Question about Sanyo Camping, Backpacking & Hiking
Sanyo NL-560 Rechargable Emergency Lantern battery can't charge how to new battery fix and old remove from lantern?
  • 29 Answers
SOURCE: replacement globe for a 1960's thermos portable gasoline lantern
Hard find.........www.ronfoo.com
This guy may be able to point you in the right direction being an antique/collector's item.
GGBMDB
Posted on Dec 02, 2008
joboo1
  • 257 Answers
SOURCE: how to fit a mantel to a coleman propane lantern
Hi, First remove the knurl nut on the top. Remove the top and then the glass globe. There are several types of mantels most of which tie with a string that is part of the mantel top. The newer ones have a wire clip in place of the string. Which ever type you had on before you need to remove the old pieces completely. Since the mantles burn to an ash they will disintegrate when touched but if it had the metal clip you need to remove it. Tie or clip the new mantle over the lip on the output orifice being careful with the screen underneath. Replace the glass globe and top, put the nut back on finger tight. Remember that the mantel turns into ash when it burns for the first time so keep the gas low to start it till the mantle forms properly ( in the first minute) Good Luck, this should Fixya!
Posted on Mar 16, 2009
SOURCE: How do I put the battery into my new ibeam
This is an absurd situation. I am returning the flashlight for a refund.
Will never buy Garrity again.
Posted on Dec 24, 2009
Testimonial: "That's marvelous! "
  • 973 Answers
SOURCE: lantern doesn't charge using the hand crank dynamo
You most likely need a new battery, you can purchase one from Black and Decker, here is the link
http://www.dewaltservicenet.com/Products/ProductDetails.aspx?pid=68217&tid=15945
Posted on Jun 18, 2010
CarlGlas
  • 283 Answers
SOURCE: replacing batteries on Energizer Hard Case Lantern
Step 1.
Start by locating the battery compartment which will be on opposite end of the lamp. The compartment is covered with a protective rubber, tire-tread-like surface.
Step 2.
Twist the cover of the battery compartment counterclockwise to unscrew. Do not unscrew any of the screws on the sides of the spotlight, you need only to use your hand to turn and take off the battery casing cover and expose the batteries.
Step 3.
Remove the old batteries taking note of the orientation of the batteries in relation to positive and negative polarity.
Step 4.
Install replacement batteries, making sure to replace the batteries using the correct polarity.
Step 5.
Replace the cover of the battery compartment by putting it back into place and turning clockwise until secure.
  • Step 2 Twist the cover of the battery compartment counterclockwise to unscrew. Do not unscrew any of the screws on the sides of the spotlight, you need only to use your hand to turn and take off the battery casing cover and expose the batteries.
  • Step 3 Remove the old batteries from the hard case spotlight's battery compartment. Take note of the orientation of the batteries in relation to positive and negative polarity. Check for any corrosion of the battery terminals and clean with a small amount of vinegar, if necessary. Allow vinegar to air dry before replacing the batteries.
  • Step 4 Install 4 new C size batteries into the spotlight. Make sure to replace the batteries using the correct polarity. Rechargeable batteries are not recommended for this particular spotlight.
  • Step 5 Replace the cover of the battery compartment by putting it back into place and turning clockwise until secure.
  • Read more: How to Replace the Battery for an Energizer Hard Case Spotlight | eHow.com http://www.ehow.com/how_6182197_replace-energizer-hard-case-spotlight.html#ixzz0sx9yYC1Q
    Posted on Jul 07, 2010
    Where can I get a replacement battery for the trail tracker, emergency radio lantern, yellow?
    Trail Tracker Sport Lantern/Weather Radio doesn't charge using the hand crank dynamo for my Power on Board Trail Tracker lantern/radio, You most likely need a new battery, you can purchase one from Black...
    More information please open this link:-- Best Manuals
    Jun 17, 2016 | Cars & Trucks
    How to fix the switch on eveready lantern flashlight
    The switch in the lantern is a press fit switch so you will destroy it when you remove it. Remove the lense and retainer ring. Remove the battery. With a pair of pliers, preferably channel lock water pump pliers crush the switch into small piece and discard. Trail Tech makes the exact water resistant switch model 040-ls-b and you can get it at Amazon or on eBay . The switch runs around $6.25 + $4.00 shipping
    Jul 11, 2014 | Energizer Eveready Utility Lantern Uses 6V...
    Rayovac 360 sportsman lantern wont work
    Since batteries and bulbs are new/ok, check for a bad connection. In older version using 4 lantern batteries, open the battery compartment by unscrewing the knob on top of lantern. The lantern bottom comes off once unscrewed (of course you did this to change batteries). There is a "C" clip on the lantern center shaft; remove this by prying with screwdriver or with pliers. Carefully raise the battery contact plate and check slip-on wire connections. Clean as needed (Scotch-Brite works well) and reconnect. Squirt some contact cleaner in exposed switches, work switches back and forth. Inspect circuit board for obvious corrosion or damaged parts (this damage may "total" the lantern). Re-install plate aligning grooves with ribs. Install batteries and test.
    Nov 01, 2012 | Camping, Backpacking & Hiking
    Swissgear rechargable lantern won't light up, even though the green led light indicates it is fully charged
    There are several different models of the Swiss Gear rechargeable lantern. On most though, you can remove the top portion of the lantern and check the lighting element inside. In most cases the elements can be removed and replaced. I have a dual filament lantern and from experience I know that every so often you may have to go buy a replacement light piece. If the lantern has been bumped or even just strapped to the outside of the pack while walking, it's possible for those elements to become loose and need repositioning or replacement so do check that. I'm sure that it should be unlikely your charger is malfunctioning unless you left it plugged in for some very extended period of time, in which case I would say the light would be more likely to burn out. But definitely try that and if that doesn't work the battery pack on the lantern itself may have an issue in which case you can always get a replacement.
    Aug 29, 2012 | Camping, Backpacking & Hiking
    I am trying to find a 120 Volt AC adaptor for my Swissgear lantern.
    The adapter need to match the charge voltage requirements of the battery in the Swissgear lantern.
    This voltage maybe written on a label on the lantern.
    i suggest go to the shop where you purchased the lantern for the charge adapter.
    Jun 02, 2012 | Computers & Internet
    User's manual for coleman rechargeable lantern model # 5348-700
    There are several options to buy replacement batteries for a Coleman rechargeable lantern, model 5348-700. I just picked up two new batteries from www.1000bulbs.com for $4.87 each plus shipping. ($20.99 for 2 with shipping!) Do a Google search for: ub645f1 6 volt - 4.5 ah - f1 terminal battery for other options
    Jan 22, 2012 | Coleman Rugged Battery Powered Lantern...
    Manual for coleman lantern model 5348-700
    simple unscrew the top clockwise and you will see how the tubes are removed,
    Nov 22, 2011 | Camping, Backpacking & Hiking
    Tried to charge my Coleman Retro Lantern, the red light for charging is on but after 24hrs charging, I take the charger off and try to turn the lantern on, it wont work. How can I fix this...
    I just bought a retro rechargeable sealed battery,recently. I charged it for 18 hours,the lights all worked,but I don't remember the green light comming on.i put the lantern away for 3 months or so.i decided to check the the battery light out first week of june, the light was there,then I said let me charge it up again, I never seen any green light come on showing it was fully charged. I took the battery out and checked the wires to see if there was a break. None that I could tell. After you take the battery out ,there is another section square that covers where the bulb is located,but I didn't touch that part yet. Stuck" on this one. Help"
    Sep 15, 2011 | Coleman Retro Rechargeable Battery Powered...
    Coleman rechargable lantern Model 5327A750. Have not used it in a while have left it on charge for over 24 hours. the night light works but the main light does not go on. Replaced the bulb and still...
    just read the charging instructions. Charge for 16-18 hours. If stored for more than 6 months recharge for the full 16 hours. Do not leave the lantern on after the battery has stopped, has overdischarging the battery can cause problems in recharging to a full charge. If this does happen, switch lantern to off and recharge for 40 hours.YES 40 hours. Only the LED is the only light to be used while charging. If you hane the other light on hi or low the battery does not charge.
    Hope this helps
    Oct 24, 2010 | Sport & Outdoor - Others
    Camping, Backpacking & Hiking Logo
    409 people viewed this question
    Top Sanyo Camping, Backpacking & Hiking Experts
    Tom Chichester
    ray gallant
    Are you a Sanyo Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
