Question about Toshiba Satellite A65-S126 Notebook
Toshiba Satellite laptop won't start
My laptop screen just flicker out and up to now it wont open. I connected it to the charger but after it lit to yellow then to green it wont open up. help
    Sergeant:
  • 366 Answers
From Toshiba Manual:
"Over a period of time, and depending on the usage of the
computer, the brightness of the LCD Screen will
deteriorate. This is an intrinsic characteristic of LCD
technology.
Screen will dim when the computer is operated on
battery power and you may not be able to increase the
brightness of the screen.
Try pushing Screen contrast to Max when on AC charger connected.
Allow several hours charging battery with PC off.
If battery does not completle charge Or if older than 3 years CHANGE it.
Posted on Jan 04, 2009
My laptop is lit up but cant go any further
Wdk, Try starting up in safe mode and use system restore to go back to an earlier date when PC ran OK, an update or virus may have corrupted the start up. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Windows is loading files then blank screen
http://ccm.net/forum/affich-108275-toshiba-laptop-cannot-reach-login-screen
My Toshiba satellite cannot load anything at all Windows 8 and Windows 8 1
http://forums.toshiba.com/t5/Windows-7/Windows-7-won-t-start-black-screen/td-p/157700
Aug 27, 2016 | Toshiba Satellite Computers & Internet
Toshiba satellite battery won't charge
DID YOU NOTICE ANY OVER HEAT IN BOTH,THE PC OR CHARGER? IF SO THE CAN BE 2 ISSUES.
1-THE CHARGER
2-THE BAT
IF YOU TRY TO CONNECT THE CHARGER WITHOUT THE BATT,THE CHARGER GET HOT? (1) ,DO THE CHARGER IS OK (2)
Apr 26, 2012 | Toshiba Satellite A65-S126 Notebook
My toshiba satellite pro doesn't work , even with charger in , it doesn't turn on , its like all the power is gone :o ?
You may have a bad DC connection:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 16, 2010 | Toshiba Satellite A60 Notebook
Flickering screen Toshiba P105
Flickering, always cause by LCD cable. Change it at any computer shop or service center and its not so expensive
May 08, 2010 | Toshiba Satellite P105-S6104 Notebook
My Toshiba wont turn on. I tried holding the power
Hi there, Your ac adapter is damaged & that's why power does not transfer in your notebook. The capacitor of adapter is burned & that's why the noise started. Thanks & waiting for your feedback.
Feb 19, 2010 | Toshiba Satellite A60 Notebook
Toshiba Satellite A135-S2276 just suddenly stopped
first to do is check your charger... remove the battery then connect the charger.. if still not working.. you need to open the system check the dc connector if its okay.. now time to check the motherboard. maybe some chips bluwn or burn... shortage... this is always happens epecially those over heating the cpu fan is slow not enougth to give out the coold..
Sep 09, 2009 | Toshiba Satellite A135-S2276 Notebook
Flickering Screen on Model P105 Toshiba Satellite
on the back of the LCD is a cable that goes from there to the Motherboard. Try reseating that cable on both ends. If that doesn't fix it then it has to be a problem with either the screen or the cable behind the screen.
Aug 11, 2009 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 Display
If you've replaced the LCD Panel already, then chances are good, the failing part may be the FLR inverter. It's a thin little chip about 3 or 4 inches in length that bridges the connection between the LCD and the motherboard. It's location varies from computer to computer though, so you may have to check with manufacturer documentation. They're not too terribly expensive to replace though, much cheaper than the LCD panel, anyways.
May 09, 2009 | Toshiba Satellite A105-S4004 Notebook
Computer screen is upside down
u need to open the monitor control menu by pressing the menu key on the monitor then select the option showing two bent arrows one facing up and the other down, then adjust.
Mar 14, 2008 | Toshiba Satellite A205-S4617 Notebook
Toshiba Satellite A65-S126 Notebook Logo
157 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
