self clean double oven purchased 1988 Cannot get it to turn on and heat. The Lock light does not go on and no heat is generated.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 17, 2011 | KitchenAid Ovens
The inner oven glass of my self-clean oven has a small crack. Can I still use the self-clean feature?
No, that may be what cracked it in the first place...the self clean or self destruct feature will noly finish it off for you...
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 23, 2010 | Frigidaire 30 in. Electric Gallery Series...
Loose oven door handle
I had the same problem. We took the door off completely & turned it upside down. There are screws on the bottom of the door, take them out, take off bottom trim piece that holds the outside glass panel in place, remove glass panel and you can access the door handle screws and clean the inside of the glass while you are at it.
Jan 05, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Cleaning between the double glass doors on smeg integrated oven
thats 4 glasses not 2,,you should get a technician,it preety hard taking door apart,,but this is a commend problem..if you want to give it a try .i will talk you thought
Dec 26, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Self-cleaning heat stains on the front facing panel
Use DeBruce polish. We Use Debruce Polish on all our cooktops and ENAMELED SURFACES. Debruce also works on stainless steel polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Nov 24, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
KITCHEN AID KEBC107KSS03 DOOR. REMOVE INNER PANEL. CLEAN GLASS
LOOK WHERE THE HINGE METS THE OVEN DOOR FACING..you will see on the hinge a tab with the door open pull these forward this will lock the hinges do this on both sides then closed the door slightly and lift up the door will come off then you can unscrew the bottom scres to access glass
Feb 22, 2008 | KitchenAid Architect Series KEBC107KSS...
Self Clean does not work
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Oct 30, 2006 | KitchenAid KEBS177 Electric Single Oven
KitchenAid Architect Series KEBC107KSS Electric Single Oven Logo
318 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
