Question about Activision Video Game Consoles & Games
Cabelas dangerous hunts 2013 cant read disc - Activision Video Game Consoles & Games
  • 6 Answers
SOURCE: xbox not acting right
no more points or bad connection and make sure game is in
Posted on Dec 14, 2008
  • 21 Answers
SOURCE: Just bought Cabela's Dangerous hunt 2011 and I'm
See the Top Shot Elite Set Up Guide on the Discussions Tab at Facebook.com/ActivisionHunts or contact Activision Assist on Facebook. http://www.facebook.com/topic.php?uid=133041143393695&topic=331
The same is below.
Activision HuntsCablela's Dangerous Hunts 2011: How-to-Guide for the Top Shot Elite
You have two options when playing Cabela's Dangerous Hunts 2011 with your Top Shot Elite. You can either play with the default setting, or you can calibrate the gun to your television set.
Option 1: Default Setting - Sensor Bar Position
The default setting will work fine for most people. However, you will need to ensure that the sensor bar position is set up correctly within the game. If it isn't, you may have issues with aiming and lining up the reticle that appears on the screen.
How to Setup the Sensor Bar Position:
1. From the main menu, select "options"
2. Select "Controls"
3. Make sure that the "Use Calibration" option says "No".
4. Select the Sensor Bar position that matches your setup. Top means that you have the Sensor Bar above your TV, and Down means that you have the sensor bar below your TV.
Option 2: Calibrating your Top Shot Elite
Calibrating the Top Shot Elite is not necessary to play the game, but it can help improve the aiming experience if done correctly. It should be noted, however, that not all homes are ideal for calibration. You should only calibrate if you can stand comfortably 6-8 feet in front of your television.
How to Calibrate:
• From the main menu, select "Options"
• Select "Controls"
• Select "Yes" in the "Use Calibration Option."
• On the calibration screen, you'll see a target in the upper left hand corner of the screen.
• Stand at least 6 feet away, aim through the scope and line up your crosshairs over the target. Pull the trigger to continue.
IMPORTANT: A message will say "Cannot detect gun position" if it cannot read your Top Shot Elite. Usually this means that you're standing too close to the TV. Try backing away from it. If you're still unable to line up the scope with the target, read through the tips section below to ensure proper setup.
• Next, you will see a target on the lower right of the screen. Aim through the scope and pull the trigger to continue.
• Now check the calibration. Look at the screen through the scope. When you move the gun around the screen, the on-screen reticule should stay within view of the scope. As long as the reticle is visible, your calibration should be ok. If, however, you can't see the reticle at all times or you're simply not happy with the results, select the calibrate option to retry.
• Once you're happy with the setting, you'll need to save them. Exit the calibration screen and select "Yes" (you would like to save your settings).
Note: Moving your position within your room may throw off the calibration. If you decide to change positions, we recommend recalibrating for the best results.
Additional Tips and Tricks to Having a Good Experience with Your Top Shot Elite.
1. Room Setup
• Make sure your room is comfortably lit - not too bright. Your TOP SHOT Elite has a built-in infrared camera and will have less trouble seeing the infrared lights from your sensor bar if you turn down some of your lights a bit.
• Make sure you've removed extra lights near or around your television. The TOP SHOT Elite includes a small camera that looks for infrared light. If you've got little lights or even candles around your television, your camera might have a hard time seeing the sensor bar.
• Turn off other gaming consoles. Other gaming consoles might interfere with your TOP SHOT Elite. For example, if you're trying to use your Xbox 360 TOP SHOT and you have your Wii turned on, the sensor bar from your Wii could interfere with the wireless sensor bar for your TOP SHOT Elite.
• Give yourself plenty of room. The TOP SHOT Elite works best if you're standing about 6 to 8 feet from your television. In addition, you want to make sure you don't have any breakable objects near you when you're playing with the TOP SHOT Elite. This includes vases, lamps, other people, and anything else you wouldn't want to accidently hit with your TOP SHOT Elite.
2. Sensor Bar Setup
• Set your sensor bar at a comfortable height. Your TOP SHOT Elite needs to see the sensor bar at all times. Generally speaking, you want to set your sensor bar above or below your television so that it is as close to eye level as possible.
• Make sure your sensor bar is on. Please note that the wireless sensor bars that come with your TOP SHOT Elite don't stay on all the time. To save on battery life, the sensor bars have a built in timer that shuts off automatically. You can set your timer by adjusting the small switch in the back of the sensor to 1, 2, or 3 hours. When your sensor bar is on, you'll see a little red light in the front.
• Why isn't there a Sensor Bar Position option when I calibrate? When you calibrate the Top Shot Elite, the game automatically figures out where your Sensor Bar is, so you don't need to manually set it up.
3. The TOP SHOT Peripheral
• Turn it on and sync it up! Your TOP SHOT Elite peripheral is a wireless controller that needs to be synced to your console. If you need help syncing your TOP SHOT Elite, please refer to the following guide to help you out: Customer Service FAQ
• The forward control stick. Sometimes you need just a little extra help. Located on the front left of your TOP SHOT Elite is a second control stick that you can use to help you quickly turn while playing Dangerous Hunts 2011.
Posted on Jan 08, 2011
  • 21 Answers
SOURCE: I just purchased Cabelas dangerous
See the Top Shot Elite Set Up Guide on the Discussions Tab at Facebook.com/ActivisionHunts or contact Activision Assist on Facebook.http://www.facebook.com/topic.php?uid=133041143393695&topic=331
The same is below.
How to Calibrate:
• Select "Controls"
1. Room Setup
2. Sensor Bar Setup
  • 21 Answers
SOURCE: Problem with the Activision Cabela's Dangerous
The same is below.
How to Calibrate:
• Select "Controls"
1. Room Setup
2. Sensor Bar Setup
ladysrome
  • 54 Answers
SOURCE: gun won't sync on 2013 cabelas dangerous hunts
Good game equipment can help you solve this problem, a good gun model controller can let you enjoy a live-action version
Posted on Dec 07, 2012
Gun won't sync on 2013 cabelas dangerous hunts
Dec 06, 2012 | Activision Cabela's Dangerous Hunts 2011...
Xbox cabelas dangerous hunt is there suppose to be
yes there is. it holds all of your memory and a lot more
Mar 13, 2011 | Activision Cabela's Dangerous Hunts 2011
I have the X box Kinect and just purchased the Cabelas Dangerous Hunts 2011 game. I can't get the gun to connect to the sensor that came with the game, I don't think I need to disconnect kinect fto play ...
Try connecting it to the console by pressing the small button under the disk tray and the counter one on the gun.
Other solutions
  • Low batteries
  • line of sight needed between sensor and gun
Does the game come with a manual perhaps?
Mar 07, 2011 | Video Game Consoles & Games
The gun wont calibrate
Cablela's Dangerous Hunts 2011: How-to-Guide for the Top Shot Elite by Activision Hunts
http://www.facebook.com/note.php?note_id=174694822565847
Jan 03, 2011 | Activision Cabela's Dangerous Hunts 2011...
How do i synch the gun to my ps3?
i cant sync my cabelas gun to my ps3 the scope wont work but the buttons do can anybody help me figure this out please?
Nov 30, 2010 | Activision Cabela's Dangerous Hunts 2011
Video Game Consoles & Games Logo
112 people viewed this question
Top Activision Video Game Consoles & Games Experts
Person On the...
Level 1 Expert
Zhenya Ogorodnikov
dj ese
Level 1 Expert
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
