Question about Jwin JX-M20 AM/FM Radio
Locked keys i cant reset my clock. all the buttons seem to be locked.
On the JX-M20 lock by pushing 'H" button. (Left side between voume up and down.)
Unlock by holding "H" button til key disappears.
All else fails complete 'master set' by removing battery momentarily. Seems like it wont even lose time set.
Is that why there is a sat antenna logo on the radio?
Posted on May 16, 2008
Take out the batteries, that should work.
Posted on Nov 02, 2007
    Problem Solver:
  • 15 Answers
Hi. I have a different Jwin model radio to yours, but they might have this in common: is there a 'hold' button on yours? If so, this is used to 'lock' all the buttons so that you don't switch it on/ change stations etc accidentally. Look for a 'key' symbol on your display, and press AND HOLD the 'hold' key until the symbol disappears. Pressing the 'hold' button briefly will make the symbol re-appear, and lock the keys again.
Posted on Aug 29, 2007
SOURCE:
Just bought a x reg ford puma but the key fob does not work, bought a new battery and fitted it, needs re-programming but don't know how to do it.
Telephone: Fax: VAT Registration No.:
Infrared remote control
NOTE: Infrared emitter can be seen at front edge of key.
System operation
Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system.
Programming
When
Key batteries completely discharged. Key batteries not replaced within 15 seconds. Key added or replaced. System malfunction.
How
Obtain all keys fitted with remote control. Turn ignition switch to position I. Wait approximately 10 seconds. Ensure clock LED illuminates.
NOTE: LED illuminates for approximately 5 seconds.
Switch ignition OFF and remove key, while LED illuminated. Programming mode activated for approximately 20 seconds (LED illuminated). Proceed as follows: Point key at receiver (located near interior lamp). Press and hold unlock button Fig. 1 [1]. After approximately 1 second key LED will flash once [3]. Press lock button 3 times Fig. 1 [2]. Release unlock button Fig. 1 [1]. Continue to point key at receiver until LEDs in clock and key have flashed 5 times. Ensure LED remains illuminated. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode and extinguish clock LED: Switch ignition ON and OFF. Wait approximately 20 seconds.
NOTE: A maximum of 4 keys can be programmed. Fig. 1
Radio frequency remote control
System operation
Pressing tailgate release button twice within 3 seconds unlocks the tailgate - if fitted. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system. Interior lamp illuminates when disarming system.
Programming
When
How
Obtain all keys fitted with remote control. Fasten seat belts and close all doors. From position I, turn ignition switch as follows: To position II. To position I. To position II. To position I. To position II. To position I. Programming mode activated for approximately 20 seconds. LED or fog lamps ON warning lamp illuminates (some models) or the system will emit an acoustic signal to indicate start of programming mode. Proceed as follows: Type 1: Press and hold unlock button Fig. 1 [1]. Type 2: Press unlock button Fig. 2 [2]. Ensure clock LED or fog lamps ON warning lamp flashes (some models) or wait for acoustic signal (indicates correct programming). Wait 2 seconds. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode: Switch ignition ON. Wait 20 seconds.
Aug 25, 2010 | Ford Focus Cars & Trucks
AWIA VXG140 TV/VIDEO
http://elektrotanya.com/aiwa_tv-a1419.djvu/download.html
http://elektrotanya.com/aiwa_vx-g142_service_menu.pdf/download.html
http://elektrotanya.com/aiwa_tv_vcr_vxg_143.pdf/download.html
OK in these manuals above you should find, all the information, to reset any codes, the child lock, is most likely on, you need to disable it.
With the TV turned on, simultaneously press VOLUME down button on the front of the TV set and the number 7 button on the remote control to reset pin code and customer ID.
If that above doesn't work, try below.
CHILDLOCK Press ANY NUMB 3 TIMES, THEN PRESS VOL- ON SET & "7" ON R/C FOR 5 SECS this should disable it.
Jun 01, 2010 | Aiwa Televison & Video
Cant reset the clock
Press the cook time & ready time buttons simultaneously and keep the buttons depressed. use the plus and minus buttons to set the time of day. A (Auto) symbol goes out, cookpot symbol comes on.
Jan 06, 2010 | Tecnik TKC8522 Electric Double Oven
Seems like microwave is locked on clock
You have to set a time (any time) to use.
Press CLOCK, press number 2 then 2 then 2 again and then press CLOCK again. Does it say 2:22?
Everything should now work.
Do not run Empty, do not use any metal in there and do not use alot (MW kills all the vitamins and nutrition in food - like eating MUD for your body) .... and don't forget to reset the CLOCK ;-)
Mar 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Cant set cooker clock so cant use oven as a result
You will probably have to replace the cooker clock. Do any of the other parts work? This fortunately is not that expensive and you were blessed not to have more damage than this.
Jan 29, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Technik range oven
You said, you have a key symbol that's just showed up near the digital clock, and what it seems to mean is that the ovens are 'locked in some way. They won't heat up. When we turn the dials the red light doesn't come on and we cant hear the fan. There is a reset button on there but it doesn't get rid of the key symbol. I think someone leaned on the buttons yesterday and have inadvertently locked something! Please help! We can't find the manual.
1.Try holding down the reset button for 5 seconds!
2.Then if needed turn off the power from the breaker for 5minutes and see if this resets the system.
3. Send me the Model # and I will find you a user manual too!
Waiting for your response. If you can't find the model # , it will be on a white or silver sticker in the door Jam of the range OR the storage drawer below!
Huuum
Please remember to leave a rating!
Oct 12, 2008 | Kitchen Ranges
I cant get the key out or lock steering column and the automatic transmission shift lever locks up in park. Now if I take the battery off every thing works fine. This sure seems like a reset problem.I run...
This sure seems like a reset problem.I run the car by not having it in the locked column position and get the shifter to work by putting a key in the hole furnished
by chevy to bypass shift lock. thank you
Sep 15, 2008 | 2006 Chevrolet Aveo
Cant find reset button inside scanner
There is a lock/light key at bottom left hand corner of buttons hold that down until it beeps and the buttons should be unlocked
Jul 27, 2008 | Radio Shack Pro-82 Scanner
Jwin JX-M20 AM/FM Radio Logo
322 people viewed this question
Top Jwin Audio Players & Recorders Experts
 Grubhead
Grubhead
Dapid Candra
Dapid Candra
InstaRep
InstaRep
Are you a Jwin Audio Player and Recorder Expert? Answer questions, earn points and help others
