Will not load files by playlist, will only load alphabetically
I run windows xp with windows media player. i can create a playlist, but when i load it into the mp3/ it loads alphabetically with no regard to playlist, artist,album,or any other form of organization.
i have read the manual several times, and can find nothing that works.
Re: will not load files by playlist, will only load...
When you turn on the mp3 go to the setting and you can choose how the songs load, Name, artist, size, alphabetically, chose the ones you want on. And turn the other off.
Hi, You can do play list from your PC. By connecting your MP3 player to the PC through Usb cable..
Things You'll Need:
* Computer * Media player * Digital music files
Creating a playlist on your computer is an easy way to organize your music. Playlists allow you to organize music by different artists or different genres. More advanced playlists can even sort your music based on when it was added or how often you play a particular song. Creating a playlist is an easy task regardless of the media player you use to play your music.
Determine what songs you would like to add to your playlist.
Create a new playlist in your media player. Depending on your media player, this step will vary. There is usually a "Create Playlist" button that you can click to create a new playlist. In iTunes, this button is on the bottom lower left corner. In Winamp, click the "View" menu and select "Playlist Editor".
Select the songs that you want in your playlist from a new Windows Explorer window. If you are using a Macintosh computer, select the songs from a new Finder window. You can hold down CTRL to select multiple tracks. Drag and drop these selected songs into the new playlist you have just created.
Save the playlist you have just created. Most media players have a "Save Playlist" button. Other media players such as iTunes will automatically save the playlist for you when you first create it. In Winamp, click the "Manage Playlist" button in the bottom right corner. In the following context menu, click "Save Playlist". Name the playlist whatever you want and then choose where you want it to be saved.
To create an M3U playlist
On your PC, create a new empty .txt document using word pad, type nothing but save the file as a .txt.
go in to my computer -->> explore and find the file and rename the .txt document so it has an m3u file extension (example: my_list.m3u).
Open the m3u file with wordpad, notepad, or a text editor.
In the first line at top of the page type #EXTM3U.
After the first line, start listing your music files, copy and paste the song names , (with extension ie .mp3). One music file name each line.
Exit the text editor and save the m3u file once you are finished.
Drag and drop the M3U playlist to the Sansa player's MUSIC folder, your done if it works.
Try Windows Media Player 10 or 11 on an XP machine. Search for media files on your computer to add to the Media Player library. Create a playlist of songs from your library. Use the Sync tab to sync the RD2765 to that playlist.
Creating Playlist To create a playlist for Windows Media Player, follow these steps: 1. Launch Windows Media Player. 2. Clear the List pane by clicking the Clear List pane button. 3. Click the arrow below the Library Tab then select Create Playlist. 4. Type in the name of your Playlist. Loading Content 14 5. Click Songs from Library then drag them from the Details pane to the List Pane. 6. To rearrange the songs, drag them up or down in the List pane. 7. Click Save Playlist. Transferring Playlists To transfer playlists to your Sansa player, follow these steps: 1. Connect your Sansa player to the computer. 2. Select Sync digital media files to this devices using Windows Media Player on initial connection. 3. Right-click on Your Sansa Player, then select Set Up Sync. Loading Content 15 4. Select Personal Playlists from the drop down menu on the left pane. 5. Highlight the playlists you want to transfer to your Sansa player, click Add, then Finish. 6. Synchronization will start as soon as you click Finish. To see the Sync progress, click on Sync Results.
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB". 2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode - Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list - Select the Sync tab and click "Sync settings" - Check "Synchronize device automatically" - Set "View" to "All Playlists" - Place a check next to the playlists they want to transfer to device - Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Use Windows Media Player to create the playlist, and then transfer them to the player by dragging the entire folder to the sync window, instead of dragging all of the files within the playlist to the window.
Provide more info 1/ what windows OS R U Using/2 H10 requires Windows Media Player ver 10 3/ If you do not have XP to run WMP10 then connect H10 in UMS mode, transfer audio files and playlists using windows explorer 4/then use EasyH10 to update the database on H10
