Question about Kenwood Radio Communications
Frequency display showing row of dots on 432mhz
Kenwood Transceiver ts790 VHF/UHF.
When wanting to use 432mhz the display shows row of dots and fails to function. It will eventually come to life only after prolonged switching on of radio when heated up (2hrs+). No sound can be heard until display shows but this can be muted sometimes suggesting maybe dry joints on PCB.
I have been told this may be due to bad earthing of PLL unit for the 70cms board.
Many thanks if you can oblige.
Dave
Neto
  • 123 Answers
SOURCE: Kenwood TH-79E Handheld tranceiver faulty display
I think the display may have contact problems, or humidity. check for that conditions.
Posted on Dec 03, 2007
eradiostore
  • 1654 Answers
SOURCE: Need to know if MTS2000 MODEL H01UCD6PW1BN is VHF
No, it is 800 MHz
Posted on Jun 07, 2009
SOURCE: VHF Unlock
Radio off, use moni & menu toghether, start radio keeping the 2 pushed for some time until SELF apears on display. Then insert magic code 5858. There are now 2 values on screen like 136 174 first is lower limit, second is higher limit, after moding ude Enter and restart radio. Remember that at extreme ends pll may not lock on tx or rx or both, this is phisycal limitation of the radio board.
Posted on Jul 17, 2009
Mot-Dealer
  • 35 Answers
SOURCE: communication not good &battery cannot charge
If your area is big or has a lot of concrete, then you will need more then just a few cheap radios from thailand, Given range info from broshure is always meant above flat area - not inside building
Posted on Sep 23, 2009
SOURCE: I need a belt clip of Kenwood TK-2160 vhf fm
Kenwood Part # is J29-0701-05 for the spring clip type. If you have a mailing address I'll send you one.
Posted on Apr 22, 2010
Just bought a new Kenwood 2400 to add to the other 2300 radios and I can't get them to communicate even though they are both on channel 1 which should be the same frequency! Help!
The 2300 is Vhf and the 2400 is Uhf. They cannot talk to each other. Not a programming issue, the wrong radio band and it cannot be changed.
Jul 14, 2015 | Kenwood Radio Communications
Can I reprogram my tk-2400 with my PC?
No. It is programmed from the Factory on a chip. Preprogrammed. No software will change it, no hacks. Many Motorola radios like that too. It is two watts, Vhf of Uhf, you did not say. If your existing frequencies are Business Band and in the same frequency band (Vhf or Uhf) you can get it to match those.
Oct 13, 2014 | Kenwood Radio Communications
Chanel lock
The Kenwood TK-3312e is a EU version of that handheld If you truly have that model# 3312e and not a TK-2312e.
Then you don't have VHF here the specs for the posted model# you gave.
Frequency Range: 400-470 MHz 5 Watt RF Output 128 Channels/128 Zones Built-In Voice Scrambler QT, DQT, DTMF and 5-Tone Signalling FleetSync Digital Signalling, PTT ID and SelCall MDC-1200 Signalling PC Programming
Jul 01, 2014 | Kenwood Tk-2312e / Tk-3312e vhf / Uhf...
Eeprom error ? B0003 on display
if a reset has failed, these means either the eprom or the cpu is damaged.
Feb 11, 2014 | Yaesu FT-2900R 75 Watt 2 Meter VHF Mobile...
Can the freq 156,600 be put in this radio if so how do i do it
No, 156.600 MHz is not one of the 27 VHF frequencies available in the CP100 VHF radio. (If by chance you have a typo and you meant to ask about the common frequency of 154.600 MHz, aka green dot, it is available in the CP100 VHF.)
Here is a link to a website with the user guide:
http://www.essnashville.com/CP100-operationsmanual-021407.pdf The frequency chart is on page 34. Programming instructions begin on page 20.
Best regards.
Best regards.
Feb 09, 2014 | Motorola Radius Cp100 Uhf 1ch Two Way...
Wiring a mic to a ham radio.
Get the schematics, isolate the circuits, and apply the fix. But... You probably want all those details.
Dec 07, 2013 | Kenwood TM V71A VHF/UHF Mobile Dual Band...
VHF/UHF RF Power falls to Zero when the Auto ATU tunr logo is on the display. When the tunr logo is off the VHF/UHF RF power is only 10 watts on 2M and 3 watts on 70cms. The Yaesu FT 857 D should have no...
Check for open or shorted Veractor diodes and steering diodes there may be no direct interaction as you say but if a diode is open or shorted the RF circuits might still be selected for the higher bands and the lower output power on your vhf/uhf is an indication of this.
If you do not have a service manual you can get one hear, you will likely kneed one
http://www.tradebit.com/filedetail.php/127575994-vertex-yaesu-ft-857-ft-857d-2005-service-repair
Good Luck Best regarsds Falco
Nov 04, 2013 | Yaesu FT-857D transceiver
Kenwood tk-768 displays channel numbers. Can I get it to display frequency instead?
Hi Michael,
Simple answer is NO!!!
The way these radios are designed, as with nearly all 2-way radios, only Channel Numbers are displayed. This is to save space on the LCD display for the other icons to fit in.
I hope this answers your query with satisfaction.
Ragards,
Peter
Dec 08, 2012 | Radio Communications
Radio Communications Logo
46 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
