Question about Sony NWZ-E438F Digital Media Player
Sony walkman nwz-e438f won't start up
On starting the device you get the initial screen then it turns off. Unit has full power. When placed in charging point the initial start up screen flashes continuously, but still won't turn on. Have tried resetting the unit a number of times. Any ideas?
  • 11 more comments
  • jeff brown Jan 05, 2009
    Same as above.
  • xenia_joe Jan 24, 2009
    same mines only 5 days old
  • Anonymous Jan 27, 2009
    I have the same problem turns directly off when turning on
    Reset won't help
    With USB cable to the computer, the display is on with the message Connected USB
    With the computer you can go into the files.
  • Anonymous Feb 05, 2009
    same as above and 5 days old as well
  • mykalgraves Feb 11, 2009
    i plug mine in and it says full, unplug it and i got 1 bar left wtf sony. this is my second one, i returned the first to walmart and i am about to do the same with this one
  • speedbleue Feb 17, 2009
    After regularly 2 months using this sony, it is starting with the first display " every moment has its music" and shut off by itself... What a waste!
  • Anonymous Mar 04, 2009
    The thing flashes walkman but only for a second and shuts of then flashes again then turns of
  • Anonymous Apr 21, 2009
    will someone please give a helpful solution? mine does the same thing and im very upset about it
  • Anonymous May 02, 2009
    I have exactly the same problem!
  • t_andrew80 May 02, 2009
    Will only power on for a second and shuts right back off..not even a month old. Cant reset it and it wont do anything when you hook it to a pc except cut on and back off...WTF I have three ipods and don't have any trouble with them, One is the original mini and it still rocks out. Can someone plz help!!
  • Anonymous May 03, 2009
    same as everyone else wont set up even after tryin to reset
  • Anonymous May 10, 2009
    Same problem here. I got it to stay "connected" once and I thought the problem had disappeared. Now I'm almost out of juice and I can't re-charge the damn thing.
    Constantly turns on & off
  • lost now May 11, 2009
    i need help as well my sony walkman nwz-e438f will charge on the computer but i can't access it on the computer. so i can't put any new files on it
Check that your not plugged in to a usb hub, my hub is USB 1. When I connect direct to a USB2 port problem solved!!
Posted on Feb 05, 2009
Reset with no disc etc
Updated 08/05/2014 05.01 PM
Reset Procedures for Garmin, Navman, Tom Tom
Garmin Master Reset NB: This will erase all way points or favourites and will restore your unit to the default factory settings.
NuviĀ® 2xx, 2x5, 5xx, 6xx, or 7xx.
  1. Start with the unit OFF and unplugged from power.
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil.
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON.
  4. Release the power button when the device powers ON.
  5. You will see a new message: Do you really want to erase all user data?
  6. Remove your finger from the touch screen when this message displays.
  7. Touch Yes.
The device will automatically reset. Please follow the on-screen prompts on the n?vi and when completed, place your device in an area with a clear view of the sky until it acquires satellites.
NuviĀ® 8xx or 5000.
  1. Turn the device OFF (you will need to remove the battery from a nuvi 8xx).
  2. Turn the device back ON (you will need to install the battery into the nuvi 8xx).
  3. When you see a progress bar on the screen of the unit, quickly place your fingertip, or the eraser end of a pencil, in the bottom right corner of the touch screen.
  4. Hold the bottom right corner of the touch screen until a message says, "Do you really want to erase all user data?"
  5. Release the touch screen and touch Yes.
  6. The unit will now restart.
  7. Follow the onscreen prompts to set up the nuvi.
Navman S30/50/70/S80/90i.
  1. To reset your device, hold down the power button for at least 10 seconds and the device will power off.
  2. Press and hold the power button to turn the device back on.
For other models, please visit this link, select model and search for 'reset'.
  1. Soft reset - select your model.
  2. Reinstall TomTom application.
  3. Format internal memory or memory card.
Apr 01, 2015 | Navman S30 3D Portable GPS Automobile...
How can I get the samsung tab to turn on
I'm assuming this is a new device for you. Do/did you see the battery charging icon in the middle of the screen when you plugged it in? If so, great. If not you are having a problem charging your tablet. Most likely either a bad cord, a cord that's pulled out a bit on either end, or an outlet that's turned off or not working.
If the icon was present and indicates a full charge, then simply press and hold the power button for a few seconds and the screen should start right up.
If it worked for you in the past, check your power cord. I've gone thru 3 on mine.
Aug 14, 2014 | Samsung Galaxy Tab Tablet PC
Virgin mobile venture won't start
Take the battery out. Then put it back in. I couldn't find anything that would work but doing a hard reset. Once I did that the phone worked again. I lost everything but my phone works again.
To hard reset the Virgin Venture please follow the instructions below:
Start with the phone turned off.
  1. Press power button until the phone turns on and vibrates.
  2. Press and hold the up volume button until you see the word hello.
  3. Release the up volume button.
    : You will see the word hello on the screen for about 5-7 seconds.
  4. The screen will display the android guy next to an exclamation point inside a triangle.
  5. Press the home button to access Android system recovery screen.
  6. Scroll to and select wipe data/factory reset.
    : The volume button scrolls and the enter/return key selects
  7. Scroll to and select Yes.
  8. The Venture will reset.
  9. Select reboot system now.
The Venture will reboot to the initial setup screen
Aug 10, 2012 | Virgin Mobile PCD Venture No Contract...
Model 1350 will not aquire satelites to operate
During the initial start up of your GPS it may take 15-30 minutes to lock satellites depending on where it is. I would suggest giving it a full charge powering it on then let it sit for 30 minutes. If you are unable to lock satellites still there may be an issue with your unit.
Hope this helps!
Apr 07, 2011 | Garmin Nuvi 1300 GPS Receiver
How to charge dvd plug in to ac get a red light some time yellow and do you charge with power switch on or off need a manual.
I have seen no rechargeable device that requires the power switch that lets the device function turned on. Often, it is mentioned that the length of time for a full charge will be longer if the unit is in use at the time since the unit and recharging function both require power and if the player is in use, it logically has priority over the recharging function. In other words, it should charge more quickly if the player is turned off.
Unfortunately, Initial's website: is no longer in operation so finding the manual could be a problem. Initial Technology has sold a number of 'turkeys' in the US (we own an Ilo TV) and I think they no longer exist.
Jan 02, 2010 | Initial IDM-1731 Portable DVD Player with...
Initial setup to operate gps?
you normally wouldnt have to but it is recommended to charge it. if it was tested before it was packaged, its possible it was in sleep mode instead of turned off..if its in sleep mode, it will drain the batteries over time. if its not starting, charge it for a few hours, then hold the power button untill it starts. if that does not work, try a hard reset.
Jul 09, 2009 | Magellan Maestro 4250 GPS
I turned it on and it lit up and then completely died
Question: Why won't my StreetPilot c3xx power on?
Found on the Garmin web site --> Answer: If your StreetPilot does not power on, or if it turns on then turns off, you can troubleshoot the problem by resetting or charging the unit. The reset is a "soft" reset that you can perform in the car; it restores power to the unit, but it does not remove data.
To reset the unit:
  1. Place the unit in the cradle and roll it backwards slightly to lock it in place.
  2. With the key in the car ignition, turn on the unit or put it in accessory mode.
  3. On the face plate of the unit, put your thumb nail in the groove under the Garmin logo and gently pull off the face plate.
  4. With the face plate removed, press the reset button on the right side.
  5. Turn the unit back on. If the unit still doesn't power on, you may need to charge it.
To charge the unit:
  1. Using the provided USB cable, connect the device to the computer.
  2. Reset the unit (following instructions above).
  3. Keep the device connected to the computer and allow it to charge overnight (7-8 hours).
  4. After charging, unplug the unit and power it on.
//changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 03/10/2008
Oct 05, 2008 | Garmin StreetPilot C330 GPS Receiver
Digital photo keychain
Have done that, reset the unit, tried all combination of re-installing software, starting program 1st, plugging in unit 1st. pressing power button, resetting unit while USB is plugged in adn not plugged in, holdig doen power button and reset, holding pwr button while plugging in, and about 20 more combination. The screen says "UPDATING", the little light is"GREEN", the battery meter shows "FULL", when you unplug unit screen goes black and "NOTHING"... "0", "NADA", piece of **** !
Dec 08, 2007 | Alera Technologies Digital Photo Copy...
Turn it on
Here is the page to download a user manual: The screen you speak of is an initial setup screen, if you use the stylus and tap on the screen where the cross is. this will get you started using the device.
Aug 04, 2007 | HP iPAQ hw6515 Pocket PC
Sony NWZ-E438F Digital Media Player Logo
682 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
