Question about Yamaha Music
Yamaha tuba #YBB 102 on center valve case . Eb or Bb?
3 Suggested Answers
SOURCE: location of serial number on Yamaha tuba (Eb 321S)
I have an Eb 632 and its on the back of the second valve casing. Good luck.
Posted on Dec 13, 2008
ukvacfan
  • 328 Answers
SOURCE: wanting to know the age of my tuba
As a musician I'm not entirely sure. Best to contact worldwide services at www.yamaha.com and email customer services.
Posted on Apr 02, 2009
Yamaha Piaggero NP12 all "A" and "Eflat" keys are dead.
If all A & Eb are dead it would point to either a bad connection between the keyboard circuit and the motherboard ( ribbon cable ) or possible diode problems on the keyboard PCB.
Initially open up and check connections are all tight and correct.
Did this just happen or has the keyboard been opened up?
Nov 27, 2016 | Yamaha Music
How do i fix a Yamaha P95 that sounds Es with Fs and Bb with Bs across all the octaves?
Whether it happens to all of the key?
If yes, transpose setting may have changed. Change the setting to normal (0).
If the normal transpose, but tuning is still not standardized, check Pitch Setting.
To Restore Standard Pitch setting:
Hold down the A-1, B-1, C0 and C # 0 keys simultaneously and press any key between C3 and B3.
View image :
fix-yamaha-p95-sounds-es-fs-bb-bs-across-vzw3qjj2ajjzgyoqcmqtppa4-4-0.jpgfix-yamaha-p95-sounds-es-fs-bb-bs-across-vzw3qjj2ajjzgyoqcmqtppa4-4-1.jpg
If the above procedure is still no effect, try resetting the factory settings / Initialize overall: :
This is the steps:
Initializing the Settings
When you initialize the settings, all backup data stored to this instrument will be initialized and reset to the factory default settings.
Turn off the power to the instrument. Then, simultaneously hold down the C7 key (right-most key on the keyboard) and turn the power on again.
NOTICE
Do not turn off the power to this instrument while it is initializing the data in its internal memory (that is, while the button indicators are flashing).
View image:
Notes:
If this instrument somehow becomes disabled or malfunctions, turn off the power to the instrument, then perform the initialization procedure.
Sep 07, 2015 | Yamaha Music
My yamaha keyboard YDP140 will not play any A keys or the E flay keys
look for the common connection of A or Eb keys, lose contact might be the cause
Jul 29, 2014 | Yamaha Used Arius Ydp140 Digital Piano...
Are there any other Yamaha model trumpets that the valves are interchangeable with the Yamaha YTR232?
Any Bb trumpet made by Yamaha should have valves that are interchangeable. A few models that might do it are:
YTR-6345GS
YTR-6335S
YTR-200AD
YTR-8335LA
These are all in the same tuning as yours, so the valves should fit without any problems. The S at the end of some models denotes a silver finish.
Hope that helps!
Feb 11, 2011 | Yamaha Trumpet Ytr 6335
I've got Yamaha bass BB 414 with serial numbers QPX193028 tryin figure out what year?
LOOKING FOR THE YR OF A YAMAHA BASS GUITAR SERIAL # YAMAHA BASS BB 414.
Oct 13, 2010 | Yamaha BB414 Bass Guitar
What needs to be removed from my Yamaha YPG-625 to
DO NOT open the case unless you are aware of and comfortable with the fact that you could _destroy_ your piano. Easily.
Observe appropriate anti-static precautions. It should go without saying that this is an electronic repair, and dangerous voltages may exist inside the case.
1. Remove the stand if you have one
2. Lay the keyboard upside down (bottom up) on workbench
3. Remove all 90+ screws from the bottom of the chassis, including the 14 inside the speaker compartments
4. Carefully lift up on the bottom case part, taking not to damage the speaker lines
5. Unplug speaker connector and set lower case aside
6. LCD is mounted beneath main logic board
9in the center), my problem lies elsewhere, but competent and cautious service technique should lead you where you need. I would strongly recommend replacing the LCD assembly module, unless you are experienced in LCD repair.
Jul 06, 2009 | Yamaha Full-Size Keyboard
Wanting to know the age of my tuba
Mar 30, 2009 | Yamaha Music
Location of serial number on Yamaha tuba (Eb 321S)
Dec 10, 2008 | Yamaha Music
Music Logo
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
