Question about Kenmore 96532 / 96534 / 96539 Electric Kitchen Range
Kenmore range When I turn on the oven, I do not get a preheat signal as I usually do. Instead, there is a period of about a half minute wait and then a code pops up EO or D..? and an F1. I can't find my manual so I have no idea what that means. Thanks
    Problem Solver:
  • 11 Answers
Either the control is bad or your temp sensor is bad, the temp sensor is cheap and easy to replace, the board is easy to replace, but not cheap. hope this helps
Posted on May 20, 2007
I cleaned the oven self clean, now the oven preheat feature won't turn on
I don't know what kind of range you have or if it is gas or electric. You may have to call a repairman.
May 25, 2015 | Kitchen Ranges
What does it mean when your Samsung flat top oven and broiler will not work and the code reads E-08
E08 Error Message on a Samsung Electric Built-in Oven:
The E08 preheating error code appears if the set oven temperature is not reached within 50 minutes. If this code appears, the reason might be due to overheated thermostats, a defective heater or a defective relay; in which case a repair will need to be arranged.
However, if food has been put into the oven during the preheating time that may cause the error code, since the presence of food cools the oven and so it doesn't reach the right temperature. The error message can be removed by turning the oven off and turning it on again.
To prevent this error code from happening again, the oven should not be used during the preheating period. The preheating period ends just after the sound signal and the icon in the display have turned off. When the oven gives the signal, it's close to the set temperature and your food can be put in.
Apr 14, 2015 | Samsung Kitchen Ranges
My Kenmore Model 91195371790 oven Preheat light comes on as soon as you turn oven on and then flashes f2
Over-temp condition due to either oven temperature sensor or ERC (electronic range control).
Testing should be done by a qualified tech to prevent risks to user.
Jan 16, 2015 | Kenmore Ovens
Oven preheat times
It gas not electric. There is NO hidden element. It a bad sensor.
Mar 08, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
The stove preheat light is on and the oven does.nt cook fast
Hello Theresa Thomas - Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the range back on. Select a normal bake cycle and if issue continues then the unit may possibly have either a faulty element, bad communication error with the EOC, oven sensor, or mechanical thermostat. I strongly suggest contacting a professional to move forward accurately. They also usually warranty their labor just in case something else may turn out to be the root cause of your initial problem and it does work out better to your advantage. .
Nov 20, 2012 | Frigidaire FEF366 Electric Kitchen Range
Preheat issue with a new kenmore electric range
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 21, 2008 | Kenmore 96020 / 96021 / 96022 / 96024...
Kenmore gas range--oven won't come on
My oven will not work. After pressing the desired temp on the oven, the preheat light and oven light comes on. After about 15 minutes, the oven is slightly warm and maybe an hour later the oven may or may not heat to desired temp. Kenmore gas range model #790.72851301.
Nov 15, 2007 | Kitchen Ranges
Preheat taking long time
If your oven has the hidden bake element then it is probably working properly. A standard oven with an exposed bake element will usually take about 12-15 minutes to preheat. The hidden element models take a little longer but they usually heat a little more evenly.
Post back if you have any more questions.
Oct 29, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
times quoted seem about right and don't suppose your old oven was much different. element ratings don't vary much for same size ovens
Jun 07, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Kenmore 96532 / 96534 / 96539 Electric Kitchen Range Logo
69 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Marvin
Marvin
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
