Question about Consew SKZ-6 (head only)
Existing foot pedal overheats and smokes
Please can you advise on the best new one i can buy for the Singer Capi 141, and the reason my old one is overheating and smoking it is the second one that this happened too, the existing pedal no. is
103435 009.
Replacing clutch type with a variable speed 3/4 hp 400 watt motor. I need a compatible foot pedal. can you suggest one that will handle the wattage
Sewing Machine Foot Pedal - Alibaba.com
www.alibaba.com > Machinery > pedal
804 Results - Sewing Machine Foot Pedal, Buy Various High Quality Sewing Machine Foot Pedal ... Power: 400W Compact AC servomotor(direct-drive system).
Jul 30, 2015 | Sewing Machines
Wiring a foot control pedal for Singer 2010
Your question is not clear to me. If you need to work on the Foot Pedal I'd just buy a new one on eBay.
SPEED CONTROL FOOT PEDAL POWER CORD SINGER 7350 1 3709 3722 6510 2010...
Mar 26, 2015 | Singer Sewing Machines
Nothing happens when I push the foot pedal
Please check the Stitch regulator & Presser foot lifter.
Jan 03, 2014 | Singer 7442 Mechanical Sewing Machine
Need foot pedal control for singer 766
try calling or email these sites and ask them about the part
sewvacdoctor.com
a1sewingmachines.com
Feb 10, 2013 | Singer Sewing Machines
My singer will not stop running untill i pull the elec plug
it possible that either the foot pedal isn't working correctly
or the switch to the sewing machine is not work correctly
it needs to be serviced
Jan 17, 2012 | Singer Sewing Machines
I have a singer sewing mahine 3014 does any know were i could get a new foot pedal from my smoking
If you are in the USA, try www.sewingpartsonline.com, search for Foot control and lead Singer. They have one listed for the 3014
Jan 13, 2012 | Singer Sewing Machines
My singer 4522C home sewing machine slows very slowly, even when I floor the pedal. It's also beginning to smoke. Any ideas what is wrong with it?
If the motor is smoking it may mean a new motor, if it kis the foot control you need to take the little square suppressor out.
Aug 14, 2011 | Singer Sewing Machines
I have 2 singer 9117 sewing machines. One is an older model with an air hose type foot pedal. This one runs great. Since it runs to great I decided to purchase a brand new one. The only difference is the...
It may be your foot pedal needs to be replaced, it looks like there is a couple of different ones. (I looked at www.sewingpartsonline.com) and saw they start at around $20, you can call them and see which one to get or call Singer at 1-800-4singer.
Feb 15, 2011 | Singer Sewing Machines
My foot pedal started smoking on my Singer 413 Sewing Machine
Hi.
No solution I'm afraid - but it has just happened to me too on a 1975 singer 522 Machine. Like you just switched it off and am now sourcing a new pedal....did have a look inside the pedal but nothing obvious - smells horrible though and will not use until replaced.
Jan 03, 2010 | Singer CE-200 Quantum Futura Computerized...
Consew SKZ-6 (head only) Logo
515 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Shehu Pro
Shehu Pro
Oloyede Monsuru
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
